Question about Craftsman Garden
6.5 sears craftsman push muwer starts for 3 seconds then cuts offi changer the spark plug and but the air filter was very dirty i changer that but ithink it was let go for too long and the engine is fouled up can you advise
  • 755 Answers
Sounds like a plugged main jet. you are only running on the priming fuel and when it runs out the main isnt flowing anything to keep the engine running.
You can remove the bolt from the bottom of the fuel bowl and look at the tiny main jet opening at the top of the threading. The hole is really small so you might want to wire brush the threads slightly first. Use a magnifying glass too if you need it. A small piece of wire strand will clean the small hole nicely. Then just put the jet back in and try it out.
Good luck and be careful
Posted on Aug 02, 2010
My craftsman lawn mowers (model #917.274751) starts and run for about 45 second before it cut off.
Does it loose spark when it stalls out, that would b the most common issue.
Dec 07, 2016 | Craftsman Garden
Craftsman riding lawn mower won t cut grass
Does it die when you attempt to engage the cutting deck? If so the you might have a clogged fuel filter, bad gas, dirty air filter, bad spark plug.
Or the mower engage switch may be faulty. They are located in different places on different mowers. But should be attached somewhere along the main pivot of the engage lever. Let me know if you need more assistance. Good Luck!!
Jun 05, 2012 | Craftsman Garden
My name is jim. My Sears Craftsman lawn Tractor
Clean the carburetor. The needle and float are stuck closed, passage blocked or a jet plugged with debris. Give it a good cleaning.
Jul 30, 2011 | Craftsman Garden
My older Sears Craftsman leaf blower/vacuum will start after some effort, but then dies after 3-5 seconds of running. The spark plug looks clean and is clearly getting a spark. This just started...
If the plug has been in there for awhile i would change it.check the air filter and make sure it is clean.You can clean it with soap and water.Make sure you dry it good.If that doe,s not work try rebuilding or replacing carb.
Dec 03, 2010 | Garden
CAN A VERY DIRTY AIR FILTER PREVENT MY 6.0 HORSE POWER PUSH MOWER FROM STARTING? i.e. GAS FOUL SPARK PLUG AFTER ONLY 3-4 PULLS
Yes, if your air cleaner is dirty it will cause the condition that you talked about...flooding.
You need to either replace or clean your airfilter.
The following is for the foam type air cleaner.
Normally if you clean your filter, you would wash the air filter in a cleaner such as kerosene or diesel fuel, dry it, add a little bit of oil to the outside of the sponge filter and squeeze it to distribute the oil around the filter.
This is a free answer, Please rate me
Oct 13, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
Sears Craftsman mower-Tecumseh engine 3.75 HP- wouldn't start-replaced air filter & spark plug; dismantled carburetor and cleaned it; now it will start but only runs for a couple of seconds and dies....
check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Jul 06, 2010 | Craftsman Garden
I have an 18hp 42inch cut Sears Craftsman, it will crank, run a few minutes then cut off. Will crank back up just will not keep running. Dranied old gas, and changed spark plug, still doing the same thing.
check the gas cap vent little hole on top of cap clean with a pin-check and or replace air filter -check and or replace inline fuel filter if still not running correctly need to clean and repair carb
Mar 29, 2010 | Craftsman Garden
Leaf blower problems
You may have a dirty fuel filter, or carb needs cleaned.
Mar 19, 2009 | Craftsman Garden
Garden Logo
90 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
