Question about Samsung Computers & Internet
Why is my computer doesn't boot from cd even if i set the bios setting to boot from cd first?
    Brigadier General:
  • 10,406 Answers
Will another computer boot from that CD?
Disconnect the disk-drive, so that the computer cannot boot from it, and try again to boot from the CD.
Is it possible that the CD-drive is failing, and cannot read *ANY* CD disks?
Posted on Aug 02, 2010
Hard drive won't reboot (jumpers not set proper)
Just google your drive's make and model and search the results for a diagram of the jumper settings.
If you have a SATA drive, there ARE no jumpers. If the drive is a PATA, then if it's connected with another drive or cdrom, then make the cdrom 'slave' and the disk drive 'master'.
Check your bios setting sometimes bios changes the boot order esp. if bios doesn't find a boot disk- make sure you have your desired boot device showing in the boot setup.
Oct 31, 2012 | Hitachi Computers & Internet
Windows 7 password reset bought at a auction dont know main password
Download the Ophcrack Live CD: http://pcsupport.about.com/gi/o.htm?zi=1/XJ&zTi=1&sdn=pcsupport&cdn=compute&tm=48&gps=88_10_1152_572&f=10&su=p284.9.336.ip_p504.1.336.ip_&tt=4&bt=1&bts=0&zu=http%3A//ophcrack.sourceforge.net/ and burn it to a disk using Image Burn: http://www.imgburn.com/index.php?act=download
Then just boot the computer with the Live CD in the CD/DVD drive. If it doesn't boot into the CD you will have to go into the BIOS and set the boot order so that the CD/DVD drive boots first. Most computers will tell you which "F" key to press to get into "setup," also called the BIOS. Sometimes it is the "del" key.
Be advised that it is a criminal offense to break into a computer that doesn't belong to you.
Jul 16, 2011 | E-Machines eMachines Desktop PC
How to boot from a USB CD/DVD ROM MY System is Dell Optiplex 170L Thanking in advance
If you want to boot from a external cd/dvd rom here's what to do.
  1. Connect your USB CD/DVD ROM to your computer.
  2. After connecting, you must start from boot up. so Reboot your computer.
  3. You must go to your bios settings, so during boot, press DELETE or if it doesn't work reboot again and try F2.
  4. Now once on the bios settings, search for the boot device, or boot priority.
  5. You must make your USB CD/DVD ROM as First boot, or just place it at the top of the list.
  6. You can adjust the position by pressing (-)minus and (+)plus signs in your keyboard.
  7. Now once the USB CD/DVD ROM is at the top. press F10 to save the changes and click Yes.
  8. And that's it. Your PC will now boot from the USB CD/DVD ROM.
Goodluck, Hope my solution will help, Please give some feedback regarding my solution.
Thank you very much for using Fixya! Have a Great Day!
Jul 12, 2011 | Dell OptiPlex 170L PC Desktop
I assume Dban worked.....worked so well I am froze at there very first screen {biostar mobo logo} and cant get any farther to load OS or even to the CMOS to even check settings......help pls
Once the drive is wiped that's about as far as one can get because there is no longer an OS to load. Power down the computer. Then turn it back on while hitting the "del" key repeatedly. If del doesn't work try the "F" keys, usually F2. Once in the BIOS, set the boot order for the cd/dvd drive to boot first. Exit using F10 to save. Insert your CD/DVD that has your operating system in the drive and reboot to install the new OS.
If you still can't get into the BIOS, power down the computer, unplug the power cord, remove the side panel and then remove the CMOS battery for 3 or 4 minutes. Put the battery back in and repeat the above instructions.
Jul 06, 2011 | ASUS Computers & Internet
How to boot to CDROM? unit: IBM Intel Pentium 4 1.8 ghz
At power on, you should have an option to hit F12 or another key for boot options. From there choose CD/ROM
Aug 08, 2010 | IBM Netvista Intel Pentium 4 2.4GHz /...
What will i do if this message appear on the screen of my computer everytime i attempt to open it : Reboot and select proper device or insert boot media in selected boot device and press a key.
I dont know if youre are familar with bios settings, nut every time you start
the computer, you can press esc or del or something to load the bios. in the bios you can select the boot device. set it to harddisk.
Apr 19, 2010 | Microsoft Windows XP Professional for PC
My acer PC does not boot from CD drive
if you want to boot your computer with cd you have to set first boot device in bios as your cd rom or dvd rom,
for that when you power up computer press F2 or "del" then you enter in bios then go to boot option then set first devcie as dvd or cd rom .
then save all settings then exit.
Jul 10, 2009 | Computers & Internet
Usb cd boot
you need to set the boot device priority in the BIOS in such a way that the computer will take an external CD/DVD-drive as first boot device. to do this, you need to enable USB legacy support first, save and exit from the BIOS settings and then return to the BIOS to set the USB-CD/DVD-drive as primary boot device.
Jun 22, 2009 | Dell PowerEdge 2600 Server
Need to get into bios
Dear friend for go BIOS some computers Need to preess DEL, Some Computer need to Press F1, Some Computer need to pree F2. you didnt write about your computer... One solution i have ... Press DELL+F1+F2 At starting your sustem... Here is two option to find out Boot Sequence from BIOS.... some BIOS Have Independent Boot Menu.. IN Boot menu you may see boot sequence... there you have change it. For Other Option You may go the Advanced BIOS Setting Option There you may find First boot device, Second Boot device..... Or Boot sequence.... find out your solution...
For Master And slave..setting in CD/DVD rom ..
set jumper.. near ide or sata cable... for setting as Master...
Set jumper After Master jumper... for setting as slave..
Best Regards.. sumon
Mar 27, 2009 | Computers & Internet
Hp 530 notebook cant boot from a cd drive
There is one possible reason for this issue
  1. CMOS battery
Troubleshooting Steps
Open the computer case and find the battery on the computer motherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery. Removed the battery and put it back. This will reset the BIOS setting to default. Change the setting and select first boot device as CD ROM. If that doesn’t work then replace the CMOS battery. After replacing the CMOS battery please change the BIOS setting and select first boot device as CD-ROM.
Dec 30, 2008 | Computers & Internet
Computers & Internet Logo
71 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
