Question about HP DeskJet 3650 InkJet Printer
Blinking green light< will not print. staus says it is offline
    Genius:
  • HP Master
  • 1,354 Answers
Hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · Step 1
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
· Step 2
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
· Step 3
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Mac Instructions · Step 1
Open System Preferences by clicking on the icon in the Dock.
· Step 2
Go to the Print & Fax control panel under the Hardware category.
· Step 3
Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button.
· Step 4
Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Posted on Aug 02, 2010
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
My printer is offline. I have an HP deskjet 3930. I have tried unplugging, disconnecting, turning both printer & comp. off. The green light just keeps blinking. I've cleared all printing.
The green lights blink during the starting phase of the printer. If it doesn't stops blinking then the starting process never finishes, which means that the processor of the printer or the firmware circuit have failed. The only way to replace those is to replace the entire mainboard, and that would cost more than a new printer altogether.
This printer is dead, time for a new one.
Apr 03, 2011 | Gateway Computers & Internet
My hp 2360 wont print, green light keeps on blinking, it says printer offline on the printer status bar
Make sure that cable to printer is attached and if printer still shows offline then in control panel for the printers make sure that you right click and choose Use Printer Online
What the flashing light means
The Power light can flash for several reasons:
? The printer cover is open.
? The printer is out of paper.
? A problem exists with the printer, such as a paper jam or a problem with a print
cartridge.
For information
Jan 30, 2011 | HP Deskjet 2360 InkJet Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
SAMSUNG ML-2510 LASER MONO PRINTER
no, I have paper....the red-light on the top keeps blinking.....
I have used akums-razor to determine the answer.....
sol: push and hold down the orange button for 3-4 secs and wait for a print-out. It will give you the staus of the toner cartdg. MINE REPORTS A LOWWWW LEVEL. ( the orig. cartridge gives the user only about 1000 sheets and mine is around 783. This is why I think the light came on to tell me to jump in my Lexus, get down to Best Buy, and get another ( more capacity) new cartridge....
cool, huh?:>))))
May 09, 2008 | Samsung ML-2510 Laser Printer
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer light keeps blinking and status stays offline even it is READY
UNINSTALL AND REINSTALL THE DRIVER SOFTWARE BRO...................
IT MAY LEAD U 2 A SOLUTION.........
TRY IT
Nov 14, 2007 | HP Deskjet D2360 InkJet Printer
Offline and blinking lights
A couple suggestions. Unplug the usb cable from the pc to the printer, make sure there is no paper jammed in the machine, unplug the machine from the wall and see if you can move the print head left to right freely. If nothing is obstructing it plig the power cord in with out the usb cord plugged in. See if the machine goes to ready. If all of these fail, that means the main board has been damaged by a power surge, and it would be cheaper to replace the machine than repair it. Good luck!
Jun 28, 2007 | Dell 942 All-In-One InkJet Printer
HP DeskJet 3650 InkJet Printer Logo
505 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
