Question about Cycling
Have old DP Exercise Bike Model 14-5390A. The the plug came off end of wire that plugs into the monitor. Is it possible to repair that?
  • 23 Answers
SOURCE: Increasing the resistance on a DP 400 Exercise bike
20 years old! wow vintage ha well it is actually connected my friend but ur bike is well a little oldy for more resistance u see as the bike gets older the wire to provide the tension losses its tension factor or rather its ability to provide tension like our tendons and ligaments so my friend either change the wire if u can or better change the bike lol
Posted on Jul 13, 2009
SOURCE: edge 491 exercise bike monitor panel dead
http://www.academy.com/images/pdf/Fitness_Quest/Edge_Recumbent_Bike_491r.pdf
Mine went dead last Spring. I ordered a replacement part from Fitness Quest. I think the link is above. Actually, while I was waiting for the part, I reconnected all the wires on the whole bike and the panel worked. So I actually have an extra new working panel if Fitness Quest doesn't have the part for some reason and u want mine. Double check ALL the connections of the wires first. They come loose easily.
Nancy
Posted on Aug 10, 2009
SOURCE: DP Air Gometer Exercise Machine manual
When excercising faster it seems to make a lound clicking noise.Dose not happen when going slow.HELP
Posted on Oct 16, 2009
SOURCE: Putting together new nordic track upright exercise
Customer service says that is for testing the console at the factory. I was hoping that it was for a cool add-on but it's not.
Posted on Dec 26, 2009
SOURCE: i have an old acer monitor model 7134T, the
A female DE15 socket (videocard side). Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 ID2/RES formerly Monitor ID bit 2, reserved since E-DDC Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 KEY/PWR formerly key, now +5V DC Pin 10 GND Ground (VSync, DDC) Pin 11 ID0/RES formerly Monitor ID bit 0, reserved since E-DDC Pin 12 ID1/SDA formerly Monitor ID bit 1, I²Cdata since DDC2 Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 ID3/SCL formerly Monitor ID bit 3, I²Cclock since DDC2
Posted on Feb 16, 2010
Do I need both cables for windows machine or can the USB connected to the machine and the mini dp plugged into the monitor work by itself
Is this an external monitor cable? Where the monitor cable that connects to the computer has two USB cables attached at one end?
If so, no. You do not need to plug both ends in. If one is powering the monitor fine and you see no performance problem occurring with the monitor you are OK to plug in just one.
The extra USB end connected to the cable is for additional power supply. If for some reason the machine you are plugging into does not supply enough power to the external monitor you would plug the second end it to the machine and boost the power to the monitor.
Hope that helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
Oct 20, 2015 | Computers & Internet
Where does the h35HR exercise bike plug in?
Plug the power adapter into the receptacle on the frame of the exercise bike.
The insert for the power supply should be toward the bottom front of your machine.
If any other issues, please do not hesitate to call us at 888-713-2880 or visit us online at www.sportsmith.net
May 02, 2015 | Exercise & Fitness
I cant seem to get the timer to do anything on my excercise bike
The display (timer) needs to be connected to a sensor on the bike.
Make sure the display is plugged into a cable coming out of the bike.
If it's plugged in and still doesn't work, then contact the manufacturer.
It could be,
1. a bad display. (possibly a broken PCB connection)
2. a bad sensor inside of the bike. They typically use a Reed switch.
3. a broken connection in the cable or connector
4. the magnet fell out of its location.
You can get a replacement monitor from the manufacturer. If this doesn't solve the problem then it's either the sensor or the connection.
You can also place a continuity tester across the 2 contacts of the connector that plugs into the display. The continuity tester should flash when you pedal the bike.
Here's a link where you can purchase a continuity tester.
http://www.amazon.com/Extech-ET40-HD-Continuity-Tester/dp/B0025PK724
You can also pickup a continuity tester at any auto parts store.
Apr 27, 2015 | Body Sculpture Bc1510 Exercise Bike
Exercise bike instruction manual
WARNING Do not attempt to open the back cover of the Monitor console. This is not a battery storage area; this Computer is powered by an AC Adapter. This bike is to be used only indoors and in a dry location. Do not plug the AC Adapter into the wall until the electronics monitor is completely assembled.
Jul 16, 2014 | Fitness Quest Edge 482U Upright Exercise...
I moved,so I took the bike apart.can't find a plug or wire to plug it in
you have to buy an adapter the plugin is behind the right side battery panel if you're sitting on the bike
Mar 19, 2014 | Golds Gym Cycle Trainer 390 R Recumbent...
Torpedo FN-10195 Magnetic exercise bike ERROR E1
Contacy the makers to see what the error code means.
Jan 10, 2014 | Sport & Outdoor - Others
Preform 310 cx bike. I can't find where to plug in the adapter cord on the bike.
Usually with this brand it will plug into the back of the console. You may have to take off a cover where the batteries are to find the fitting.
Oct 05, 2013 | Proform 310 CX - Exercise Bikes
Jun 29, 2009 | Exercise & Fitness
Wanted:Owners manual for DP Air gometer exercise bike
Scanned image of the 14 page manual that came with a DP AIR GOMETER Model 14-3800B that was purchased in 1991 is available at http://sites.google.com/site/oakrunsite/
Oct 19, 2008 | Sport & Outdoor - Others
Cycling Logo
59 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
