Problems printing cd's and dvd's - Office Equipment & Supplies
  • damjikoria Apr 06, 2009
    Everytime CD or DVD is inserted, it is rejected with error: Not alligned- Re-insert. I have tried several times but no chance.
I want driver for printer LBP 1120 laser
Posted on Apr 25, 2008
  • waleed5559 Apr 25, 2008
    i want driver for printer LBP 1120 laser
Xp-800 cd/dvd printing
The tray is for the DVD or CD itself, not for a label. The printer prints directly on the CD or DVD, you must use ink jet compatible blank disks, the white ones with no printing. You don't need a tray to print the label.
Oct 14, 2014 | Epson Expression Premium XP-800...
Not able to print directly on CD/DVD
Printing Directly onto a CD or DVD in Roxio Express Labeler
  1. Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
  2. Click Start , click All Programs , click Roxio , and then click Roxio Express Labeler v3 .
  3. Click Disk Label , then click Options . Figure 1: Options c01452912.gif 1 - Options button
  4. The Options screen appears. Figure 2: Options screen c01452913.gif
  5. Make sure that LightScribe 12cm Disc is selected from the Disc Label menu, then click OK to return to the Roxio Express Labeler window.
  6. Click Disc Titles , type the title and subtitle for the CD or DVD, and then click OK . Figure 3: Disc Title option c01452914.jpg 1 - Disc Titles button Figure 4: Edit Disc Title screen c01452915.gif
  7. Click Background , then click Import Background to use an image on the computer as the background on the CD or DVD. Click OK to return to the Roxio Express Labeler window. Figure 5: Background option c01452916.jpg 1 - Background button
  8. Insert a LightScribe CD or DVD into the LightScribe drive of the product. Make sure that the label side of the disc is facing down.
  9. In the Roxio Express Labeler window, click Print . The LightScribe label is printed on the CD or DVD. Figure 6: Print c01452917.jpg 1 - Print button
Jun 18, 2009 | HP Office Equipment & Supplies
How to print on CD/DVD's
Printers will not print on DC/DVD's. They will print on CD/DVD labels that then have to be glued on the CD/DVD.
The only device that will print on a CD is a lightscribe CD or DVD recorder--a CD drive that is made to do that.
Jan 29, 2009 | Epson RX595 Photo All-In-One Printer
I have a HP Printer C5500 When I try printing something on the CD/DVD Directly I get a Error saying that the printer doesn't support printing directly on the CD while the Printer is meant to print on...
I'm confused.. Are you trying to print to a CD/DVD Drive? Try the print job again, and choose the C5500 as the print device.. Seems that there may be a problem with the print device set-up , and you may have to delete the printer, and reinstall it.
If the printer is designed to print a label on a CD / DVD. then you will have to use the programs provided to accomplish this, as it requires formatting parameters be sent along with the print request. I.E. You can not cut and paste directly to a CD / DVD printer..
Nov 19, 2008 | HP Office Equipment & Supplies
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson r230
hello babu,
the problem is not with the printer, problem is with your general knowledge, to print on cd/dvd surface means you have to stick the sticker (cd label sticker) on the cd, then put the cd on the printer to print.
ok
bye bye
hope u will soon understand......
Jun 22, 2008 | Epson Stylus Photo R220 InkJet Printer
Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
May 24, 2008 | Epson Stylus Photo R320 InkJet Printer
Is there any way I can burn an image onto a printable cd/dvd using a burner either through my printer or directly from the burner?
1) buy a printer with cd/dvd print tray - like canon 4500, it prints on printable dvd only (printable dvd's have a special white coat to absorb the ink).
2) buy a dvd burner that supports lightscribe like asus drw-1814bl (it prints black only on special coated "lightscribe dvd's"
3) NOT RECOMENDED but also possible, buy cd/dvd labels print on any printer and adhere to cd/dvd, usually over time the glue will destroy cd's and trapped air will make bubbles when the cd/dvd is hot (air expands in hot environment).
Shapirit Computers
050-2330137
www.shapirit.biz
May 04, 2008 | Office Equipment & Supplies
Printing directly on a cd or dvd
You should clean the white printed marks on the CD caddy. the "magic eye" relies on these marks to accurately assess where the CD is.
If it still struggles after cleaning the white alignment marks, clean the exit rollers with something like windowlene/windex to ensure they have sufficient grip.
Jun 13, 2006 | Epson Stylus Photo R200 InkJet Printer
543 people viewed this question
jasbo
jasbo
