Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Ice chute door does not open
Is the solenoid easily fixable? where is it located? I can manually push it open.
  • dalelh May 05, 2008
    Thanks for your help. Fixed it in under 30 minutes and saved some money. Thanks again!!!
    Scholar:
  • 150 Answers
The solenoid is right beside the ice chute door. there is an arm coming off he door to the side and the solenoid has a stirrup hooked to the arm. you have to remove the trim surrounding the dispenser area to access this stuff. you don't repair the solenoid you replace it. ca. 20 bucks for the part
Posted on Apr 25, 2008
  • andrew kinslow Apr 25, 2008
    oh yeah thats if your unit has a solenoid you didn't give me make and complete model so you may have a unit that uses a different system but what I described is 90 percent of them out there
Where can I get a replacement solenoid switch for my LG LFX25980ST?
Hi Bob,
this is the part number #6421JB2002L you can get it easily online in various sites like sears, appliancepartspros, etc.
hope this helps.
May 30, 2014 | LG Lfx25980st French Door Refrigerator...
Lg lmx25984 ice chute flap will not open automatically
On Mine, the solenoid connection fell off that allows the ice to dispense, Thank you so much!
Aug 04, 2012 | LG LMX25984ST 24.7 Cu.Ft. French 4-Door...
The ice chute door (flap) is not opening. Is it supposed to open from the weight of the ice dropping on it, or is it somehow connected to the ice lever in the door when you push on it?
Most Ge refrigerators have a solenoid that is in the door that opens the ice dispenser door. It activates when you push the lever it activates the micro switch. Then sends the signal to the board that sends power to the solenoid and opens the flapper door. Most times the solenoid is either rusted or stuck. You can get part at local appliance parts store but it gets involved to take door apart to repair if one has never done it before. As always if you are not comfortable trying the repair please call a local service technitian.
Nov 12, 2010 | GE GSS25LGM Side by Side Refrigerator
LFX25970 Bottom Freezer Refrigerator This morning it began to make a clicking noise coming from the ice/water dispenser and cold air was coming down from the opening. I pushed the lever for ice and it...
You may have an issue with one or more of the following:
* icemaker
* dispenser actuator
* ice chute door assembly
* ice dispenser solenoid (if the solenoid is stuck in an open position, the ice chute door/flap would remain open allowing cold air to escape).
Contact an appliance service company.
Feb 16, 2010 | LG Refrigerators
Flapper in ice chute remains in open position.
Solved via another post. Appears that the solenoid that moves the flap needs to be replaced. Already ordered the replacement. It's easy to remove the plastic facing without removing the entire trim around the chute opening. About one inch in at the inside top of the chute area there are three small holes. Starting with the leftmost hole, use a small phillips screwdriver to push up while using the other hand to pull out on the left side of the plastic part that houses the water/ice selection buttons. Then do the center one, followed by the rightmost one. That exposes the inside plastic housing which is removed by taking out the four screws. Its easy to get to the solenoid that has to replaced - unclip the wiring and remove three screws. Then reverse the process.
Jan 02, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
The ice dispenser chute sticks open allowing warm air into the freezer. Once the chute sticks open, you have to reset it manually but sticking your hand into the ice chute in the door.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Aug 15, 2009 | Refrigerators
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice chute door on maytag refrigerator
the door is opened by a solenoid. it is bad or it is not getting voltage due to bad control or wiring
Apr 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Oct 02, 2007 | GE 17.2 cu. ft. Top Freezer Refrigerator...
Ice maker chute door
Here's a location for a schematic to let you see what's all inside there. http://www.partselect.com/Schematics/Whirlpool/VM1P3RPM.gif
Dec 27, 2006 | KitchenAid Superba Architect KSCS25INSS...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
89 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
