Question about Xerox WorkCentre M-24 Color Copier
What does Error Code "L6" indicate for a Xerox Work Center 2140 DF copier/printer?.
    President:
  • 2,072 Answers
That is a problem with the polygon mirror motor. That is the motor that rotates the missors in the laser assembly.
Most likely have to replace the laser.
Google a business called The Parts Drop.
Give them a call and ask for Britt. He will help you.
I believe there are 2 different lasers for that machine. I am not sure just the mirror motor is spared.
Here I pulled up the site and phone number. I have ordered from them for years. Top knotch people to do business with.
Posted on Aug 02, 2010
  • Rick Kasper Aug 02, 2010
    Phone number is 201 387 7776. Goodness it wouldnt copy and paste.
U2 error code on xerox 5020 . how to fix it?
Actualy my copier is xerox work centre 5020. My problem is machine is indicate u2 error
Mar 23, 2013 | PrintCountry Xerox 5020 Laser Printer...
I am using xerox work center pro428 .now it is not working error message showing code U8-3
Hi, I can't find that specific error code in the documentation on that model of machine, however, in general in Xerox machines U8-3 means that your exposure lamp is blown or has a problem
Aug 19, 2011 | Xerox WorkCentre Pro 428 Copier
Hello. We have 2 Pcs of Xerox Copier
Try removing the fuser and re installing it.
If that doesnt work then the fuser is bad.
Nov 10, 2010 | Xerox DocuColor 3535 Copier
XEROX XD130DF HAS ERROR CODE L6 HOW DO I FIX IT
An L6 usually means the motor that spins the mirrors in the laser unit has failed.
You can try unplugging the machine, removing the back cover and unplugging and reseating the plugs on the main circuit board, if that doesnt work, then there is probably a 90 percent chance the laser will need to be replaced. Not an easy job to replace. You can try looking on E-bay or other online part sources. But used really isn't the way to go on a laser and it would be at least $200 to purchase one, wish I had better news .
Jan 19, 2010 | Xerox Office Equipment & Supplies
L6 Code
The Laser's Polygon Motor has failed to reach proper speed in the allotted start up time.
Replace the polygon/laser assembly.
Jun 19, 2009 | Xerox WorkCentre XD130DF Laser Printer
L6 code on a Xerox XD130 DF
Yes, and L6 means the main board is not detecting the operation of the motor that runs the mirrors in the laser.
In order of probability , the laser is bador the main board.
Jan 14, 2009 | Xerox WorkCentre XD130DF Laser Printer
E7-03 error code on work center xe88 xerox
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Xerox WorkCentre XE88 Laser Printer
FLASHING ERROR 6 L
L6:The Main PWB sensed a Polygon motor lock signal error. 5-L6 only: Check the connector CN23 on the Main PWB and the wires and connectors on the Laser Module. If connector and wires are not damaged, replace laser module. What that normally means is the laser mirror motor has failed. That normal price for that item is normally over $300. Here is a parts dealer to contact to see if they have it in stock. https://www.partsdrop.com/store/
May 15, 2008 | Xerox WorkCentre XD120F Laser Printer
Xerox XD100
I have a XD100 Work Center with a L6 error code indication. After press "C" Clear (orange color button), followed by "Auto" (the most left small button) - exposure mode key; and "C" followed by "Auto" again, the copier starts to print and solved problem.
Nov 02, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox workcentre xd105f
Guest.
The L6 indicates the machine is not seeing the motor in the laser, that rotates the mirrors.
There are 3 possibilities, I will list them in order of probability.
1 The Laser unit itself.
2. The cable connection on the Main Board.
3. The Main Board itself.
The laser depending on the lens, Curved or straight is $323 and $393.
the main board will cost in the $250-$400 range depending on the vendor.
That is without labor.
Oct 29, 2007 | Xerox WorkCentre M123 Copier
Xerox WorkCentre M-24 Color Copier Logo
188 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
