Question about Intel Cpu Pentium Dual-Core E2180 2.0Ghz Fsb800Mhz 1M Lga775 Tray
NO SIGNAL ON SCREEN CHANGED GRAPHIC CARD. FSB800
NO SIGNAL ON SCREEN CHANGED GRAPHIC CARD. FSB800 MOTHERBOARD
Hi
I sugges u that u have to reinstall all driver and mantion that chipset driver should be first u definetly solve your problem
bye take care
-Vinesh Motivaras (MCSA)
Posted on Sep 29, 2010
Why no signal in the monitor and just keep on beeping when I on the power?
It is either unplugged , from the computer or the video card is loose in it's slot.
If not these the video card may have gone bad.
www.computerhope.com/beep.htm
Jun 29, 2014 | EliteGroup ECS 661FX-M P4 FSB800 DDR400...
Why some graphic motherboard in Graphic card port disply came but in normal display not came
Difficult to understand your question.
If an external monitor works then the problem is Cheapest to most expensive:
MB to Power inverter cable is bad (No light to board) to check shine a flash light at you screen if still black not this
Power inverter is bad
Cable from Motherboard to Laptop screen is bad flashing on wiggle test will show flickering image
Display panel on laptop is bad if this is the case replace the Display cable/ Inverter power cable/LCD
this may still not solve the problem if you are not sure take to a local repair shop
Mar 30, 2013 | AMD 486542-001 - HP Pavilion DV7 Series...
Video drivers problems
Hello the driver is available here:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=530&DetailName=Feature&MenuID=24&LanID=0
Select download and vga and click on the link for download.
Here is only drivers for windows xp so if you run another system add a graphic card on the mainboard suppoting your windows.
Good luck
Jan 04, 2013 | EliteGroup ECS P4M800-M Socket...
Loss of graphic signal
If there is a problem with the internals graphics "card", that may cause an externally installed card not to perform. In the BIOS of some machines there is an entry under the peripherals that states something along the lines of "Initiate graphics first", then allows you to select ONBOARD or PCI. If you have this, try setting it to PCI and checking again with the card in the express slot.
Jan 06, 2012 | EliteGroup ECS A740GM-M Motherboard -...
Can I use 16:9 resolution on my onboard VGA _ ECS P4M800 M V 1.0 ? Thanks
Hi, you can try to upgrade the driver from here:
Or you maybe have to look for a better graphic card.
Its a AGP 8X/4X card It has to be in the yellow slot on the mainboard.
Hope this was helpfull.
Aug 18, 2011 | EliteGroup ECS P4M800-M Socket...
Ok, I changed my video card ( hp: p6230f) I still have no signal in your opinion would you go with monitor failure or motherboard? I have also checked all connections. Soon as I turn it on it scans reads...
1.If your display come during start up windows then its problem with graphic settings.
2.check moniter with another pc if its work on that pc then its your card problem.
In the case of 1 you have to go in safe mode and change the graphic setting.you have to change frequency hertz from advance setting to 60hz or 75hz which is mostly compatible with all moniters.And restart pc.you also check display driver correctly installed.
in the case of 2 problem change card or connec it with built in vga card and check your graphic card with another pc.you should find what is problematic by follow these steps.
Jul 13, 2011 | Computers & Internet
256 MB Nvidia GeForce Go 7800 for Inspiron 9400/E1705 Card Failu
Both solutions are wrong. The Dell Inspiron 9400/1705 is a laptop. If you buy a Nvidia GeForce Go 7800 for this laptop, you need to buy a Dell Inspiron 9400/E1705 motherboard for a discrete video card. The integrated video is a Intel Graphics Media Accelerator 950. The integrated video has the video chipset on the motherboard and the discrete video (GeForce Go 7800) has the video chipset on the video card.
Jul 09, 2009 | Dell nVIDIA GeForce Go 7800 GTX, (256 MB)...
NO DISPLAY M2NE MOTHERBOARD
It's probably your pci-e slot of the motherboard problem. Try using different motherboard.
Sep 21, 2008 | ASUS (M2NGREEN) Motherboard
Lost internet connection - after installing graphic card
If this is the power problem then change your SMPS with more Wats power.
Jun 09, 2008 | VIA P4MA Motherboard
Intel Cpu Pentium Dual-Core E2180 2.0Ghz Fsb800Mhz 1M Lga775 Tray  Logo
88 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
