Question about GE JVM1650 1000 Watts Microwave Oven
Asks for " Set clock" all the time
3 Yr old unit does not keep time. Always says "set Clock".
When clock is set, (occassionally) then, unit works.
Is there a solution?
  • debb1e Apr 26, 2008
    thanks.
    Is the smart bd. easily accessible from front/back/top/bottom? Is the replacement an easy job?
    thanks a lot for your help.
Replace main smart board
Posted on Apr 25, 2008
Set clock on Omega 00652XN oven it has 3 buttons
Turn the oven off at the wall. When you turn it back on the clock will flash. Use the + or - to adjust the clock then use the middle button to scroll through the duration, start and end times of the auto cook function until you end up back at the clock. The oven symbol will always be displayed in clock mode unless the auto cook function is set.
Hope this helps.
Craig.
Aug 15, 2011 | Microwave Ovens
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
Sep 21, 2009 | Sharp R-1480 Microwave Oven
Set clock time on microwave oven
I have consulted the Owners Manual and there is no mention of the demo mode. I would suggest that you unplug the unit or disconnect power if it is hard wired in, and try to set the clock then.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Jul 04, 2009 | Panasonic NN-SN657SMicrowave Oven
Clock and timer on Whirlpool GH7155XHS micro/hood are running slow. Clock loses about 10min/hr and kitchen timer countdown is slow.
I've just fixed a very similar problem with a 10-yr-old NEC microwave oven.
Disconnect AC power, take the top cover off, go through the unit and tighten all screws, particularly those connecting ground wires to the chassis and those fixing major components like the power transformer and magnetron to the chassis.
May 28, 2009 | Whirlpool GH7155XHS Microwave Oven
Reset clock, ge spacemaker xl1800 times out after 2-3 seconds
There's a simple fix for this. Unplug the unit. Take off the top grill with 2 screws. Remove the 1 screw that holds the touch pad unit. Lift up on touchpad unit and lift out. Put a piece of aluminum foil inside a large zip lock bag and tape it to the back of the touchpad unit and reassemble. GE put the magnetron to close to the control board causing stray microwaves to interfere with the board. The foil shields it.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sanyo microwave clock reset
This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
  1. Unplug the unit for a minute then plug unit in.
  2. Press the clock (clock/timer) button once.
  3. Using the keypad, input the time you wish to set.
  4. Press the clock (clock/timer) button once.
  5. Press the stop/clear button, Time should remain.
Hope this works, if not, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
Apr 12, 2009 | Sanyo Microwave Ovens
How do you set the microwave clock?
After setting the time push the clock button again and it should start working after a minute passes (on some models you have to hit the start button after setting thr time!
Please rate this response
thank you!
Jan 26, 2009 | Microwave Ovens
Toshiba micriwave time setting
These manuals are no longer available, but maybe one of these key combinations will work:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Please let us know how it goes.
Nov 04, 2008 | Microwave Ovens
Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
Sep 06, 2008 | Westinghouse WST3501 Microwave Oven
Thermador microwave from oven/micro/warming drawer not keeping time correctly. clock is shaking and running 3-4 hours behind.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Aug 21, 2008 | Thermador Microwave Ovens
GE JVM1650 1000 Watts Microwave Oven Logo
104 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
