Question about Belling FarmHouse 932 Dual Fuel (Electric and Gas) Kitchen Range
Belling Farmhouse 911
Hi
I have one of the above cookers and the ignition seems to be sticking in the grill only i.e. it repetitively sparks when the mains switch is on. Also there is no gas feed to either oven when they are switched on. Otherwise everything works fine. Is this some kind of a safety feature? Do I need to change the ignition unit?
Thanks
Steve
  • stealfar May 08, 2008
    It turns out the timer is stuck on auto and this is why the ovens don't work. The timer part is obsolete now according to Belling.
    Is the timer fixable? Are there other timers that will work? I am not too happy about the prospect of throwing out a range cooker just because a timer is stuck!
    Any help much appreciated
    Thanks
    Steve
  • stealfar May 10, 2008
    OK I somehow (luckily) managed to get the timer back onto manual without having to take it apart and the ovens now come on however, as per the original problem, the ignition is still constantly sparking in the grill and the ovens.
    When an oven is lit the ignition still sparks. If I switch off the mains electricity switch to stop the constant sparking the flames die out in the oven....?!
    Any idea what's going on here and how I stop the continuous spark?
    Thanks
    Steve
  • 3,037 Answers
You could take it to an electronics store and see if they could rig up a part to fix this. I could help you find some places if you want. But if the company says the part is obsolete then, there is only a small chance that someone, somewhere would have one. Let me know what you think and I would be happy to help you further.
thanks
Posted on May 08, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri May 08, 2008
    check out this website and give them a call, they might actually have the part that you need
    http://www.partmaster.co.uk/cgi-bin/sear...
  • Benjamin Patri
    Benjamin Patri May 09, 2008
    Please don't forget to let me know your feedback about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, my solution needs to be rated.
    Otherwise, let me know if you have further questions and I would be more than happy to help.
    Thank you
  • Benjamin Patri
    Benjamin Patri May 10, 2008
    If the igniter does not shut off, then I would suspect there's a short
    in the switch causing it to stay on. With this being said, I would venture to say that
    the gas valve regulator switch would be a likely source of some of the
    problems you are having, and might be worth the effort to replace.
    Sergeant:
    Champion:
  • 304 Answers
If you check it and see it that it will not work fine even try repairing it, much better to replace it.. & also please the burner for some dirt that makes the gas not flowing normally..
Thank you, & post back again for any further assistance..
  • Elizabeth Krijt
    Elizabeth Krijt May 08, 2008
    there's possibly you can find parts that will work to the oven, but i think the fitting to the oven cabinet will be the issue..
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
Hi there, I have a belling gas oven cooker, which when you try to ignite the oven or grill it keeps ticking but wont spark up. The gas is fine as you can light them manually and the hobs light fine so...
why would they be trying to light an electric oven ( see which product do you think they mean ) You need to check that the spark being produced is close enough to the gas outlet
Oct 03, 2012 | Ovens
The ignigter in the oven keeps clicking all the time the oven is on ? the model is 911
The clicking is not in the oven. You have a bad surface burner switch. Open the front control panel to access the surface switch. Remove one wire at a time for each surface igniter. They are located on each burner valve stem. When the clicking stops, that will be the bad switch. Replace it.
Jun 12, 2009 | Belling FarmHouse 931 Gas Kitchen Range
Cooker problem
If it has a timer, make sure it is set to manual or it will not heat, another possibility is a faulty thermostat, you need to find out if you are getting power to the element, if you are then element should work unless you have got a faulty one.
Plz rate this solution.
Dec 15, 2008 | Belling Ovens
Belling farmhouse 911
Propane I take it.?Order from a parts house the "propane conversion kit".It should have orifices (2-3) and a spring .You Have to replace the parts to allow the propane to work. Please Rate This !!
Jun 07, 2008 | Belling FarmHouse 931 Gas Kitchen Range
Belling FarmHouse 932 Dual Fuel (Electric and Gas) Kitchen Range Logo
307 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
