Question about Kodak i260 Duplex Color Scanner
Unable to scan page, Bad width and/or length specified (V10.2.102421)
The length, l, of a rectangle is 5/2 its width, w. The length, l, of the rectangle is 10 inches. What is the perimeter of the rectangle? What Iis the area of the rectangle, in sauare inches?
We are given the following data:
length = 5/2 * width
length = 10 inWe know through the transitive
property of equality that the following must be true:
5/2 * width = 10 in
We then solve this equation algebraically for width:
width = (10 in) * 2/5
width = 4 in
The perimeter of the rectangle is given by substituting our known values of length and width into the following general equation:
Perimeter = 2 * length + 2 * width
Perimeter = 2(10 in) + 2(4 in) = 28 in
In a similar fashion, we substitute these known values into the general equation for the area of the rectangle to solve for the same:
Area = length * width
Area = (10 in)(4 in)=40 in^2
Nov 29, 2016 | The Computers & Internet
Scanned document is 8.5 x 14 even though setting says 8.5 x 11
You probably have the PDF programme page size settings incorrectly set to the larger size = why only able to print some of the length. As a solution, use a photo programme (Photoshop, Elements or the excellent FREE Faststone Image Viewer to resize the image so it will then print on your paper but so doing will reduce, slightly, the width to suit the revised shorter length to preserve the proportions/balance between length and width.
Apr 01, 2014 | Epson WorkForce WF-2530
P=228 width is 24 ft less than the length
Say length is x.
Width is x-24.
Perimeter is length plus width plus length plus width = 228.
x + (x-24) + x + (x-24) = 228
4x-48 = 228
4x=276
x=69
length = 69
width = 69-24= 45
check: 45 + 69 + 45 + 69 = 228
Dec 18, 2013 | Computers & Internet
How do you solve a rectangle is eight inches longer than its width. find the dimensions of the rectangle if the perimeter is 60 cm
The rectangle is 11cm by 19cm.
The perimeter is 60, so the width and length must add to 30. The length is 8 more than the width, or width+width+8=30. Solve that for width, then you can calculate the length based on the width.
If this is homework, be sure to show your work.
Oct 11, 2013 | Lands Phones
Change page lenght
**Got file, page lay out>paper>paper size>scroll to custom,type desire pape length & width** After print command, in printer dial box go to properties,select paper/quality,paper size,select custom, type desire length & width
Feb 01, 2012 | HP LaserJet Office Equipment & Supplies
Pages printed with dark horizontal lines the entire length of the page with a repeating (lighter) images.
I have seen bad laser scanners cause this...
A black line across the page from left to right, of various widths, at various intervals, all the way down the page.
First, though, I would reseat the toner cartridge. If the problem disappears, you are in luck!
Try another Toner Cartridge to see if the problem disappears.
It could also be a bad control board.
Good Luck.
Nov 03, 2010 | HP LaserJet 2420 Printer
Hi, i am teaching my wife how to parallel park,
Width of parking space: 2.6m and poles should be
Length of parking space: • Rigid: according to Table 1 • Articulated vehicles: according to table 2 The length of the parking space is determined by adding the total length of the vehicle as indicated in the top column, to the comparative free play in metres, as shown in the bottom column. For example: Length of Rigid Vehicle A is 9 metres – therefore the total length of the parking space is: Length of Vehicle + specified free play = 9 m + 1.8 m = 10.8m.
Rigid Vehicles:
Length of vehicle: 7.0-7.5m / 1.50m free play
7.6 - 8.0m / 1.60m
8.1 - 8.5m / 1.70m
8.6 - 9.0m / 1.80m>br /> 9.1 - 9.5m / 1.90m>br /> 9.6 - 10.0m / 2.00m
10.1 - 10.5m / 2.10m
10.6 - 11.0 / 2.20m
11.1 - 11.5 / 2.30m
11.6 - 12.0m / 2.40m
12.1 - 12.5m / 2.50m
hope that helps please vote thanks
May 25, 2010 | 2005 Hyundai Tucson
Parts of page being scanned are cut off
Whcih version of CapturePerfect you are using?
I use ver 2.0. In the settings page select scanners maximum. In the 'advanced' select auto detection. Then whatever size of the paper guides you choose, that will will be the width and ofcourse the length is automatic. There is a sensor under the paper guide, and it detects the paper width. Any rotation chosen will be after scanning the required size.
S. Mohan, Chennai, India
Jul 20, 2009 | Canon DR-5010C Scanner
I have an argos 214. Running windows XP. When I set the page width and length to 762mm x 300mm and click on ok, when i go back to page setup the page width and length settings have changed back to inches.
when u want to use it, set it as default printer. then the setting of the design will not go back. and don't set anything setting on the printer, use program to amend the location of the design.
Jun 08, 2009 | Argox Office Equipment & Supplies
Setting correct paper size
By trial and error I found that the paper is specified with the width then the lenght of the paper.
Even though the graphics show you that you are printing the image either vertical or horizontal I still wanted to know when I set up my non standard paper size of 24x 6 which was first the width of the paper or the length. I didn't see that in the manual. All our problems should be so small.
Thanx for the reply though
Apr 10, 2009 | Epson FX 1170 Matrix Printer
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
