Question about Kenmore Oasis HE 27082 Top Load Washer
After turning power on and setting cycle and pushing start. Machine seems to take forever and at times doesn't start the washing process. after approx 15 to 30 minutes the time read out is still on the same number. washer want respond to pushing power off or any other function. I have to unplug machine. once i pull the plug to turn machine off. I replug then theres a flashing of the lights and constant beeping....Then there are times when the washing process starts and when it get to the rinse and spin and drain part, the washer won't drain or turn off or change cycles. Then i unplug and replug try to use just the drain and spin cycle , but washer won't respond. what do you think the problem may be.
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow links to diagnose your problem when your washing machine won’t respond….go through the given articles to have an in-depth knowledge regarding your query….
http://www.ehow.com/how_8264_troubleshoot-washing-machine.html
http://www.ehow.com/how_112327_diagnose-washing-machine.html
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntworkatall
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 02, 2010
Tricity bendix washing machine won't work on any of the settings
Hi, mine is the same - it will literally go on forever and it wont seem to ever 'finish' like it wont drain properly either - is it the 800 model? quite and old machine with a button you push in and twist to select the cycle and pull out to turn it on? its just awful it wont give an indication whether its completed any cycle! did you get yours fixed?
Feb 25, 2016 | Tricity Bendix Washing Machines
The normal wash cycle wasn't counting down and seemed stalled at 39 minutes. I turned off machine to change cycles. Now door remains locked with lock indicator flashing and machine doesn't turn on. When I...
You interrupted the cycle and now the memory has been compromised. You may have to call the manufacturer to get assistance from the help desk and have then run you through the process of doing a factory reset.
Feb 03, 2015 | Washing Machines
Indesit Washing machine WIL88 red light flashing
Seems that the main board or the processor is hanging up and does not take up the full process control. You need to remove the panel and check for moisture on the board, check for loose connectors. If this seems fine the fault seems related to the board and can be confirmed with a board swap before one can be ordered. Check the door switch and wiring to the main board.
Jun 03, 2013 | Washing Machines
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
My washing machine would stop and beep and not advance to the next wash cycle and it was taking forever to fill up. I did the diagnostics and found it to be #49 which is a faulty hot or cold water valve. ...
Sorry for the very much delayed response due to site changes which modified the notification system.
Anyway, you should try holding first the WASH TEMP DOWN button then the POWER button until there's a beep. If it doesn't work, use WASH TEMP UP instead.
Make sure the Restart feature is turned on and the Recycle feature is turned off if all else fails. During the diagnostic mode use the WATER LEVEL DOWN button to turn RESTART on by pressing the said button until the LOW WATER LEVEL LED turns on. Use the WATER LEVEL UP button to turn RECYCLE off. The MEDIUM WATER LEVEL LED off indicates RECYCLE OFF. To set these modes in EEPROM the Advance button must be held while selecting Restart or Recycle. Power off the machine thereafter to complete the reset.
Oct 17, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have purchased a house with the single door dishwasher and it takes forever to wash - about two hours - what could be the problem?
Check your program settings. If wash quality is good, it's OK. Check your inlet water has sufficient pressure! Refer user manual
Apr 07, 2010 | Fisher and Paykel DS603SS Stainless Steel...
The wash time continues to increase on every cycle. I have a Maytag Neptune TL Washer.
Thank you my machine model number. The reason I ask is so many folks post non FAV6800A/FAV9800A issues in this forum. This forum doesn’t ask for machine model number and serial number. Here we go.
Does your machine seem to take longer than normal to fill with water?
Does the machine increase the time during the Spin Cycle of the Wash Cycle?
Are there any error codes to the LED display such as dC or uC?
Do you want to work toward a DIY fix? If not maybe we can get a solid feel for the issue that will help you in the decision process to bring in a repair company or replace.
So I can better understand the issue can you start a Quick Wash cycle with Soil and Spin settings set to lowest setting and if you could place a couple of bath towels in the wash basket for a load.
I want to see if the machine will go thru the Wash, Rinse and Spin cycle within the 27 to 29 min time of a Quick Wash cycle. I want to see if the machine is increasing Washer Cycle time in the Spin Cycle of the Wash Cycle.
You should enter the Rinse Cycle at the 20 min mark on the LED display.
You should enter the Spin Cycle at the 10 min mark on the LED display.
Watch the cycle and see if you have similar times as I do. Let me know if the washer has any off balance issues as it enters into the Spin Cycle…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a technika diswasher,not sure of the model, is approx 3 years old and has a big dial on the left hand side with 7 wash functuions and the power button is smaller and is on the RHS. I cant remember...
I have the same model. You just turn the dial to the setting you want, push the dial back in, turn the (right) power button on then turn the smaller start button on. I use different cycles all of the time depending on whats in the load and this works fine for me.
Apr 27, 2008 | Dishwashers
Kenmore Oasis HE 27082 Top Load Washer Logo
65 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
