Question about Comfort-Aire HMC18AD-1 Air Conditioner
Hi
The L3 and L4 lights are blinking means that the filter is dirty and obstructed. You’ll need to clean the filter. Also Inspect whether the evaporator air is blocked, remove the blockage. Check the air intake and outlet ducts of the condenser side are obstructed. Check both of the ducts. Check whether the unit is set on dehumidifying mode. Set at cooling mode, Set at low fan speed Re-set the fan speed at high speed and check.
However, if this doesn't help then it might have happened that the compressor is not runing and the connection to the compressor is cut. Please check the wiring diagram on Pg 22 in this manual---
Comfort-Aire Air Conditioner Manual & wiring diagram
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Posted on Aug 02, 2010
The model you are referring to is made by Heat Controllers Inc. I cannot find the model that you have on their website. The closest I get is MMC18DA-1.
Is this your model. Refer the manual available from Comfort-Aire website. If you have the unit made by Energy Knight then the model number you have HMC18AD-1 is correct.
Please clarify.
Posted on Aug 05, 2010
Sorry, Please ignore my earlier posting. We don't get to see responses of other consultants on the fixya site and this causes confusion.
I will keep looking and help you if i can.
sorry for annoyance.
Just to help further with this, provided you give me the benefit of rating my solution favourably.
I know there have been other consultants who have given you a run around, but it is hard when we are all eager to help the clients but do not have access to what the others have posted. This is the way the system has been setup and most of us are just volunteers trying to help the community where we can.
Now coming to the point, the model HMC18AD-1 used to be made by EnergyKnight who may at some stage have been taken over by Heat Controllers and have changed the model numbers. Atleast this is why people are trying to write to you confirming the model no.
I am assuming you are very good at servicing aircons and will therefore not bother you with details on what could be the fault you are experiencing. You asked for service manual and I will help you get it.
I have a service manual for the single zone version which should give you enough diagnostic information because I would assume the dual unit would have two compressors.
I have the parts & assembly list for your 2 zone system and the electric circuit diagrams. I am hoping this will help you.
Best to print or save these documents when you open the links. Never know when they can disappear.
In addition I have also listed the website which has all the Heat Controller system manuals. They don't have the service manual for your model but there is a current model which should be similar.
I noticed you have taken refund from fixya for your problem. It is unfair after I got you the service manuals which you had asked for in your problem enquiry. We are mostly volunteers trying to help the community and don't make much money compared to the effort put in responding. But it is the fairness that matters.
Try these manuals if it helps:
click this link:
Posted on Aug 03, 2010
Hi
You can download the manual at the website below
www.kaelte-bast.de/dateien/euro/pdfs/asr609-612cl-ser.pdf
i bought a replacement t-stat, that did the trick. the idea i of taking
out the t-stat temp coil and moving it out from the condenser coil
seems like a worthy enough idea, although my replacement t-stat only
cost me 30 bucks and a half hour..
You should make sure your compressor coil is very clean, by blowing it out
with air and vacuuming it out. Making sure there is no ice built up
anywhere on your coils, and making sure your door seal is air tight.
Thanks
Hi
Please check the bellow link for the manual....
http://www.comfort-aire.com/downloads
http://www.appliancefactoryparts.com/airconditioners/comfort-aire/comfort-aire-manuals.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Here is the link for the Comfort-Aire Website Downloads:
Oct 13, 2017 | Panasonic Heating & Cooling
Aug 14, 2016 | Zanussi Dishwashers
Jan 26, 2016 | Panasonic Heating & Cooling
Nov 18, 2012 | Ruud Central System Air Conditioner
May 27, 2012 | Sharp Heating & Cooling
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Feb 01, 2011 | Fujitsu Heating & Cooling
Dec 13, 2009 | Fujitsu 18C1 Air Conditioner
Oct 30, 2009 | Air Tools & Compressors
Jan 24, 2009 | True T-49 Side by Side Refrigerator...
423 people viewed this question
Does anyome actually read the problem before offering a solution? This is a comfortaire HMC18ad 2 zone minisplit system. The "A" side works fine putting out 29 deg f air. The B siode is only putting out 49 deg f air. The pc board on the outside un it is flashing at 1 sec intervals at L3 and L4.
I need a service manual. I have checked all of the sites that come up on google including calling comfort aire (they are a bunch of idiots).
Comfortair/heat controller/energy knight model A-HMC18AD mini split 2 zone system. If you don't know anything about this specific unit, then don't waste my time and yours.
