Question about Casio Cell Phones
LOOKING FOR DICU731 USB CABLE FOR MY GzOne rock
Wont charge says usb tried six different chargers
Try new battery. Check mini usb port of your cellphone for mis-align contact pad or pin
Mar 10, 2015 | Casio Gzone Commando C771 - Black verizon...
Cannot find USB modem driver
try using a blackberry usb cable cord with blackberry emblem on cord
Jan 28, 2013 | Casio Verizon Gzone Ravine 2 C781 Rugged...
Gz one boulder will not turn back on..it quit on me one day and iv chaged it and it stl ownt turn on
I am re-posting the following answer from a similar question..
Connect to the charger just long enough for the screen to power on, then immediately disconnect the charger before it goes into charging mode. . -- It should power up and be ready for use.in a couple seconds.
I have found that only when the battery gets completely drained, that the Gzone Rock often will not power back up on it's own, even though the battery has been successfully recharged.
By connecting the to the charger it will initiate the boot-up of the phone - but you must remove it before it displays the charging screen again, otherwise it still won't come on and boot.
Sep 10, 2011 | Casio G'zOne Rock Cell Phone
The phone won't take a charge. The red light comes on indicating that it is charging but it doesn't. What's the deal?
Try this.. as it works for me on my GzOne Rock..
I don't know why, but this method works for my GzOne Rock every time.
Jan 31, 2011 | Casio G'zOne Rock Cell Phone
We need to plug a usb wire into a as rock mb10lrm
Here is a diagram of the connector block you are looking for and were the wires go to the pins. hope it helps.
Feb 02, 2010 | Asrock M810LMR Motherboard
I am told that my Gzone does not have bluetooth. and there is no way to get a bluetooth adapter for it. Is this true?
The ONLY GzOne phone without Bluetooth capability is an older model Type-V. All other GzOne Verizon phones have Bluetooth. If you would like to specify which model you have I can direct you to enable it.
Jul 10, 2009 | Casio G''zOne Type S Cellular Phone
Not Reading Peripherals - i-rocks IR-4100 4-Port USB Hub
If your looking for a good quality USB hub, i would go with a Belkin. They do cost more than most other hubs, but from the 8 years i have been at my retail store, they have had the lowest return rate of all that I have sold.
Aug 25, 2007 | i-rocks IR-4100 4-Port USB Hub
Cell Phones Logo
386 people viewed this question
Top Casio Cell Phones Experts
Oloyede Monsuru
ray gallant
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
