Question about MTX TN2501 Car Audio Amplifier
Amp blow the fuse when power is connected.do you know why it does that and could it be fix
  • 70 Answers
Could be a bad or floating ground if not then it is inside of the amp
Posted on Aug 03, 2010
Amp keeps blowing fuses
Blowing fuses, was caused by many thing.
Short of rectifier,resistor,elco,tube heater,tube pin, and also trafo itself (primary or secondary winding). It must check step by step.
CAUTION :
THIS IS HIGH VOLTAGE AREA.
RISK OF ELECTRIC SHOCK THAT CAN KILL.
DON'T DO THIS IF YOU ARE NOT TECHNICIAN OR NOT FAMILIAR WITH VACUM TUBE CIRCUIT. THE CIRCUIT MAY STILL CONTAINS ELECTRIC SHOCK EVEN IF IF THE AMP IS NOT POWER PLUGGED.
The simple steps (see picture) are:
  1. Disconnect all connection from secondary of power trafo (PLV,PDCH,PACH and PHV).
    Power ON the amp. If fuse is not blowing,trafo is good.
  2. Power OFF the amp. Unplug the cord.
    Connect PLV1-PLV2-PLV3 (this are Bias voltage,+/-15VDC and Backlight PCB voltage) to power trafo.Power ON the amp. If fuse is not blowing,PLV circuit is good.If fuse blowing,there are parts is damage (dioda,elco,7815/7915,resistor) in this PLV circuit.
  3. If step 2 is good,go to next step.
    With PLV circuit stay connected,connect PDCH 1-2 and PACH 1-2 to power trafo. Power ON the amp.
    If fuse is not blowing,PDCH and PACH circuit is good and all tubes heater/filaments are lights after a few seconds.
    If fuse blowing,there are parts is damage (dioda,elco,tube heater pins) in this PDCH/PACH circuit.
  4. If step 3 is good,go to next step.
    With PLV,PDCH,PACH circuit stay connected,connect PHV 1-2 to power trafo.
    Power ON the amp. CAUTION: HIGH VOLTAGE AREA is ON.
    If fuse is not blowing,PHV circuit is good.
    If fuse blowing,there are parts is damage (dioda,elco,tube pins) in this PHV circuit.
Notes:
  • Steps had to be done sequentially from 1 to 4, not upside down.
  • If tube/heater pin is short,it can't be repair. The tube must be replacing.
  • PDCH circuit is voltage for V1-2-3-4 heater/filaments.
  • PACH circuit is voltage for V5-6-7 heater/filaments.
  • Always replace fuse with same type.
Oct 02, 2015 | Peavey 6505 Plus 120W Guitar Amp Head
SHORT CIRCUIT
The question is not very clear, but I assume that you blow the main fuse when you connect the amplifier to the battery.
First make sure that you have the correct fuse rating (amperage) installed. Then try connecting the power to the amp with the speakers disconnected. If the fuse still blows, you have shorted output transistors in the amp. This could be expensive to repair. If the fuse does not blow, your speakers could be short circuit as well. It is very possible that both the amp and the speakers are shorted.
Sep 07, 2017 | Lightning Audio B4.250.2 Car Amp
The garget blows the fuse and goes off
if the fuse blowes when you swtich the power on its the power supply circuit. if the fuse blown after a short while that the Amp is on its possible that protection circuit is short
if you want to fix the Amp let me know
ecrdn@yahoo.com
Jack
Oct 15, 2010 | Yamaha P-5000 Amplifier
Amp blows fuses
Are you using the correct fuse? if so,
more then likely, you don't have a good ground. Try grounding to something else that has more direct connection to your frame. If that doesnt work, try getting larger power cables.
I had the same problem with my 2500w xplodes all I had to do was get a thicker cable for the ground and battery connection. What was happening, was it was needing more power then the wire and fuse could handle, so it would blow the fuse, since the higher you have it, the more power it needs to feed the watts.
I would try grounding it directly to the frame on a good part of the frame before spending another $70 on new power cables though.
Mar 09, 2010 | Car Audio & Video
Fuse blowing on start up on Behringer PMH 518M
Try running the amp with no speaker cables connected. If it doesn't blow the fuse you know it's either your Speakon cables or the speakers themselves that are to blame (it's usually the cables)
If it still blows then there is a more serious problem with the power section.
Jan 19, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Amp grounding out
If the amp is blowing fuses, you could have one of several problems. The only one of those problems you could fix yourself is if you have a shorted speaker. A speaker that is shorted in the voice coil can cause the fuse to blow. To check if this is causing it, dis-connect the speakers and then turn it back on. If no fuse blows there is a good chance that a speaker is shorted, take the speakers to somebody or someplace that can check them properly. If the fuse still blows with no speakers connected, you have an internal problem in the amplifier.
If the fuse blows before you even turn the amp on, you have some shorted components in the power supply. If the fuse blows after the amp gets turned on, you have some shorted components in one or both of the output channels.
Unless you have some experience with electronics and have the proper tools to troubleshoot electronics, there is really nothing you can do yourself to fix the amp if it has internal problems.
You should take it to a repair center and get an estimate for repairing it, that way you can decide if the cost of the repair is worth the price of the repair. Sometimes it is better to just buy a new amp, but you first need to know what it will cost for repairing it. There is no way to tell you how much it will cost to repair without having the amplifier in front of me and troubleshooting it to see exactly what is wrong.
If I can be more help let me know, I have been repairing car and home audio equipment for almost 18 years and can offer you good honest advice.
Good luck,
Dave
Jul 27, 2008 | Car Audio & Video
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
Apr 07, 2008 | NAD C350 2-Channel Amplifier
Blowing fuses
Here are some answers:
1. Make sure your amp does not have a higher amp rating then the fuse, For example, an 18 amp amplifier will blow an 15 amp fuse, so connect it to a 20 amp fuse
2. you have a connection issue, where something is shorting out
3. you are pushing the amp or car to it's limit with how loud you put it, and thus blowing it, fixed by getting a more powerful amp and a better fuse.
4. or there is something very wrong and cannot help you and you would have to bring it into a shop.
Nov 18, 2007 | Car Audio & Video
Beer Spilled on my Power Acoustik PS2-820 Amp
Hi , now that you have the amp apart , just check the underside of the printed circuit board and check for any corrosion ,rub it with a soft brush . then try connecting without speakers . see if it still blows fuse, if it does then there is a likelihood that your mosfets / outputs may have shorted the first time you reconnected it . Good luck
Mar 21, 2007 | Power Acoustik PS2-820 Car Audio Amplifier
Blown fuses
I used to have one of those amps also (nice amp btw) Did you try another fuse of the same size?
Is it blowing fuses everytime you put one in or did it just blow that one fuse ?
Is the conection on the battery solid and clean of corrosion build up? Because that is a good amp and if wired properly shouldnt blow out or anything and so if the speaker is not blown then maybe connection is weak somewhere? I would try disconnecting the speakers from it and try a new fuse and if it does not blow the new fuse than amp is ok? and if it does blow the new fuse right away then there must be a short somewhere in the wire or the amp. then disconnect the fuse again and reconnect the speakers and if the fuse blows with the speakers connected but doesnt blow with them disconnected then you know it is a blown speaker causing the problem.
Just currious but what size fuse do you have connected at the battery?
Jan 06, 2007 | Rockford Fosgate Punch P4004 Car Audio...
MTX TN2501 Car Audio Amplifier Logo
20 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
