Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
Set time on the keyboard - Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
I have a toshibe laptop want to change my password how do i do it
Boot up or restart your Toshiba laptop.
Immediately and repeatedly tap the F2 key on your keyboard until the start screen appears to change your BIOS (user) and supervisor
(HDD user) passwords.
Use the arrow keys on your keyboard to highlight "Set User Password" or "Set HDD User Password" and press "Enter" on your keyboard.
Type the current password in the box that appears.
Type your new password ox.
You will be asked to enter your new password a second time to confirm it.
Sep 08, 2012 | Toshiba Computers & Internet
How do I turn off French characters
Hello.
try pressing the left CTRL + SHIFT keys at the same time to switch it back over (You might need to press them a couple times).
From regional settings (regional and language settings) keyboards/change keyboards, you can remove all the keyboard you don't use and leave only the one you need.
Good luck
Jan 31, 2011 | Logitech (9673120403S) Keyboard
How can I set the correct date and time on my Logitech MX 3200 wireless keyboard?
"To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously." Also "LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer." The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse. Good luck.
Nov 10, 2009 | Logitech Wireless Access Duo Optical...
Every time i type@ the "comes up and vice versa.any solutions please
check if the keyboard layout setting is set to the same layout as your keyboard on your desk. this can be found on the bottom of your keyboard. the settings can be adapted in start -> control panel -> regional settings.
Oct 12, 2009 | E-Machines AAFQ50400000K0 Keyboard
How do I set my keyboard date and time?
1st, if your time display is not shown on the LCD, press FN and F9 at the same time until the display appear. Press FN key and F10 key at the same time to go into SET mode. Use the arrow key to select and set your correct time. Press ENTER when done.
YBC (/\)
Sep 03, 2009 | Logitech Cordless Desktop MX3200 Laser...
I have a mx3200 cordless keyboard that has a clock and date window. The alarm clock goes off at 2:00pm how do i turn it off? Do you have a manual I can download?
got this off the logitech forum, The only instructions that I can find (which came with my relatively new pc) are on a large "Installation Guide," the most pertinent information from which is about setting the time and date: "To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously." Also "LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer." The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse. Good luck.
Jan 31, 2009 | Logitech Cordless Desktop MX3200...
I can't set the date and time on my Logitech MX 3200 cordless keyboard. How do you do this?
1st, if your time display is not shown on the LCD, press FN and F9 at the same time until the display appear. Then press FN key and F10 key at the same time to go into SET mode. Use the arrow key to select and set your correct time. Press ENTER when done.
YBC (/\)
Jan 23, 2009 | Logitech Cordless Desktop MX3200 Laser...
I can't set the date and time on the keyboard
YBC (/\)
I cant set the clock on my keyboard
To enter the time/date setting you must press the FN key
then to set the date/time press the F10 key.
I hope this solves your problem. If not please check the forums.
Dec 15, 2008 | Logitech Cordless Desktop MX 3000...
Setting the date and time on the keyboard
Hi Wlingrell,
Thanks for your posting in FIXYA.
Go To Control Panel --> Open --> Date and Time --> Click on Change Date and Time,, set the exact date and time.. Next time you will get the correct time and date on your PC.
Please use this link to obtain the manual if your Keyboard is of Logitech:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=8040&p_created=1204577470&p_sid=8gAUtIdj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD02NCw2NCZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Db3JkbGVzcyBEZXNrdG9wwq4gTVjihKIgMzIwMCBMYXNlcg**&p_li=&p_topview=1
Best of luck
Ellin
Sep 11, 2008 | Logitech Computers & Internet
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
53 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
