Question about Panasonic GPS
Were can i get a panasonic car key battery from cr 1818 3v
What batteries can i use instead of smashing batteries? Duracell ?
That camera takes lithium batteries. Duracell are DL123. Others are Energizer CR123 or Rayovac CR123A. The 123 is the key here. Other makers of lithium disposable batteries will use different letters, but the 123 is what you're looking for. They should still be available at Walmart etc. Panasonic CR 123APA 1B CR 123A Photo Lithium Battery Retail Pack Single
Mar 02, 2015 | Samsung AF Zoom 1050 35mm Point and Shoot...
What size battery for 2006 ridgeline key remote?
The replacement is a #CR-1616 which is actually a fairly oddball battery that I found at a Walgreen's store. It wasn't available in the 'Big Box' building supply store near me, in CVS pharmacy or in Walmart. It's a 3 V. lithium battery.
For more details try the following link:
Thread Key fob battery replacement
Feb 12, 2015 | 2006 Honda Ridgeline
Remote not working can't start car with key
You can replace the battery of key and get it again working...
I have one video which shows how to replace battery in Swift Key, Honda has exactly the same procedure.
Honda Car uses CR 1616 battery which you can get from any watch repair shop...
Sep 06, 2013 | 2003 Honda Civic
Car will not start.It turns over but will not fire.Remote key control is out.Fuelpump is OK. Battery is new.There must be some electrical short somewhere.Do not have access to a code scanner.75 miles away...
equipped with an SID (Saab Information Display) unit that displays various information about the amount of fuel left, the radio station you're listening to and the key's battery status. It is time to change your key batteries if the key stops working or responds slower than usual. The SID on your car will also say "Replace Key Battery." Saab keys use either a CR 2032 or a CR 1632 battery depending on key type. There are two types of keys. The first generation key has one key and a transponder and the second generation key is a one piece key with a built in transponder.
First Generation Key
  • 1 Loosen the single screw that is located by the key ring. Use the small Phillips screwdriver to remove the screw that is on top of the transponder.
  • 2 Lift the plastic top. Remove the old battery and insert the new CR 2032 battery.
  • 3 Put the transponder back together and tighten the screw using the Phillips screwdriver.
  • 4 Press the alarm five times to re-synchronize the transponder with your car.
  • Second Generation Key
  • 1 Push the plastic catch with the pushpin to open the cover latch. The transponder has a plastic catch that is hard to depress. The pushpin will separate it.
  • 2 Lift the plastic cover. Remove the old battery and replace it with the new CR 1632 battery. Position the battery properly.
  • 3 Put the cover back and press the plastic together.
  • 4 Test the transponder with your car to make sure it is working.
  • Dec 02, 2010 | Saab 9 5 Cars & Trucks
    How do i open the key fob to replace the battery
    For 2009 Cadillac CTS
    Remove the hidden key by slipping a small screwdriver or knife under the metal endcap and lift. The key will come out. To replace the battery, pry the two halves of the main plastic housing apart, exposing the CR 2032 battery.
    May 17, 2010 | Cars & Trucks
    What battery goes into a Panasonic fax 8100 and where does it go?
    On the right side of the keyboard, remove the chrome screw and pull the battery out. CR-2032
    Mar 12, 2010 | Panasonic UF 8100 Plain Paper Laser Fax
    Panasonic Panafax UF-885 low battery on display how do you change the battery and what size is it and where is it
    Pull up and open the doc feeder. Push the large white tab hanging down towards the rear to release the battery holder....it's hard to do.
    The battery is a CR-2032 available anywhere.
    If there is no white tab to push, somebody has lost the battery holder.
    Oct 08, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
    Coolpix 2200/3200 Battery Compatibility
    The Coolpix 2200 / 3200 camera is designed to use 2 (two) AA type batteries. Due to Nikon’s advanced power management technology, two standard AA Alkaline batteries can provide more than 100 photographs. For better performance, please consider using Nikon EN-MH1 rechargeable batteries. These are available as an optional accessory at Nikon dealers and at The Nikon Mall Recently a new type of battery, the CR-V3, has been released to the market from several battery venders. The CR-V3 is similar in shape to two connected AA batteries and easily fits in your Coolpix camera compartment. Nikon has confirmed compatibility only with the following battery brands. Please use one of the following brands when using CR-V3 type batteries. Duracell Sanyo Panasonic Due to it’s unique design the Eveready Energizer® brand CR-V3 battery may not be compatible with the Coolpix 2200/3200 camera.
    Aug 30, 2005 | Nikon Coolpix 2200 Digital Camera
    Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
    GPS Logo
    932 people viewed this question
    Top Panasonic GPS Experts
    Richard Foster
    Richard Foster
    Will Halftowaite
    Are you a Panasonic GPS Expert? Answer questions, earn points and help others
