Question about Brother HL-2040 Laser Printer
Brother hl-2040 printing problem
I have a Brother hl-2040 and it is printing small black dots on the right side of the page 3 inches apart?
  • 1 more comment
  • bgmaine Apr 27, 2008
    That indeed was exactly the problem. Thanks!
  • Matthew Altman
    Matthew Altman Aug 29, 2013
    I have those spots, replaced the drum unit, and they are still there. Help!
  • Anonymous Mar 27, 2014
    printing marks on the right side of the page
  • 62 Answers
Could be that there are a mark on the drum itself or some dirt, remove the drum unit and inspect the surface , by rotating the drum , becareful not to touch the drum as it will leave marks on the surface
Posted on Apr 25, 2008
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
Using Brother Printer HL-2040, not so many pages printed, but have some dot in pages about 3 black dots and some fade letters. what should i do to clean drum?
Remove the cartridge and look carefully at the rubber roller. You have debris stuck on the roller that needs to be removed. Get a cotton ball and dab some rubbing alcohol on it. Then run the cotton ball back and forth over the rubber roller making sure to use a clean section of the cotton ball each time. Now advance the rubber roller and repeat with a new alcohol cotton ball. Do this until you made it all the way around the rubber roller. Allow to dry for 10 minutes and then insert the cartridge back into the machine.
Nov 12, 2010 | Brother HL-2040 Laser Printer
Prints only blank pages
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 06, 2010 | Brother HL-2040 Laser Printer
Little dots on right side of margin (Brother HL-5040)
I would have guessed the trouble shooting steps you first performed. It could still be a bad imaging drum. Or a fuser. Not sure if this model has a replaceable fuser or not.
Jul 08, 2009 | Brother HL 5040 Laser Printer
Tiny dots about 1 inch apart down the side of page
Again, this was actually HP Laserjet 3800. Problem solved by chatting with HP, and them having me go into a diagnosis mode that disabled cartridge check. Then, I removed the cyan cartridge, the dots went away. They then had me put the black into the cyan slot, and not dots appeared. I had backup toner on hand, swapped in a new cyan and magenta, and all was good. HP agreed to replace the cartridges.
Jun 19, 2009 | Brother HL 2140 Laser Printer
Brother HL2040 PRINTING DOTS
1- change the drum unit
2- check the fuser unit
Sep 06, 2008 | Brother HL-2040 Laser Printer
Dark line down printed page
problem in your fuser assy call to hardware service provider
Feb 28, 2008 | Brother HL-2040 Laser Printer
Error printing on brother hl 2040 series
Check blue slidy thing on drum is in home position marked with a triangle.
Nov 30, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
543 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
