Question about Panasonic Technics SL-1210M5 Turntable
Panasonic slh203 I have model number slh203 the belt broke and there is some type of rivit stopping me from taking off the top to get to the belt.. can you please help?? thank you
How do I change the belt on the 116 model?
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled..
Aug 02, 2012 | Kenmore Vacuums
My dryer model number MEDC400V heats up but the drum does not turn. How do I find the belt to see if it has broken?
There are 2 catches in the front corners about an inch in take a putty knife and push in to release the top. Also take out the 2 screws under the lint filter. Lift up the top. You should see the belt or not. Belt there pull on it to see if it isn't broke. Belt not there broken belt. To replace belt need to take of the front panel. 2 screws in the cabinet top corners. Take them out then front will come forward then you need to lift it up off some little catches on the bottom. Then you should be able to see where the belt goes.
Dec 28, 2010 | Maytag MEDC400V Dryer
Starter rope broke how do i replace it. toro super recycler mower. Removed the plastic engine cover and the recoil mechanism seems to be rivited down and I cant get in there to replace the rope. Please...
You have to remove the whole engine air shroud over the flywheel to gain access to the recoil and rope mechanism. If you need specific help on your exact model engine I need all of engine model type numbers 5 to 6 char then 4 char then 2 char i.e XXXXXX-YYYY-ZZ for B & S Honda numbers are by the engine oil port on the base of the crank case. Thanks for using FixYa, Kelly
Apr 22, 2010 | Toro Lawn Mower With Toro Power Tools
Belt part number and doesnt stop at end of cycle
Go to an appliance parts store and take the belt with you. They can get you a new belt and probably the timer control unit.
Mar 26, 2010 | Dryers
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
I think belt broke need to replace
Go to maytag.com then service and parts then use and care manuals then model no. hopefully you can find info. there if not call customer care 800 number. Most times you have to remove the top of dryer then the front to get to the belt. You will have to locate what type fasteners it uses some use a snap lock type fastener others use screws.
Apr 07, 2009 | Maytag Dryers
Belt broken a a Kenmore model 116 canister vacuum
Greetings from GoVacuum.com,
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Sep 29, 2008 | Vacuums
Belt type
The belt number is 91001028. The belt will be snug but not real tight, so the belt you got may not be the right one. Most repair shops for vacuums should have this belt in stock.
Jul 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Panasonic Technics SL-1210M5 Turntable Logo
64 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
