Question about Sub-Zero Bottom Freezer Refrigerator
Ice forming inside of refrigerator
We get a little pocket of ice forming inside our Sub Zero refrigerator on the left side of the middle part of the frig. It only seems to happen during the summer months. Doesn't show up at all during winter. Any ideas? Thanks
SOURCE: Sub-Zero 550
Hi!
I had the same problem with my 550...several times the tech came out and used a steam machine to blow out the drain...which didn't solve the problem. Finally, they ordered a refrigerator drain heater from sub-zero (part#4201290) and this finally fixed the problem. Hope this helps...I'm not a tech, just a customer. K
Posted on May 19, 2008
22yooper
  • 828 Answers
SOURCE: Sub-zero Fridge not cooling and ice forming
The leak in the system can be located by a number of methods. First I would look for a slight sign of oil at the point of the leak. 10% of the compressor oil circulates with the refrigerant. Although the refrigerant will leak out as a colorless, odorless gas and be invisible to sight it will leave an oil trace. Electronic leak detectors can detect leaks as small as .5 ounce per year. If the leak is large enough it can be detected with simple soap and water which will form bubbles at the leak point.
Posted on Jun 01, 2008
  • 37 Answers
SOURCE: Side by side Sub Zero not cold enough.
I have the same problem with the same older model, and have kept the coils clean. I've reached the clockwise limit of the freezer control. I wish the answer were that simple. I'm hoping that the oppressive heat and humidity here (Louisiana) might be a contributing factor, but that might be just a dream, and I'll have to shell out for repairs. Still cheaper than replacing it though.
Posted on Aug 09, 2008
abhishek33
  • 1239 Answers
SOURCE: sub zero refrig - ice forming inside
HI This component is a heating element located on the evaporator coil. When the refrigerator or freezer switches to the defrost cycle, the defrost heater is turned on to melt the frost in the compartment. Failure of the defrost heater causes failure to defrost.Test the element with a VOM set to the RX1 scale. To gain access to the heating element, remove the compartment's wall panels. Clip one probe of the VOM to each element terminal. The meter should read between 5 and 20 ohms. If it doesn't, the heating element is faulty and should be replaced. Replace the heater with a new one of the same type and electrical rating. Connect the new heater the same way the old one was connected.
Posted on Oct 12, 2008
Krazytech
  • 725 Answers
SOURCE: Ice is forming inside the refrigerator
You have a freon leak in you evapator. Call an authorized Sub Zero service company it will be coverd by you sealed system warranty..
Ice build up
Hi
is it brand new?
Jul 15, 2008 | Sub-Zero 632 / S
Sub-zero model 532 side-by-side icing on inside panel
I would get in touch with SUB-Z customer service, they are the only company that still cares about customers
800.222.7820
They will be able to get it fixed
Jun 08, 2010 | Refrigerators
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Ice keeps forming inside on the back panel of mysubzero model 550
If the ice is on the back panel especially a block of ice in the middle left part of your panel, then you have a sealed system problem. Check to make sure that your condensor coils above the refer are clean, and if it continues to have an ice block then you have to have a technician come out an do a major repair. This is not something you can do yourself, most subzeros have a 6 to 12 year sealed system warrantee that covers either all of the repair or just parts. This is an expensive repair if it is not warranteed, but when the refers cost 8000 to 10000 new it is usually well worth it. Most often it is the result of a slowly leaking evaporator, though most inexperienced technicians replace the compressor first, so make sure you use an experienced Sub-Zero technician. Good Luck, Appliance Specialits
Nov 12, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 690 Refrig Side Ice Forming on Back Wall
replacing leaking evaporator on Sub Zero Video
Jun 09, 2009 | Sub-Zero 642
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Ice in Refrigerator Section
there are 2 possibilities. first the drain is blocked causing water to overflow from the defrost water gulley at the bottom rear of the inside of the fridge. this can form ice as it is close to the division between fridge and freezer. second, the .fault of ice growth can be caused by breakdown of the cabinet insulation. of the two, the first is the moree likely. to test drain is cloear, pour a little water down the drain. if it does'nt flow freely, push something flexible down the drain hole till blockage is clear
Apr 14, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero Bottom Freezer Refrigerator Logo
230 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
