Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
Can the rubber gasket between the drum and door be removed for cleaning...it tends to become very moldy.
  • 171 Answers
It can be but don't reccomend it unless you have done it before such as a repairman.  i have found that cleaning it with bleach usually does the job.  you may want to also run about 1 cup of white vinegar through a hot water load by itself and that should alleviate any odors for the most part.  you can also by a product called washer magic at most stores.  made specifically for cleaning front loaders.
Posted on Aug 02, 2010
How to clean the mold of the rubber
If you have mold on the rubber gasket of your Duet front loader, I can almost assure you that you have lots of mold in other places in the machine. Front loading washing machine are almost hermetically sealed and if the door is left closed, the inside just never dries out. This is just a perfect environment for the growth of mold and other fungi. Once mold gets established in materials such as rubber gaskets, it can be very difficult if not impossible to eradicate because mold grows "roots" deep into the pores of the material, making it very difficult to remove. Eradicating the mold may result in damage to the gasket since my "cure" is to paint on full strength bleach on the moldy surfaces with a brush or sponge (wear gloves). Repeat if necessary. You may wind up having to replace the front door gasket to get all of it. It will probably take more than one application to fully eradicate the mold from the VISIBLE surfaces of the rubber gasket. If you remove the detergent dispenser and peer inside the opening, you may see a lot more mold inside the cavity. If you see mold inside the detergent dispenser cavity, imagine what the rest of the inside of your machine must look like. Do you run a periodic cleaning cycle as advised in the operating manual? Have you read the operating manual? Do you use the absolute minimum amount of HE (non foaming) detergent? Factory instructions for cleaning the door gasket call for mixing 3/4 cup of bleach into 1 gallon of warm water and applying this mixture to the affected gasket area, let stand 5 minutes and wipe the area down with a dry cloth. My experience has shown that this is a grossly inadequate concentration to deal with a deeply seated mold problem in the door gasket. To run the cleaning cycle, the factory calls for 2/3 cup of bleach to be added to the bleach dispenser. "Use of more than 2/3 cup of bleach will cause product damage OVER TIME". Initially, I would definitely consider using a whole lot more bleach than recommended and run two or more consecutive cleaning cycles. Then EVERY USE OF THE MACHINE: wipe the door gasket and all the creases and folds dry with a sponge, remove the detergent dispenser and wipe the cavity dry, leave the drawer out to dry on a clean towel, leave the door open, buy a cheapy plastic box fan and place it inside the machine and let it blow air around the inside of the machine for an hour or so to dry it off quickly, run a cleaning cycle at least once a month. If this sounds too involved or difficult, I would suggest switching to a top loading washer that is much less prone to develop mold growth as air can circulate in these types of machines to a much greater extent than the front loaders.
Sep 12, 2014 | Whirlpool duet Washing Machines
Replacing door gasket
Most door gaskets are available online, most recommended taking drum out to replace, but task can easily be done by removing rubber from hole in machine (end of a spoon helps) then push drum back through the hole and you will see a large clip on rubber to the drum, unscrew clip and pull out rubber, reverse to replace. Good luck.
Feb 19, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in clothes, especially towels
need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Mar 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The rubber gasket has gotten very moldy since it continually collects water. How do I clean the inside of the gasket to remove the mold?
Use a solution of bicarbinate of soda in water to remove the mould. If that does not work you can purchase a mould remover for bathroom tiles that will do a better job.
It is recommended to leave the door open when the machine is not in use so that any residual moisture will evaporate and you will not have this problem in the future.
Jan 22, 2011 | Miele W310 Front Load Washer
Moldy rubber door gasket
clean it with a water bleach mixture and make sure the door boot drain in the bottom of the boot isn't plugged with lint,soap,etc and can fully drain
Nov 18, 2010 | Maytag Washing Machines
Mold on rubber gasket
The door seal need to be pulled almost inside out to be a able to thoroughly clean it. I usually use a 50-50 mix of bleach water but other cleaning products like oxyclean may work better. After cleaning run a load with no clothes in it to remove any residue. Now if the mold has gotten deep into the rubber and still looks blackish after cleaning it will get moldy real soon and replacement will be the only solution. The key is from day one to leave the door open as you do and also wipe the door seal with a towel after each use. Not to defend frigidaire but most of the other brands have the same issues, some worse. If you need to replace the door seal or if the wire ring pops off when cleaning here is a link that should help http://appliancehelponline.com/washerdoorseal.html
Jul 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Moldy door gasket, smelly clothes
Mold growth is a common problem due to tight seals and poor drainage.
Pull back the rubber or plastic around the tub or basin to reveal the problem. You should also check your detergent dispenser as this is another common area for mold growth. Remove any visible mold. You can use a solution of water and dish detergent or bleach (1 part bleach to 10 parts water). You could also use bleach wipes to do this depending on how stubborn the mold is.
Because of the set-up of the washer, mold can also tend to grow in pipes, traps, and outside the drum where you can't see it.
You can run an empty load on the hottest water setting with 1 cup or more of bleach. Run an empty load on the hottest water setting with 1 cup or more of vinegar. Use a product designed to attack build-up from detergents and fabric softeners. Call a repair man to service the parts of the machine you can't see or attempt to do it yourself
However Mold needs moisture to grow. Leave your washer door and detergent dispenser cover open in between loads to allow for complete drying. This will dramatically decrease or eliminate the problem.
2. clean the machine monthly to stay away from the problem.
3. Switch to powder and/or low-sudsing detergent.
Let us know if you need further clarification else please accept the solution.
Thanks for contacting fixya.com
Mar 21, 2010 | LG Washing Machines
Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dirt marks on clothes from dirty rubber door gasket
Unfortunately you need to remove the front panel and change both drum slides to re-align drum again and keep it from damaging your clothes.
Aug 18, 2009 | Kenmore Washing Machines
Is there ANY way to remove the gasket from a frigidaire GLTF2940ES front load washer???? It is absolutely covered with mold, it is moldy underneath, my clothes smell disgusting!!! I want to clean...
yes there is way
How to remove and replace the drum gasket on the Frigidaire -Front Load Washer with notes on tub bearing replacement and inner drum replacement....
for all the detailed instructions
click the link directly
http://www.applianceaid.com/417_Frigidaire_washer.html
hope this helps
May 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
