Question about Car Audio & Video
HOW TO LOCATE A PLACE TO PUT GEAR-BOX OIL IN TOYOTA PREVIA CAR
    Brigadier General:
  • 3,301 Answers
Side of the tranny ,, a bolt,, heres a hint for filling, get some tubing and slice it to fit in the hole, and fill from above slowly,, (clear tubing is best for obvious reasons
Posted on Aug 02, 2010
Wheres the radiator and fuse box?
what radiator, there are many.
cab heater, engine RAD, tranny, A/C what?
the glove box, open it and remove the oper. guide, lost that , get one for best safety.
fuse box, there are 2, one (LHD car) at left ankle
and one in engine bay. LHD = left hand drive,
even causal looking finds both, do look.
best, violet, is to post symptoms... or are you just curious?
the crummy haynes
http://www.ebay.com/itm/Haynes-Toyota-Previa-1991-1995-Auto-Repair-Manual-/380500687864?pt=US_Texbook_Education&hash=item58979bbbf8
the book lost, oper guide
i use fleabay, put a watch on this search, then wait from one to pop up.....
http://www.ebay.com/sch/i.html?_odkw=Toyota+Previa+operators+guide+1995&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.XToyota+Previa++manual+1995&_nkw=Toyota+Previa++manual+1995&_sacat=0
Dec 19, 2013 | 1995 Toyota Previa
Where is the engine oil stick?
The Toyota Previa is a popular car that holds its value well. It is a rare "mid-engine" car which presents some unique problems when doing basic maintenance like checking the oil. Go here for step buy step instructions:
http://www.ehow.com/how_4540025_check-oil-toyota-previa.html#ixzz1H5JrQBL3
Mar 19, 2011 | 1991 Toyota Previa
Oil is driping from gear box only a little bit but warning lite is coming on when iam driving it .plus tried looking for bolt to beable to fill gear box fluild up
gearbox filler port is usually on the side of the trans about half way up. It only gets filled up to that point. The fitting looks like a plug and takes a 3/8 or 1/2 inch ratchet to open.
Sep 02, 2010 | 1991 Toyota Previa
I have a toyota previa 1991 model I would like to know where the dlc connector is located
if you mean "code reader plug" (sorry not much of a car guy, just know what MY '91 has taught me) is under the drivers seat. there is a lever to lean the seat (whole seat, not just back) back. this is where you add oil, check oil and trans fluid. the code reader plug is the grey box thingy nearest the door.
Hope that helped
Jun 18, 2010 | 1991 Toyota Previa
Gear problem toyota previa 96 ???? its a manuel gear and its have somtimes trobble to get in 2 gear ??? Dos it needs oil or what ????
Get the clutch checked, if that's ok, it's transmission time. The synchronizers are shot if the clutch is ok 7 it still gives a problem.
May 15, 2010 | 1996 Toyota Previa
My 1996 Toyota Previa shimmeys when it is stopped;when
check the tick over speed if its slow, less than 850 950 rpm in gear that why it shimmeys,, the engine is trying to stall in gear,,,if you need to bring up the tick over speed have some body in the car holding the brakes down for you as it needs to be ajusted with the car in gear,,and running yourself over hurts??? the car should just creep forwards with the engine runing in gear with the brake off,,,tickover speed of 950rpm
Mar 07, 2010 | 1996 Toyota Previa
Where is a indicator relay on a 1993 toyota lucida
All relays are located under the hood of your car in the fuse boxs for your car that is were your relays are at.
Sep 12, 2009 | 1993 Toyota Previa
Toyota previa 1991
the oil should be black,brown or gold(new) with no other colors in it. shouldnt be milky or streaky. the trans fluid should be light red or semi light red.as for the engine being oily its hard to discern unless you rinse it off to metal and drive it. if you mean the oil pan has black oil on it then it may be ok.
Mar 26, 2009 | 1991 Toyota Previa
How much transmission fluid(oil) should a 1993 2.4 auto toyota previa gx hold in the gear box and cooling system in total !
There is always a guage there. Fill and use the guage to determine wat amount but do not exceed the guage line.
Don't forget to rate this fixya!
Mar 24, 2009 | 1993 Toyota Previa
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
