Question about Konica Minolta bizhub 350 All-In-One Laser Printer
When I turn on the main power on my Konica Bizhub 352, i get the hour glass for a few minutes and then nothing. Main power stays on but nothing else. Just a blank screen.
  • thg57 Aug 02, 2010
  • Konica Minolta Master
  • 4,737 Answers
Is there memory installed on the Dimm Slots? If so, please remove it/them, and follow the instructions below;
Turn off the machine, unplug the power cord (don't forget to switch off the the Mains), disconnect the ethernet cable (if any), press the power several times so that any static voltage may be discharged. Leave the Machine off for few minutes (approx 5 mins). Now reconnect the power cord after switching on the Mains. Power on the Machine, again while it boots up, press the Power and Cancel button continuously (don't install the memory). Now remove all the cartridges, drum and leave the machine On without cartridges and drum for another few minutes. Turn it Off, and restart, now you can install the cartridges and drum. After you are done with the cartridges and drum, close the Front Panel door and keep pressing the cancel button while the machine runs for power cycling. After it's fully booted and ready, please check the status message on the lcd, I hope it shows the correction information. Now you can turn it off and reinstall the memory. If you follow the steps mentioned above, definitely your machine will run as it was.
You should also aware of the power supply when doing all these, sometimes, power surge can create havoc with the machine.
If the problem persists, let me know so that I can assist you with another method.
Good luck.
Thanks for using FixYa.
Posted on Aug 02, 2010
  • thg57 Aug 03, 2010
    Still doesn't solve it. I tried this a few times.
  • Lebanon Raingam
    Lebanon Raingam Aug 03, 2010
    I am sorry to hear that. But since after trying this, you haven't seen any changes, I have not more idea on how to deal with this. Possibly, this could be another problem with the rom memory or chip on the board. Honestly, I can't go further from here since I can't physically inspect the unit myself.
    I wish you good luck.
    President:
  • 4,070 Answers
Hi! Please try this. Unplug the unit from power source and turn the machine on while unplugged and leave it for atleast 10secs. This should reset the system and resolve the problem. Take note that you may need to repeat the procedure more than 3 times. Hope this helps and have a good one!
  • 1 more comment
    Tried this several times. The machine will start to come on, but then just the hourglass and then just a dark screen.
  • dj_relly999
    dj_relly999 Aug 03, 2010
    Hi! Hows it going?
    Still not working.
Konica minolta bizhub 654e erorr code c-9401
The bright lite under the big glass is dead raise the the doc feeder then place a paper on the big glass and press start a very bright light should come on which is normal
Try this once if code come back replace the exposure lamp section
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Reset key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 11, 2017 | Konica Minolta Office Equipment & Supplies
We have two Konica Minolta (Develop) c203s which won't boot up. Both working fine one day, then overnight seems to have frozen. I.e. Turn of the main power switch, the two status lights (Orange and blue)...
Try to Troubleshoot By SWITCH ON MACHINE FROM MAIN POWER SWITCH BY PRESSING UTILITY BUTTON.
-WAIT AND KEEP HOLDING UTILITY BUTTON
-AFTER 10 TO 15 SECOND, TROUBLERESET OPTION WILL APPEAR ON SCREEN, TOUCH IT AND SWITCH OFF.
-NOW ON NORMAL WAYS.
if not ok, then check the panel connection.
- after switching off and on, wait and observe if it display KONICA MINOLTA SCREEN OR Hour Glass symbol.
and let me know for further diagnostic.
Aug 01, 2017 | Konica Minolta Office Equipment & Supplies
Konica bizhub 283 photocopier error code c9401
FIRST, if this code comes back. Have a technician look at it the exposure lamp the bright light under the glass is bad or the board controlling it.
2. Turn main power switch ON while pressing the Utility/Counter key.
4. Check to make sure that [OK] is displayed and the it has been reset.
Mar 22, 2017 | Konica Minolta Konica Bizhub 283 Copier,...
Konica minolta bizhub c654e error 9401
Raise the doc feeder when you press start to make a copy does the bright lite come on???? Try this procedure if code come back have tech come to replace the bright light under the big glass
1.
May 20, 2016 | Konica Minolta Office Equipment & Supplies
Error bizhub c450 c9401
The bright lamp under the big glass is burned out or the circuit board that controls it is bad try this first if the code comes back get tech out to look at the lamp or board.
Aug 26, 2014 | Konica Minolta bizhub C450 Scanner
Why do I have a Trouble code c9401 on biz hub c550 Konica Minolta?
After doing this the code comes back replace the Exposure lamp assy. big bright light under the glass.
1.
May 20, 2014 | Konica Minolta Bizhub C550
The big bright light under the big glass is bad or the board that control is. replace it.
reset
May 05, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 7000 controller doesn't turn on
Turning the Power On or Off - Konica Minolta Online Manuals
manuals.konicaminolta.eu/bizhub-C554-C454-C364.../id10-0061.html
bizhub C554 C454 C364 C284 C224 ... The Main Power Switch of the machine and thePower key on the Control Panel. No. Name, Description. 1. Main Power Switch. Press this switch when turning on or off the main power of this machine or ...
[PDF]C7000/C7000P/C6000/C70hc/ C6000L
myworks.sindoh.com/upload2/.../d37800822888835787371.pdf
KONICA MINOLTA Confidential. 2. C-2721, Intermediate .... v) Execute Printercontroller calibration for every output profile. (Standard ..... Start CWS5 and login to a Fiery controller. ii) Click [Calibrate] ...... If FD skew doesn't remain,. FD skew ......*A1DURX01: For bizhub PRESS C7000/C6000 and bizhub PRO C6501. 2.
Feb 15, 2014 | Konica Minolta Konica Kit For Bizhub Press...
My konica bizhub c550 does not go past the hour glass when powered on, how can I fix this please?
Something maybe mechanically stuck. The printer is expecting something to happen which is failing to happen. Maybe the carrage has to go to one end then back again when you turn on.
Nov 15, 2013 | Konica Minolta Bizhub C550
Copier is locked up with hour glass symbol on screen
Try pulling the plug/turning off the main power switch. Wait a minute, then power it back on.
Dec 30, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
77 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
