Question about TruTech LMD-5702RT Portable DVD Player
Trutech 7" mobile dvd player screen turns white.
  • 1 more comment
  • ddadosky Aug 02, 2010
    Trutech Lmd-5702rt Screen turns white. whats wrong with it and where do you find the parts if needed.
    trutech lmd-5702rt screen turns white.
    Whats the problem?
    Detailed instructions to fix it?
    Where do i get the parts quickly?
    Trutech lmd-5702rt portable dvd player screen turns white on the main unit
  • TruTech Master
  • 11,800 Answers
The screen has turned white because the video processor is frozen. The only thing you can do is a hard reset  - press the forward and back buttons on the case at the same time for more than 5 seconds. If nothing happens then the player is good for the skip, the processor has died.
Posted on Aug 02, 2010
  • Azrael SRL Aug 03, 2010
    You can't fix anything on this device: there's only the mechanism, the motherboard and a case and none of them are repairable - if defective they should be replaced. And you can't replace any of them since they don't sell parts since this is a disposable device.
    Sorry, just junk it and get a new one.
    President:
  • 2,559 Answers
This is due to a loose connector on the board to screen and would need to be disassembled to repair.
    Where is the connector? how do i fix it?
  • Randy Hough
    Randy Hough Aug 02, 2010
    When you open the unit it will be attatched from the main board to the display
  • TruTech Master
  • 6,993 Answers
the problem is either from the screen inverter or from the flex that connects the screen to the player's main board.
This is a common problem with this player. To confirm, connect the player to an external TV, and you will see that its going to display fine. Look by the side of the player, you should see a yellow hole (AV OUT), that's the part you will be connecting to the TV.
Therefore do necessary replacement (Screen inverter/flex) and the player will display normal again without the screen turning white.
Good luck.
  • 1 more comment
    Where do I get a screen converter flex?
  • Walesarumi
    Walesarumi Aug 02, 2010
    the screen inverter and screen flex are located inside the player. The inverter is a small board by the side or under the screen of the player.
    As for the flex, you will see a flex or a wire that connects the screen to the player's panel/board inside the player.
    Get a screw driver that will fit into the screws of the player, unscrew all screws, remove the player's cover in other to gain access to the internal part of the player where you will find the screen inverter and screen flex.
    Take care.
  • Walesarumi
    Parts can be found in any electronics accessories shop/store.
Trutech pvs12701 7" dvd player.
trutech pvs12701 portable dvd player Manual Free Download .pdf
Mar 09, 2011 | TruTech Televison & Video
My main screen Doesn't Turn On
There is a power switch on both units. The second screen will get power if the power switch is turned off on the main unit.
Apr 12, 2010 | TruTech LMD-5702RT Portable DVD Player
Low/No contrast on main screen
There should be a setup menu for "video" where the brightness and contrast can be adjusted.
Feb 10, 2010 | TruTech LMD-5702RT Portable DVD Player
I have a trutech LMD5702RT portable duel screen dvd player the cable is broke that goes in 2nd screen we get sound but no picture. Can I buy just that cable
If its the red white and blue AV cable on both ends yes you can. If its a red white and blue AV on one end and a audio looking jack on the other end you can too. They sell all those cords at Radio shack or most electronic stores.
Jan 09, 2010 | TruTech LMD-5702RT Portable DVD Player
Monitor #2 has sound, no picture
A/V cable is broke. I'm trying to find one also with little luck
Jun 16, 2009 | Televison & Video
Lost the cord
i SAW THEM ON EBAY. also there are broken systems or parts or replacement.
Feb 25, 2009 | TruTech PVS12701 Portable DVD Player
Trying to hook PS2 up
u cant play them on it its a dvd player
Dec 12, 2008 | TruTech PVS12701 Portable DVD Player
I have a mobile dvd system,but in the carwash lost my remote
Depende de que modelo es lo puede encontrar en www.ebay.com, alli tambien hay modelos que estan descompuestos y que los venden como partes para reparar otros, los puede buscar entrando a la pagina de ebay y en "search" (buscar) poner el modelo del aparato (com por ejemplo el mio es LMD-5702RT) y luego pone la palabra "parts" o tambien puede tratar "system broken". Yo estoy buscando el reemplazo de la segunda pantalla que no funciona bien, el servicio al cliente (1 800918 3720 -creo que solo hablan ingles-) de estos aparatos no ayuda mucho, pero tambien puede tratar. La pagin web de trutech es www.axiontv.com pero tambien puede entrar a www.shopaxion.com y puede enviar un mensaje por email a ellos para ver si les pueden vender un control remoto nuevo si es que no lo encuentra entre los que ofrecen.
Mucha suerte!
Nov 15, 2008 | TruTech PVS12701 Portable DVD Player
Playing dvd from UK region
hello onadzki
have a look here TruTech PVS12701 region code
this is all you need to do .
riz.
Mar 20, 2008 | TruTech PVS12701 Portable DVD Player
My dvd player turns on but...
must be a kink in the electrical wire therefore there is not enough electrical output to show images or make sounds but there is enough to charge your dvd player up :-|
Aug 03, 2007 | TruTech PVS12701 Portable DVD Player
TruTech LMD-5702RT Portable DVD Player Logo
70 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
