Question about Freezers
Hi, I recently purchased a secound hand Beko glacier model CG964 , I believe its about 2 years old. Anyway , its a frige freezer and it works fine but with the fridge section what appears to be happening is that ice is forming about 1 inch thick over a period of a month at the back of the inside of the fridge. Why is this happening? Thanks in Advance.
    Sergeant:
  • 250 Answers
Http://www.appliancepartspros.com/repair-help/
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Jan 02, 2018
dididsaythat
  • 291 Answers
SOURCE: LG Fridge freezer Ice formation
below the evaputator coils should be some type of pan or drain system ... the drain most of the time is in the middle of the pan... it you see anything with ice defost should be NO ice in there .. can use hair dryer once defrosted u should look for some type of drain whole.. once u think u got drain open pour small amount of hot water down to help clean and test if drain is open
Posted on Sep 03, 2007
fixitallguy
  • 11 Answers
SOURCE: layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
Posted on Jan 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Posted on Mar 27, 2009
  • 323 Answers
SOURCE: Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Posted on May 12, 2009
SOURCE: BEKO AB910 Frost Free Fridge/Freezer Ice build up
I have the same model + problem. You should not need to defrost this model manually if it's working correctly, but the ice build up you describe is probably due to a blocked pipe in the auto-defrost system at the back. You need to defrost properly to prevent recurrence.
Behind the upper freezer drawer there's an aluminium tray behind a plastic grille. Every few days this tray warms up to melt any accumulated ice behind this plastic grille (full height of the freezer). A pipe should take the meltwater down to a plastic tray below (pipe + plastic tray are visible if you take the lower panel off the back). Your problem is too much ice blocking that pipe: the heater can't cope and it doesn't melt, so the ice 'cascades' down the back behind the bottom drawer.
When you manually defrost, you must ensure that this pipe is clear, otherwise the auto-defrost won't work, and you may have to defrost manually again within days.
I have found that the best way to defrost the pipe is to remove the lower back panel, disconnect the corrugated flexible plastic pipe from the stub that comes from the bottom of the freezer, + pump steam into the stub (gently) using a hand-held steamer (with tube + nozzle). You don't have to empty the freezer or move your food as the door stays closed, and no steam gets into the freezer until the pipe is unblocked. Be sure to unplug the freezer before taking the back off! [There is a fan in this area that could start up without warning]
Check how much of the pipe is blocked by gentle probing with a pencil: the aluminium tray is about 105mm above the bottom of the stub. This measurement is important…
When the pipe is clear, there may still be too much ice in the aluminium tray above (not sure how much is 'too much') if you only created a narrow 'chimney' though the block of ice (likely to get blocked again). You need to widen that chimney by melting more of the ice in the aluminium tray. I use a simple steam nozzle made from an old-fashioned Bic pen with a couple of 1mm holes drilled just below the coloured bung at the end. This directs steam onto the walls of the 'chimney' rather than upwards.
There's no point steaming the walls of the plastic 'stub' pipe, so only use the home-made nozzle when your probe reaches 105mm (i.e. when you have melted all the ice in the plastic stub tube but before your 'chimney' has broken through the block of ice in the aluminium tray). If you judge this right, you'll melt almost all of the ice under a still-frozen top surface: no steam will get into the freezer and your food will stay frozen. With a probe it will be clear when you've broken through the top surface of the ice. When you have done so, it's time to look inside the freezer to see how well you have cleared the aluminium tray.
It's perfectly feasible to get all this done in 30 minutes.
Don't forget to replace the corrugated plastic pipe + valve at the bottom. It stops humid air from going into the freezer and icing up in exactly the area we've just been defrosting.
Take a lot of care with steam jets as they can burn you badly. You should check a first aid website so you know what to do BEFORE it happens.
Some of these tips may be helpful: (1) run the freezer at -18 degrees (the 'warmest' setting) so it's not working so hard. (2) Leave a big gap (>100mm) between the back of the freezer and the wall. (3) Clean the matrix of delicate tubes to the left of the fan whilst you have the back off [a small bottle brush is ideal; remove the fan for better access]. (4) Put something between the middle of the freezer and the wall to prevent the warm air that's being blown out behind the fridge from being sucked into the air intake behind the freezer (there is a baffle built in underneath, but nothing behind. (5) Mount the fan on spacers (with longer screws) so that it's closer to the heat exchanger… this means that a larger area of grille can act as an air intake. (6) Raise the unit off the floor a little to free up the air intake path beneath the freezer.
Posted on May 10, 2010
I recently bought a norfrost chest freezer model c6aew,the freezer did not come with a manual or guide.i switched on the freezer set the dial to seven waited 24hrs and put some food into the freezer to...
Can't help I'm afraid, but we have exactly the same problem with exactly the same model. Ours did work for nearly 2 years, but recently only works with the boost button pressed in. I suspect the thermostat is not working as the boost button over-rides the thermostat to give max cooling. Your freezer is new so get it exchanged; it certainly doesn't need to be full to work!
May 29, 2010 | Freezers
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Thick ice build up behind freezer fan
check door rubber,if is oblate heat it with fan,if it is ragged change it.
Jun 29, 2009 | Freezers
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Freezer quit working
I suspect when you lifted or moved the freezer, you tilted the compressor such that the oil washed out into the refrigeration lines. Common when people tilt refrigeration equipment the wrong way.
Jan 30, 2009 | Freezers
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Not Freezing
Check the door seal all the way around. We purchased one recently that was slightly dented (not noticeably and the seal was not tight.) You need to get in touch with whomever you purchased it from immediately so that it can be repaired or replaced.
Aug 18, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Upright freezer
sounds like your freezer isn't maintaining a constant (cold) temp. A variation from cold to warm would cause your problems. Normal opening the door and looking for the ice cream over and over would cause a gradual increase in glacier activity in the freezer. I don't know of any quick easy fix-but wait, how about checking the door gasket? Get a piece of paper, close the door on it, move the paper all around the door, testing to see if you can pull it out easily (bad gasket), or does the paper not want to come out?(good gasket) If the gasket seems ok, it may be time to retire the global ice cream warming freezer countrycurt0
Aug 04, 2008 | Freezers
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Freezers Logo
199 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
