Question about Generac 13,000 Watt / 13,000 Watt Home Standby Generator
DO YOU RCOMMEND A TIME LIMIT FOR THE GENERATOR TO RUN IN CASE OF POWER OUTAGE ??
  • 843 Answers
If the generator is installed correctly and it is running within it's continuous rated capacity, it can run indefinitely. The main thing is operating temperature. Just like a car engine, once it comes up to normal operating temperature it's cooling system should be able to keep it from overheating. But unlike a car, where the manufacturer has complete control over the installation, a standby generator could possibly be installed in a way that inhibits proper cooling. However, this is very unlikely if the unit was professionally installed. And even if it did overheat, the unit should be able to trip it's own breakers or shut itself down anyway. The only other consideration is fuel consumption. A standby generator is not an economical way to get your electricity. If it runs for several days or weeks you are going to notice the fuel bill. I hope you found this helpful.
Posted on Aug 02, 2010
Electric company shut off electric to my neighbor -can he run a generator for electric legally?
This depends on where you live and Local Regulations... But yes it is possible to run a House from a Generator...
I have a generator on Standby for Electricity Outages... I am on Oxygen full time so Need my Electricity to remain ON all the time... You probably need to get a special Lead to go from the generator to somewhere that will supply it to the House.... I have my Generator hooked in Permanently by an Electrician
Jan 04, 2017 | Green Living
I have a coleman heater (central heating/A/C) Excel energy had a 2 hour power outage this morning unplanned and now I am trying to reset the thermostat so the heater will come back on) I had to reset the...
Hello, You may have this already solved by now but here goes. If your unit was running at the time of the power outage, you may have a limit switch kicked. This would cause your main blower to run non-stop with no heat. Gas furnaces has a main limit mounted on the wall of the heat chamber. This one should reset automatic when it cools down. Then you have a limit (maniual) reset on the blower casing. This is a small round device with two small wires coming off of it that goes toward the main board. If you can find this limit switch it will have a small button in between the two wires where they attach. Push in this button, if it clicks it should light the flame.There may be another limit on the burner casing. Try pushing this one also. When the power goes out when the flames are on this will build a lot of heat up near the blower causing this limit to kick off. Hope this helps.
Feb 03, 2011 | Coleman Propane Forced Air Heater...
Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Feb 26, 2010 | Honda 6370C - Parallel Power Kit For ...
Same problem, generator kicked in after power outage,
At the point the transfer switchis suppose to transfer put a dc volt meter across terminals 23 and 194 in the transfer if you do not show 12VDC. Then you have a relay hanging upon the PCB board in the generator, need to replace board. If you are showing 12VDC and the switch is not transferring the problem is in the switch itself.
Sep 08, 2009 | Generac Guardian 100 Amp Transfer Switch...
I,m wiring an outlet in the garage to plug my honda 3000 into , to power a few circuits in the house. How many amp circuit can I run with a Honda 3000? Thanks RJ
On your sump pump, there is something called a nameplate which lists model number, serial number, manufacturer, and power requirements. The power can either be listed in watts directly, or in amps (at 120v). Also click on this web page and You will be able to figure it out. http://www.donrowe.com/inverters/usage_chart.html Hope that answers Your question.
May 26, 2009 | Honda 3000 Watt Portable Generator
Generator won't start
Some of the generator has a control or tripping device like over speed, over voltage, overload or overcurrent or other trip device, try to find & reset it.
Mar 09, 2009 | Electrical Supplies
HAVE A TROY-BILT 8000 WATT THAT STILLS RUNS GOOD, BUT NO OUT PUT.
Visit this site http://www.perr.com/phpBB3/ and they can tell you how to flash your generator. Might I suggest you run the generator often and put it under load even if you're not depending on its power output at the time like you would in a power outage. Like use it to power a shopvac or similar device.
Mar 02, 2009 | Coleman Powermate Powermate 5000W...
Portable Generator doesnt generate any AC Current
is there a manual reset circuit breaker somewhere?
Dec 21, 2008 | Electronics - Others
Generac 13,000 Watt  / 13,000 Watt  Home Standby Generator Logo
237 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
