Question about Nikon Cameras
My Nikon D70 is not giving me correct meter reading. It is either over/under exposed in Manual, Aperture, Shutter and Program mode. However all the option under the Automatic modes seems to work fine. Is the sensor going haywire in Manual related mode??
    Brigadier General:
  • 11,967 Answers
How low/high do you have the ISO set?
Posted on Aug 02, 2010
I'm doing a project for school and i need to change the aperture for different photos. But my camera refuses to take the photo on any other aperture. Why is there an aperture adjuster if you can't use it....
It depends on the lens.
If you're using a lens with an aperture ring, simply set the exposure mode to Manual or Aperture priority and change the aperture by turning the aperture ring on the lens. In Aperture priority the camera will set the shutter speed appropriately, in Manual you have to determine the appropriate shutter speed. If you want to use such a lens in Shutter priority or one of the Program modes, you must set the aperture to its smallest setting (largest f/number) and lock it.
If you're using a lens without an aperture ring then it's a bit harder. You can only use the camera in Shutter priority or one of the Program modes. You turn the command dial on the camera to change the exposure, and the aperture will change. If you want to use an exposure different than what the meter suggests, you can adjust it by using either exposure compensation or changing the ISO setting (or both).
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n6006af/nikon_n6006af.htm
Mar 08, 2011 | Nikon N6006 35mm SLR Camera
What type of exposure system does it have?
The N2000 has Program, Program Hi, Aperture-priority, and Manual exposure modes, with exposure lock and exposure compensation capabilities. It can TTL auto and manual with flash. The meter is full-aperture and center-weighted.
The Program mode sets both the shutter speed and aperture for optimum exposure. You can adjust the exposure if you want to emphasize shutter speed or aperture. The Program Hi mode tries to set a higher shutter speed for action and/or long lenses.
You can download a copy of the manual here if you want to know more about this camera.
Feb 14, 2011 | Nikon N2000 35mm SLR Camera
The light meter is not working, in AV mode the shutter speed constantly remain at 30 seconds.
It would be nice to know what camera make and model you have. However in AV mode the photographer inputs the aperture (AV meaning Aperture Priority). If you then have the aperture set at (for example) F11 and dim lighting conditions the shutter speed will be long in an attempt to give the correct exposure. If you have a meter reading you see in the viewfinder the needle will be way to the - side of the scale it may be dim enough that attempting to adjust the Aperture a few stops makes no difference in this reading. My though is, if the meter is working in "P" program and you are getting correct exposure then it's user input error rather then meter malfunction.
Jan 07, 2011 | Canon Cameras
I just purchased a new 650 -1300 lens for my nikon d5000, i know you use it in manual mode but I cant get any aperture readings on the camera, any ideas ? i can set the shutter speed ok but the camera...
The lens lacks the electronics to communicate with the camera. As you said, you must use the lens in manual mode. You control the aperture by turning the aperture ring on the lens. You can read the current aperture setting by looking at the lens, but you will not see the setting in the viewfinder. You also will not get any metering assistance from the camera. You can review the pictures (and the histogram) to fine-tune your exposure.
Dec 02, 2010 | Rokinon 6502600 f816 for Nikon
I have a Nikon d40X. When I attempt to take a picture, the shutter speed is EXTREMELY slow. Because of this, my pics are all blurry. I am not sure what caused this to start happening. Can someone please...
Steve - the Nikon dSLR cameras are very capable. Check the position of the mode dial:
The image above has it set to "P" or Program mode. Change it to "AUTO" and take a picture of a well lit scene (preferably outside in the daytime). You should get a properly exposed image. If the mode dial is set to "M" or Manual mode, the shutter speed is probably too low, and the aperture either too small or large if the image is dark or light, respectively. You'll have to turn the knobs on the front AND rear to adjust BOTH shutter speed and aperture (f-stop) to find the right combination of exposure time and aperture opening allowed into the camera to suggest motion (more blurry with a slow shutter - or more sharp with a fast shutter), in addition to DOF or depth of field.
You may have a similar issue when set to "P". If you are in this mode, the camera will attempt to determine the best shutter and aperture settings for you. You can veiw the settings chosen in the view finder. Likewise, you may override either shutter speed or aperture changing the aperture OR shutter speed control knobs. The camera will automatically change the other - to provide a properly exposed image.
Review the manual here. Page 39 details the mode dial and how it works. Page 18 discusses the
"Digital Vari-Program" modes depicted by the icons, and the "AUTO" label. These modes should be avoided, unless you are happy with "snapshot" type pictures. The most creativity will come from using the camera in one of the other modes: M,A,S or P. Taking the time to learn them will greatly increase your enjoyment of the camera and resulting images.
I hope this was a good starting point for you & good luck!
Nov 01, 2010 | Nikon D40x Digital Camera
Nikon D40X In Program mode (P*) I can not change settings. Nikon's video show it is possible to do this using the command dial. Any suggestions ?
Program: Puts the camera in charge of aperture and shutter speed, though all remaining camera settings are available. You can vary the combination of aperture and shutter speed the camera has selected by rotating the Command Dial.
from: http://www.imaging-resource.com/PRODS/D40X/D40XMENUS.HTM
The camera takes care of the shutter and aperture settings, and you control the other stuff...(presumably white balance, focus points...etc.?). I hav ea D70 and using the thumb wheel, I can, on 'P' mode, set the aperture...but the shutter speed is always 'auto' as far as I can tell.
Best of luck!
Nick Chapman http://ChapmanIT.com
Jan 05, 2010 | Nikon D40x Digital Camera
How do i read a light meter on a Nikon N55? i see the f stop but i dont see the shuter speed, how do i adjust and how do i know its right?
Your camera is either fully automatic or fully manual. In addition it has shutter priority and aperture priority semi-automatic functions. With shutter prior. you pick the shutter speed you prefer and the camera will adjust the aperture. With Aperture prior it works the other way around. The exposure will be always the optimum (decided by the camera program).
You can adjust these automatics with the program dial.
Oct 28, 2009 | Nikon N55 35mm Film Camera
Nikon d100
Wow, that's a long lens! It it a Nikon 500mm?
I use the full manual mode on my D70 sometimes, and I think the operation will be very similar. Spin the mode dial to M, first.
Now half-press the shutter and you should get metering at the bottom of the viewfinder. The meter will tell you if your current settings are over or underexposing. You can use the front control wheel to set the shutter time, and the back (thumb) control wheel to set the aperture.
If you've used S or A modes before, you'll be familiar with these controls. More aperture (smaller F numbers) lets in more light, as does (obviously) increasing the shutter exposure. If not, play around and watch what happens to your exposure meter in the viewfinder as you dial aperture and shutter duration up and down.
You're going to want a sturdy tripod or some very bright light with a lens that long!
You may have to use manual focus, too, if your lens does not have modern Nikon guts for the camera to talk to. I guess you'll cross that bridge when you come to it. Good luck!
Nov 05, 2007 | Nikon D100 Digital Camera
Manual Exposure mode Nikon F80
1) turn the mode switch/knob on the left of the camera to M ( manual mode ) 2) turn your lens to the highest f-stop ( 22 or 16 depending on your lens ) 3) in front of shutter release button you have control for your aperture : turn until the desired aperture is displayed ( view finder or the LCD monitor on the top ) 4) your shutter speed setting is controlled with your thumb with the control situated next to the strap lug on the right hand side of the camera. 5) press shutter release half way and look through viewfinder and see light meter reading and adjust either shutter speeds or the aperture as explained being guided by the l.meter.
Sep 23, 2007 | Nikon F80D 35mm SLR Camera
Cameras Logo
64 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
