Question about Blackburn Flea Rear Flasher Bicycle Taillight
After charging the Blackburn Rear Light, it won't turn off. Any suggestions on how to get it to turn off.
Your Flea iscontinuing to flash because it acquired extra energy during the charge. Once the extra energy has been burned it will shut off. To help preventthis try to charge the Flea for no longer than an hour to an hour and a half,and don't charge the Flea after every use.
Posted on May 16, 2011
    Problem Solver:
  • 4 Answers
It might be water damaged just return item to a good local blackburn dealer who will send it back for a full replacement .. it is covered by lifetime warranty !!!
Posted on Sep 28, 2011
MY BLACKBURN 1112V2 WON'T CHARGE
Unfortunately this has happened to me with no less than two of my Blackburn Flea 2.0 USB Lights. The good news is that they are warrantied for life. The only reason I still buy and recommend this product is because when it fails I simply return it to my local bike shop and receive a new one.
Feb 11, 2015 | Bell Sports Blackburn Flea 2.0 USB Front...
Blackburn scorch light not charaging
My just bought Scorch only charges properly from1 of 4 tested computer's USB ports.
At home I have tested from 2 HP laptops and one desktop - it only charges for few minutes, then stops blinking. Once it stops, I cannot get it charging anymore, even if I reconnect it.
I bicycle to work and luckily I have there my work laptop - only there it charges properly until the battery is full.
What could be the issue??
Dec 12, 2012 | Blackburn Scorch USB Headlight 2013 -...
How do i charge a Blackburn flea with a battery? Do i need some equipment or does the battery somehow just charge the Flea?
When I scratch around my cats spine, he immediatly starts licking the air. As my vet said, this is obvious sign of a flea allergy. Advantix multi was the solution, as two days later, and for the entire ...
Jan 15, 2011 | Blackburn Flea Rear Flasher Bicycle...
My blackburn flea front light isn't charging through usb port, tested on 2 laptops
'Had this problem... turned out that the contacts weren't mating properly between the flea and the dock. I remedied by shaving back some of the plastic surrounding the contacts with a pocket knife.
Sep 17, 2010 | Blackburn Flea Front HL Bicycle Headlight...
How do I insert the battery into the Blackburn flea?
It's a rechargable light, with a built in battery and no supposed user replacable battery. You need the USB dock to charge it either through your computer or using the optional Blackburn solar panel.
Jan 16, 2010 | Blackburn Flea Front HL Bicycle Headlight...
I cannot get Blackburn flea to take a charge. It only the 2nd time I am recharging the rear flea. Its a brand new battery.
It might be stuck in 'display mode' (described on the package). Try holding down the button for twenty seconds until you see the signal. Then try turning it on normally again.
Aug 29, 2009 | Blackburn Flea Rear Flasher Bicycle...
My Flea Taillight won't charge, I'm using a brand new "AA" battery, (hooked up - red to + and black wire to - ) I've reset the "light from demo mode (holding down the button for 20"...
Try cleaning the contacts with a cotton swab and som isopropyl alcohol.
Let those dry.
Use a paper clip, or other small pointy object to clear the area around the contact points on the light so the recharger can fully "snap" into place.
Attach a battery you know has a good charge.
Turn on the light.
Did the light turn on?
If so, great, turn it off, and if it is blinking, let it recharge.
If it didn't turn on, isn't blinking and won't hold a charge after this process, return it to Blackburn and enjoy the benefits of your lifetime warranty.
May 08, 2009 | Blackburn Flea Rear Flasher Bicycle...
Blackburn Flea Rear Flasher Bicycle Taillight Logo
2,192 people viewed this question
Top Blackburn Cycling Experts
Donald Ayers-Marsh
Paris Johnson
Paris Johnson
Level 1 Expert
Tafi Nami
Tafi Nami
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
