Question about E-Machines (T2958) PC Desktop
Bootmgr is missing i made a recorvery disc but i didn't work the isntallers didnt pop up so i used one of other options none of them work
    Guru:
  • 261 Answers
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully.
8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
Posted on Dec 24, 2010
BOOTMGR is missing?
Insert a system disc and repair the boot manager.
Aug 08, 2014 | Compaq Presario CQ56-115DX Laptop
Toshiba Equium A210-171 bootmgr missing
HDD is damage.. however sometime cause by memory failure. try to clean memoryand insert it back. if not hdd is damage. you need software to recover your files.
Dec 24, 2012 | Computers & Internet
Bootmgr missing
You are not alone in this problem. There are people who are experiencing the same problem. If the problem isn't hardware related (which usually isn't), then you can fix this problem if you have the windows DVD handy (I'm referring to the operating system reinstallation disc).
Insert your OS DVD to boot to the disc.
Just follow the onscreen instructions and click next. After that, you can find a link in the lower left hand side that says "Repair Your Computer"
Just click on it and the computer or OS will try to find the fix to the problem by checking the disc. The computer will automatically overwrite the missing bootmgr and it should fix the problem.
If you have any problems right after doing this fix, please let me know.
By the way, I suggest that you isntall RadarSync to your computer so that you won't have any problems with your computer's driver. Hardware drivers are very important and they are sometimes what causes problems in your computer.
Hope this helps,
Carlo Adrian Canon
Nov 16, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
What does BOOTMGR missing mean?
What version of windows do you have? Vista or 7 & you could run the startup repair from a Windows CD.
You might also boot into your windows repair console & at a command prompt type "Bootrec /RebuildBcd"
Attempting a system restore might also be an options.
If none of the above work then I'm afraid you may need to try & backup what information you can by slaving the drive in another system & reloading your operating systems.
Any windows cd that is the same version of your operating system will work as long as you have the CD key on the side of your computer.
Jul 16, 2012 | eMachines ET1161-05 PC Desktop
Bootmgr is missing
That is unfortunate, the recovery disc is the only option at this point to reload the operational system. Go online to Toshiba and contact customer support and the technical department to see if you can purchase a recovery disc for your make and model.
Apr 08, 2012 | Toshiba Satellite Computers & Internet
BOOTMGR is missing
This may be due to the reason that your Compaq model is only Vista or Win7 Compatible.I didn't get your question properly but as you're having no windows or DOS in your machine.All you need is a Bootable Windows Disc and a working DVD rom to get this done.Cause commands or anything else will require that and even if you fix it with some tricks. Some Other file missing message may appear. But if you just want to push yourself. Normally are Booting files are in the root folder in my case it's in C:\ like NTLDR BOOT.ini BootSect.dos so try to access your root drive.
Dec 30, 2011 | HP Compaq nc6220 Notebook
BOOTMGR is missing
If the Bootmgr is missing then you will need to find either your original Windows installation disc or a Recovery disc in order to resolve this problem.
If you have one of the above discs, then boot from it and then take the recovery options which are provided.
See the Microsoft Help & Support page for details of the Recovery options provided for Windows 7.
See the Microsoft page for details of Vista Startup Repair
Dec 29, 2011 | Dell OptiPlex Computers & Internet
When pc boots it says bootmgr is compressed and does not boot
Boot using the Vista DVD or the respective OS Disc and use the "Repair Option" or go the next step.
Boot using the Vista DVD or the respective OS disc. Go to the Command Prompt. then type the following.
expand bootmgr temp
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h.
This should Work.
Oct 25, 2010 | Computers & Internet
Bootmgr is compressed
I know of three solutions, none of them will work without recovery or OS discs, and I can only guarantee one of them--the one that whipes your system. Try these in this order (assuming you have system discs);
#1 Boot from the system disc and choose the "repair" option. This is the quickest fix, and you lose anything.
#2 Boot from the system disc, and in your Start menu search type "Command Prompt". Open Command Prompt and type (hit enter after each line);
expand bootmgr temp
del bootmgr
ren temp bootmgr
#3 Run a full system recovery from your system discs.
Now, if you don't have your system discs, and you're running Windows Vista, there is another possible option. If your computer is fairly new then you probably have a WinRE partition for recovery, (a "factory image" drive)? I won't go into this now, if you have your discs option 1 or 2 should work for you.
Feb 27, 2009 | Acer Computers & Internet
E-Machines (T2958) PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
