Question about Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Antenna wont work for advent tv Model: LC-15Y26
Sharp TV model LC-20AV1U - I need to reset it so I can get it to recognize my over air antenna after cutting cable TV
Hi Loretta,
The reason you aren't getting any channels to work on this TV is because it has an analog tuner. Now a days most channels are being broadcast in digital format and the TV needs to have a digital tuner.
In order to get the antenna to work on this TV, you will need to have an OTA converter that will receive the digital channels and send the signal in analog format to your LC_20AV1U.
Let me know if you require further assistance..
Feb 23, 2017 | Sharp Televison & Video
Advent LC-15Y26 TV - Right side buttons not working (menu, input, power)
Yes, this mostly happens on most tv and dvd as their switches (called them Tact Switch Push Buttons) and in your tv control panel design is if one of only one button is internally shorting all keys are affected. I suggest to bring it to an electronic service center near you. Thanks for using Fixya.
Mar 22, 2014 | Televison & Video
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
Advent tv indoor antenna hook up
If the antenna has a cable like cable wire--hook it direct to the cable fitting on the set.
If the antenna uses the flat type wire (called 300 ohm twin wire) use an adapter that will connect to the end and have screws for the flat wires and a cable slide on the other side to slide onto the cable fitting on the rear of the TV
Mar 28, 2012 | Recoton Advent Advent DV1418A 14 in....
I have an Advent Television Model Q2035A and would like to know if I am going to need a converter box for it? I have an old timey antenna that rises above my house' roof. The wiring on it is spliced for...
Yes you will most certainly need a converter box. At Radioshack you should still be able to get the piece that you would attach the spliced wiring to.One side of the piece I'm talking about has a screw for each one of the Y shaped spliced ends to attach to. Sometimes there are two places to attach things and sometimes there are four so buy the one that best fits your needs. Then the other side of the piece has the male part that will attach to the female antenna in part on the converter box. Then a cable goes from one of the outs on the converter box to one of the ins on the television.
Jan 25, 2011 | Recoton Advent Advent Q2035A 20" TV
I have Advent LC-15Y26 LCD tv. Does it need a digital - analog converter?
I have one as well and it only tunes in analog (old over the air) t.v. signals. If you want to receive the digital signals, you will need an external tuner/converter box.
Jan 21, 2011 | Recoton Advent L2711A 27 in. LCD...
Advent ht3251a wont turn on
working on same model same symtons,pluged sys into a vareact tv came on normal,problem gone.set works ok when plug into ac outlet.can,t say what cause problem,set work ok now without veriact.will air test three days to see if probem returns.will try freez spay on chips.
Feb 20, 2009 | Recoton Advent Advent HT3251A TV
Advent q1435a
it is just adjustment problem on remote only. please check operating manual for the problem.no problem with tv.
Sep 29, 2007 | Televison & Video
Advent LC-20H15A 20 in. EDTV-Ready LCD TV Logo
247 people viewed this question
Top Advent Televison & Video Experts
Marvin
Marvin
Are you an Advent Televison and Video Expert? Answer questions, earn points and help others
