Question about HP CP3525N Color LaserJet Printer
I am getting a black stripe down the middle of the page. How do I fix this?
  • 4,281 Answers
Turn off the printer.Pull toner cartridge from it then reconnect .Try with another cartridge then check. If still same issue then you need to do some servicing on fuser unit. For that open back cover of printer then you can find fuser unit open it from printer then open all parts of fuser unit like roller and other parts make sure roller is find and there is not any small paper pices.Clean sensor then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 02, 2010
  • 857 Answers
The source of that type problem is actually rather limited.
1. Open the printer an look around cleaning anything that is dirty. (Do not clean toner drum or fuser rollers as that will create a problem.)
2. Fuser could be the source however I'd consider that as the last candidate.
3. The most likely source is a/the refurbished Toner Cartridge. This can be checked by removing the toner cartridge and looking at the drum if the stripe is apparent. (DO NOT CLEAN as that will create or worsen the problem.) Another way to confirm the problem is to do a Half Page Test. Let the printer print a page and after the toner is on the paper yet before the page goes through the fuser, open the door stopping the print process. Remove the paper and see if the stripe is visible. If their, Toner Problem but if not, Fuser Problem.
4 Suggested Answers
SOURCE: Printer prints dark middle stripe on every page?
remove the cartidge and replace with a new one,
clean the rubber roller and check all drivers are installed correctly or that you have the most uptodate versions.
if this doesnt help solve it, you could invest in a printer repair kit specified for your printer usually found in p.c shops..
if all else fails call up the company.
Posted on Oct 30, 2008
  • 990 Answers
SOURCE: Black stripe down middle of page when copying
open the top cover on the left hand side glass plateform with a narrow piece glass clean it with alcohol.
Posted on Dec 13, 2008
  • 116 Answers
SOURCE: Black line down middle of page
Clean the inside of the printer with a soft rag, be gentle and get as much toner up as you can, also your toner carttridge may be empty or the crum may be bad, start with a fresh toner carttridge and clean the printer out where the cartridge sits.
Stripe down the middle of printed page
replace the transfer belt? and or color image units
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 31, 2014 | Konica Minolta magicolor 4650DN Laser...
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
There is black 1" stripe down middle of page. I
The drum is defective, and leaking, Brother warranties if you are original purchaser (in canada, www.brother.ca)
Dec 10, 2010 | Brother HL-2070N Laser Printer
Black Stripe on outgoing faxes
If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Black stripe in middle of copies 1/2'' thick whole page
Most likely it is a bad drum cleaning blade. It will need to be replaced. This machine is old...good luck.
Jun 25, 2009 | Kyocera Mita Office Equipment & Supplies
Black stripe and white stripe on copies
Black stripes can be down to dirty optics, unplug the copier and remove the glass, then clean all mirrors and the glass itself. If this does not resolve the problem, it will be the drum cleaning blade that has worn and will nedd replaceing.
Feb 16, 2009 | Sharp AL 1631 Copier
Dec 13, 2008 | Brother MFC-7820N Printer
Oct 22, 2007 | NEC SuperScript 1400 Laser Printer
HP CP3525N Color LaserJet Printer Logo
137 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
