Question about Troy Bilt 5.5hp Self Propelled Mower
Troy bilt self propelled assembled in the box got it out of the box and finished setup but when it came to the pull start cord it would not pull am i missing something?
  • 843 Answers
The unit has a safety feature that stops the engine with a brake when you release the handle. In order to start the engine you have to release this brake by squeezing the handle lever as if you were mowing. You have to hold this lever in that position as you pull the cord.
Posted on Aug 02, 2010
Pull cord engaging
recoil clutch fingers are broken or stuck. Take the recoil cover off and look at it while pulling the cord to see if the fingers arent coming out. If the fingers are still coming out then you have worn out grooves on starter cone where fingers engage to turn the motor. If the recoil is damaged a new one can be purchased as a unit from Troy Bilt online for a reasonable price.
Jan 25, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do you remove the gears on a front wheel self propelled troy bilt push mower?
Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
Apr 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have changed the air filter and bought a new spark plug but my troy built with Honda 160 cc engine will not start.
there is a possibility the c oil is bad, pull the plug and with wire attached pull cord to see if any spark
Aug 07, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Lawn mower cable won't pull to start engine. troy bilt 210 self propelled mower.
It's possible the rope came out of it's pulley groove and is jammed inside the engine housing.
Apr 25, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
213 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
