Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
I have a Fisher & Paykel clothes washer GWL08-US1 which has a broken suspension assemble. Where can I find a schematic so that the parts I ordered can be safely installed?
5 Suggested Answers
fanny
  • 146 Answers
SOURCE: Fisher & Paykel GWL10 US won't spin
If the machine still has water in it, the drain pump is jammed or there may be an obstrution in one of the hoses. It is most likely the drain pump. Switch off the machine at the wall and unplug it. Tilt machine against a wall and look underneath. On the right you will see the drain pump. It looks upside down. Unplug the wiring harness to the pump and remove pump by turning it clockwise while at the same time releasing the little white clip that holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
woodchuck789
  • 4070 Answers
SOURCE: The cold water often will not shut off
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Post your model number(http://www.appliancepartspros.com/modelnumber_loca tor.aspx ) HERE and search for water inlet valve > http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=GWL08
Or you can go to an appliance parts store.
Posted on Sep 28, 2009
SOURCE: Fisher and Paykel GWL08: Will Not Power ON
It's been a while since I fixed mine... So I am not sure if this fixes your problem. For some reason, some of the electronic components (touch panel) get wet inside. You need to take out the electronics touch panel, wipe it off, if wet (BTW it is not difficult). Make sure you know where and how everything goes back together. On mine, I found rocker switch that got wet and corroded. If found the model on line (Cherry Semiconductor, ordered it and now works
Posted on Dec 15, 2009
Daniel S
  • 4323 Answers
SOURCE: Need Service Manual for Fisher & Paykel clothes
Hi
Please click on this link to download the repair manual for your Fisher & Paykel GWL10 washer. Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 17, 2011
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Top Loader Fisher & Paykel agitator makes banging noises when washing clothes
its common on these machines especially the bigger ones,chances are the suspension rods are worn out and need replacing
Jul 03, 2014 | Fisher and Paykel Washing Machines
How to fix my fisher & paykel washer machine from shaking and knocking
Your 4 suspension rods will need replacing as they are loose & worn.
Or the bowl has lost its ballast water from the top & bottom balance rings of the bowl.
Jan 05, 2013 | Fisher Paykel WA42T26GW1 EcoSmart 25" Top...
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
The cold water often will not shut off even when power is turned off on my Fisher & Paykel GWL08 washer. It must be turned off manually. Is the problem the input valve, and where do I get a new one?
Sep 28, 2009 | Washing Machines
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL08 top load washer appears a crack in the inside water dispenser
With the lid open, you'll see two white plastic plugs on the top front lip of machine. Pry them up with fingernail to reveal screws to remove. Take care not to let top flop back as plastic tabs may break.
May 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
Getting belt back on dryer
Try this website www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60Awashingmachine&gclid=CP_yiYL_8ZICFQHBsgodrEYP5A
Apr 23, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
176 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
