Question about ViewSonic Computers & Internet
I have a View Sonic VP201s monitor that suddenly is black on the left 1/2 of the screen. Any suggestions? Can you suggest a repair shop near Seattle WA? I assume the repair $ may be prohibitively high. Right?
    Brigadier General:
  • 7,191 Answers
You can locate a repair shop near your location from the FixYa Repair Service directory by clicking this link.
Kindly call the phone numbers in the list which opens to get an estimate of the repair cost.
Thanks for using FixYa
Posted on Aug 02, 2010
Samsung syncmaster 912T disply will disapear. moniter still on just not getting info from cpu. after it is on for and hour somtimes it will not show display
Your description suggests the fault is with the screen, not the system. Can you you test that by connecting both screens to a buddy's computer?
When first powers up display is fine suggests a bad solder joint, revealing itself after heating up.
Oct 27, 2017 | Samsung SyncMaster 912T (Black)
ViewSonic VX1935wm Monitor says out of range
The problem is in the power supply inverter board, usually caused by bad capacitors, suggest a professional.
Mar 10, 2012 | ViewSonic VX1935wm LCD Monitor
PROBLEM IS VIEW SONIC MONITOR WERE OSD LOCK
osd lock is on screen configuration menu (on screen display) to clear an osd lock in your view sonic you can try this step
1.disconnect power cord
2.press and hold button 1
3.plug again your power cord
4. press your power button while still holding button 1
hope it help you
May 12, 2011 | ViewSonic E70f 17" CRT Monitor
Problem in viewsonic VA1716w Sir, firstly my left side of screen got little darkish(right side was more brighter) after that all of a sudden picture disappeared. Whenever screen switch is tuned OFF...
Sounds like a hardware failure inside your monitor.
If it's still under warranty I would suggest you return your monitor for a new one. If it's not, then I would recommend looking for a local repair shop to repair it or try to purchase a new or used monitor to replace it.
Mar 25, 2011 | ViewSonic VA1716w Monitor
Its a Panasonic DMC-TZ3. all on a sudden, LCD is not working. Monitors remains dark when I press 'On' button and the photo taken are also dark. However old photos on the SD card I can in the screen...
Hello
If you can view the pictures previously taken with the camera on the camera LCD, but the new photos just come out black, this is most probably a blown ccd.
This is a expensive component to replace, and you will also need specialized equipment to do this yourself.
I would suggest that you take your camera to your nearest repair shop and let them test the ccd.
Hope this can be of help.
Kind regards
Andrea
Aug 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
My Viewsonic VP201s monitor is hooked up as a second monitor off my laptop. I can no longer view anything on it. It appears to be flickering at a high speed. However the laptop screen is fine. It seemed to...
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
May 05, 2010 | ViewSonic VP201s 20.1" LCD Monitor
Screen went black
Swap monitor connections to determine if one of the monitors is not working.
If one is not working you probably have an internal problem. If power led responds to the off-on button but no picture is seen, the inverter has likely blown a fuse. Replace the fuse and resolder the leads on all 6 inverter transformers or the fuse might blow again.
Monitor Mike
Mar 27, 2009 | ViewSonic VP201s 20.1" LCD Monitor
Sound on the View Sonic Monitor
Yes, they are on the front of the screen. There should be a volume up and down button right on the front (usually to the left of the power). If there isn't a separate up and down, try the Menu or 1 and 2 buttons.
Aug 18, 2008 | ViewSonic 19.0" VG910B 1280X1024 TFT LCD...
Computers & Internet Logo
27 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
