Question about Nitro Collectable Fishing Boat Patch,emblem, Ww
I have a 2002 Nitro fishing boat and the question is about the live well. I can not get it to pump water out of the live well. If fills but will not empty?
1997 Nitro bass boat 640 LX. Where can I get an owner's manual?
Boat Manuals Now Available Free From Vessel Vanguard ...
www.passagemaker.com/.../boat-manuals-now-available-free-from-vesse...
Nov 14, 2013 - Boat owners are often frustrated by the diffi. ... I need complete operating manual for 2001 Nitro 175 Sport Fish ski boat. Peter Swanson April 6, .... I am looking for a Manuel for my Italian made 1997 AquaViva Frontier 6 meter cruiser. Thank you,. Jeff ... Have purchased 1989 Pro Craft Stalker 180 Bass Boat.
Aug 26, 2015 | Nitro Boating
Motor runs good out of water in water no go
quite possibly you need a water pump.
Jul 01, 2014 | Nitro Boating
My 2001 Nitro sat for about a year, batteries are charged but it doesn't start.
More than likely your carburetors are gummed up with old fuel that turns to varnish after sitting for a long period of time without fuel stabilizer. You can easily test this by spraying a little quick start starting fluid into the carburetors and then try to start the motor. If it cranks up, for even a few seconds, then start by rebuilding the carburetors. If this solves your problem then I would recommend changing your water pump impeller as well.
Aug 21, 2013 | Nitro Boating
Where fuse panel located on a 1994 nitro 190 ft. bass boat
You may be able to find the answer on the boating forums.
http://forums.iboats.com/nitro-boats-364/?boatid=171
It most likely is located near your battery.
Mar 17, 2013 | Boating
Bilge pump on 1996 nitro bass boat inop
Check to make sure the fuse is good and you have power going to the switch and then to the wires (brown for positive and black for negative) in the bilge area using a 12 volt tester. If you have power to the brown wire while grounded to the black wire then the pump will need to be cleaned, have the impeller replaced or replace the pump. The pump is located in the rear compartment attached to a board mounted to the inside bottom of the boat at the center near the transom.
Feb 12, 2013 | Nitro Boating
Wheres my bilge pump
It's located in the rear compartment centered on the bottom of the boat in front of the transom.
Jun 22, 2012 | Nitro Collectable Fishing Boat...
My father died and left me is boat with no manual.there is 4 buttons on the dash board can you help us out on what they are? we would like to get a manual for the boat if you know where we might find one.
Sorry about your dad,I do have a nitro boat 17dc the only buttons I would say they are is the bilge pump, airrater,running lights, or to bring up the motor. If this dose not help if you are close to a bass proshops they will help you get a book for your boat they do sell the nitro boats there.good luck
Aug 01, 2011 | Nitro Boating
Nitro Collectable Fishing Boat Patch,emblem, Ww Logo
24 people viewed this question
Top Nitro Boating Experts
fordexpert
ray gallant
Oldnwise1
Level 1 Expert
Are you a Nitro Boating Expert? Answer questions, earn points and help others
