Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Champion Liftmaster Garage will not open or close. Just clicks
Lightning hit the house during bad storm and my power went out for few seconds. Went to my garage and the lights on both garage doors were on. I have a surge protecter on both garage doors but now one will not open or shut. I have tried the wall button and the remote and the garage opener just clicks and it wont go up or down. Is there an easy fix that I can do or will I need to call a technician out to repair this. What would an estimate cost be?
    President:
  • 3,197 Answers
Pull the logic board and check for burnt or missing traces on the printed circuit. I would guess at an estimate of $125.00 but don't even know where you live.
Posted on Aug 02, 2010
Liftmaster 3265M. Two units. Why does neither work since lightning storm?
Chamberlain Liftmaster garage door opener problems ...
? 3:10
https://www.youtube.com/watch?v=Zq_CxeTXoSM
Jul 2, 2013 - Uploaded by Mike McCarron
Might have taken a lightening strike, knocked out GFCI that was on the circuit that garage door opener was on. When I ... And sometimes after it happens it takes 30 or so seconds before the opener will work again. ... The keypad unit worked well butneither the homelink or the remote units worked.
Garage Door Openers - Lightning Strike - Forum - Bob Vila
www.bobvila.com/posts/30883-garage-door-openers-lightning-strike?...
Aug 6, 2005 - The house did not lose power and I do not believe the house was actually hit. ... the light comes on on the unit (as expected), but neither door opens or ... Afterplugging it back in, try opening the door with the hardwired button first - if it still doesn'twork, chances are your opener's taken some damage but not ...
I Have A Liftmaster Garage Door Opener Unit. The Remote Work ...
www.diyforums.net/i-have-a-liftmaster-garage-door-opener-unit.-the-re.
Jan 01, 2016 | Building Materials
In the past ten years I have replaced the logic boards nine times. When a storm hits with lighting I loose the board due to surges. I have a G.F.I.out let, surge protector, and I have put a grounding rod...
Chamberlain makes a surge protector that is made specifically for their openers. I would try one of those. The part number is 990LM and should be available from any service company in the yellow pages that advertises Chamberlain or Liftmaster. Unfortunately as you have learned, lightning loves logic boards.
Aug 21, 2011 | Sears Craftsman LiftMaster Chamberlain...
After a lightning storm, my LIftmaster Formula 1 garage door opener will not close without continually holding down the garage door button on the wall. If you push the button once and then let go it will...
If when the door reverses the main light flashes 10 times you have a problem with the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. They must be pointed at one another for both lights to be on. If you cannot get the lights to come on you have a bad logic board.
Jun 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have a Craftsman 1/2 HP auto gargae doors. Lost power during a snow storm. Once power was reconnected only thing that did not work was garage doors. Is there a reset button somwhere....can't see one.
There isn't a reset button. Check the house circuit breaker. You may have had a power surge and that can damage the logic board printed circuit. Check the logic board for missing or burnt traces especially around the small transformer.
Feb 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
No reponse when using the remote, the wall control works fine.
The remotes use a receiver to actuate the door and the wall control does not. It sounds like your logic board is bad. Maybe a lightning storm recently? Try removing the board and look for burnt or missing traces on the printed circuit.
Sep 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener won't work after storm
Check to see if the trolley (the part that slides back and forth on the rail and is connected to the door) is jammed against the bolt just in front of the motor unit. If so, remove the bolt and run the door until it is closed. On the side of the motor unit there is an 'up limit' control. Turn this 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Jun 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garrage door opener not operating after thunder storm
If you had an lightning storm you most likely have a bad logic board. That is not a reset button you are pressing.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears 1/2hp thinks it is not all the way up and will not go down
It is really a common problem for lightning or electrical surges to take out the logic board. Big expense too.
May 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Opener wont open makes clicking noise
Your opener has been hit by lightning or power surge.
If it's not too old you can replace the 'back board' (the computer board on the back of the opener.) Also If the opener has safety sensors one or both of them may be burnt out too, and if it was really bad then the rpm sensor will go too. So you could be looking at paying half the cost to repair or just get a new opener. Up to you, and get a surge protector. Lift master has a good line of products and makes thier own surge protectors for thier products.
Jun 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
437 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
