Garmin Edge 305 GPS Receiver
Problem for Garmin Edge 305 GPS Receiver
Acquiring satellittes function is not working
By tousey on Apr 25, 2008
When I turn my 305 on now the acquiring satellites screed is different showing no sateillites, it started doing this intermittently but now all the time.
Same Problem
Apr 19, 2009
-   Hi, I have Garmin Edge 350 and it is not acquiring satellites at all...:-((( -   Guest
Feb 06, 2009
-   I have the same thing. No GPS function but everything else works fine. A bit frustrating but not worth repairing as everything else works fine.-   robboniwell
Jul 12, 2008
-   Same problem with my unit. Recently it has not been "seeing" any satellites when the unit is powered on. The screen just says "acquiring satellites" but never does. Sometimes a quick power down and restart will bring the satellites up, and sometimes after a while the satellites will magically appear, but other times it will not lock on, see, or acquire any satellites which means no speed, no distance, and no tracking information from my rides :-(-   Guest
Best Solution
posted on Dec 04, 2008
Very Helpful)
asmpires
Rank: Apprentice
Rating: 100%, 1 votes
The problem: when I turned on my Garmin Edge 305, the "Acquiring Satellites" screen showed no satellites at all. It started doing this intermittently, but now it was happening all the time. Also, when this happened, the unit displayed incorrect date and time. I also noted that when I accessed the "About Edge" option from my unit ("Settings>System>General>About Edge"), the "GPS" field said "0.00".
The solution provided by Garmin Support: "It sounds like there might be some corruption in the satellites data of your device. To delete this information, while the unit is powered OFF press the Power and Down button for 15 seconds. Then set the device outside for a minimum of 30 minutes to acquire satellites and the satellite data."
It didn't work for me, but maybe it'll work for you. Anyway, today I turned on my Edge 305 before my training ride and, miraculously, it recognized and acquired satellites again, displayed the correct date and time and the "GPS" field said "3.00". Maybe it was just in a bad mood or something...
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 06, 2008
Very Helpful)
miltrit
Rank: Apprentice
I had same problem--but when I cleared the memory and restared the unit, it started to work normally. (However this also caused me to lose any data, routes, etc. that I had programmed into the unit.)
Was this helpful?
Yes
No
Solution #3
posted on Jul 12, 2008
Somewhat Helpful)
crkdtoes
Rank: Apprentice
Rating: 75%, 1 votes
I am having the same intermittent problem but am worried that it will become permanent. Any information available to get the unit to acquire satellites would be great
Was this helpful?
Yes
No
Solution #4
posted on May 30, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Same here!  I just contacted to the supplier to see what they say, not sure if I'll get back, but rest assured your not the only one...
Popular Solutions for Garmin Edge 305 GPS Receiver
Questions and Unsolved Problems for Garmin Edge 305 GPS Receiver
Do you recommend Garmin Edge 305 GPS Receiver?
Answer
Answer
My edge 305 doesn't always pick up sallelite. I use it on my bicycle and it fell off adaptor onto... (More)
Answer
I will be riding a 340km 24 hr mtb stage race consisting of 6 stages in dec. How do I manage... (More)
Answer
my garmin edge 305 freezes up during the ride on occasion. the distance and elevation numbers just... (More)
Answer
Device shut off due to low battery and never charged again
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top GPS Devices Experts
Top GPS Device Repair
(408) 298-8188
Auto Nav 2000 Plus, Inc can repair most portable...
Auto Nav 2000 Plus  IS YOUR ONE Stop GPS Store
(281) 371-2722
GeoQuip is a "One Stop Trimble Repair...
Gulf Coast GeoQuip
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
