Question about Garden
The self propel on my Honda Harmony 215 is not working. I don't have a manual. Can a manual be downloaded or is there a simple solution to this problem. I am a widow and I don't work on lawn mowers :) Thank you for any help!
  • 109 Answers
SOURCE: Honda Harmony mower, self propelled hydrostatic,
If i remember correctly, under each drive wheel, there is a small gear, and under each gear there is a small metal rod that is what the transmission uses to propel the mower...it sounds like the rods either have dirt on them or they are just stuck and can not move to allow you to pull it backwards
Posted on Apr 26, 2009
  • 59 Answers
SOURCE: Have honda harmony 11 HR 216 that stopped being
it has a belt look under the mower
Posted on Jun 26, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
I have an old Honda Harmony HRM-215 lawnmower. The first time I used it this year it worked fine, now I have to leave the choke on fully just to get it to run. Even after an hour of running, choke must be...
The air filter may be dirty, have a look at these tips for troubleshooting lawnmower startup problems:
http://www.fixya.com/support/r9118692-lawnmower_not_starting
May 25, 2011 | Honda Garden
Honda Harmony mower starts but will not stay running
rebuild the carberator. easier said then done huh. anyways, thats your only soluation. hope this helped you
May 28, 2010 | Honda Garden
Honda Harmony self propelled not propelling. Belt is fine. Cant find adjustments
Do you know for sure that the belt is not stretched. Make sure also that it is on the pulley correctly and the pulley is spinning with the shaft you also might have spun a key.
Oct 08, 2009 | Garden
Honda harmony self propelled cable snapped at end
Get a replacement cable, part number should be in your user manual...when you get the cable it should have directions on how to replace.
Sep 08, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have an older Harmony II HRT 215. The drive
the best thing to do is take the model number and order a belt from honda which will be the right size and thickness
Aug 09, 2009 | Garden
The pull cord does not pull easily or not at all on my honda harmony 2 self propelled lawn mower; it is also vibrating more than usual
Could be a couple of things,if it has been left out in the weather the flywheel could have collected rust and gathered between it and the armiture making it hard to pull. But with the vibration it almost makes me think that your engine shaft is bent. Take your plug out lift the front end up and manually turn the blades,if theres an inballance you should see it.
Honda Harmony mower, self propelled hydrostatic, wheels lock up when pulled backward. Going forward no problem.
Apr 25, 2009 | Garden
Garden Logo
295 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
