Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Sd 51 - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 5,081 Answers
The F51 fault code on your Cabrio washer indicates that the control board is not sensing the proper drive motor spin. To clear the fault code, press the Pause/Cancel button
In addition to the above tips, check the installation of the drain line. Make sure that the drain hose is not stuck way down the stand pipe. This can cause siphoning of fill water which will inhibit proper motor rotation.
Check to see if the wash basket spins freely. If it does not, you may have an item of clothing stuck between the outer tub and the inner basket. This restriction in rotation will also cause an F51 fault code.
If these tips do not help you resolve the F51 problem, then you probably have a component failure. Possible failures include: wire harness or wire connection problem between the machine control and the RPS sensor (Rotor Position Sensor), a failed RPS sensor, a failed drive motor, and a failed machine control board. You will probably need a technician to diagnose and repair one of these component failures in your washer.
Posted on Aug 02, 2010
Alienware area 51 card reader not recognizing 64gb exfat sd card
I would check you have all the latest updates for your Vista installation as I know for some versions of Windows extra updates are necessary for exfat support.
Does the SD card read; is it accessible; in other devices?
Mar 19, 2014 | Alienware PC Systems Alienware Area-51®...
Card slot
Yes, the CF-51 has an SD card slot. It's on the front of the machine, near the right end.
Jun 06, 2013 | Panasonic Toughbook CF-51 Notebook
Where do I find a 51 inch screen for my rear projection tv
try ANDREWS ELECTRONICS IN LOS ANGELES, THEY ARE THE LARGEST OEM PARTS DEALER IN THE USA, Most Hitachi sets sell the screens as a set (there are two and they sell them as a complete unit.
Andrews has a 800 number you can call and get a quote on the screen unit, They can also be found on the internet.
let me know if you need help, I am here to help.
SD TECH
Dec 28, 2010 | Hitachi 51F59 51" HDTV Projection...
I replaed the convergance chips and still have a red shadow on my sony 51 inch projection tv
This set has two 5 amp fuses on power board that feed the convergence circuit, did you test them?
I needed I can provide photo of that board, fuses are pico fuses and not glass.
Let me know and I will be happy to help you.
SD TECH
Nov 06, 2010 | Sony KP-51WS510 51" Rear Projection...
Left side of sreen is blurry/halo effect. Right side is normal. Magic focus stops when it gets to green and flashes green number 5 on bottom left of screen. (Hitachi 2003 51" projection HDTV)
SET uses two of the STK-392-150 convergence chips for this, both need to be replaced and set adjusted.
Parts cost on EBAY will be under 25 dollars. I can help if you are do it yourself person. A shop will get 250-300 for this but you can do it for much less.
Can I assist you?
SD TECH
Sep 15, 2010 | Hitachi 51F500 51" Rear Projection...
How do i contact SD Tech to send him a picture of the streaks on my tv
YOU CAN DO IT RIGHT HERE, PICTURE HAS TO BE UNDER 150 KB3f74c74.jpg50 KB; NOTE ABOVE(YOU TUBE ETC---ONE IN MIDDLE WILL ALLOW YOU TO UPLOAD PICTURE HERE.
IF THIS FAILS OR YOU CANNOT DO IT, CONTACT LAUREN@FIXYA.COM OR SUPPORT@FIXYA.COM
SD TECH
SEE PHOTO I ATTACH HERE:
Aug 20, 2010 | Sony KP-51WS520 51" Rear Projection...
Hello i just bought a Digital Concepts 51-in-1
more times out of 10 the SD card is either damaged or being inserted incorrectly. Are you sure you have it the right way up. Look into the slot and not where the gold terminals are and the insert the card so those terminals match the terminals on the card itself
Please rate my help++++Thanks for using FIXYA
Jun 29, 2010 | Computers & Internet
My Toshiba 51 inch projection tv has red squares on screen
The model indicated is a projection set and the question is does it look 3d looking etc or something else?
See attached photos of typical convergence problem which MAY be what you have.
SD TECH
May 02, 2010 | Toshiba 51H83 51" Rear Projection...
Bad color then no power on 51'' panasonic cinemavision
Check the power light for blink code--usually if this model shuts down the power light will blink in a sequence--3 blinks a pause and 3 blinks is short protection--usually means a convergence circuit problem.
Let me know what you find--I am here to help.
if this helped you rate this solution as I do this here for free.
SD TECH
Dec 17, 2009 | Panasonic PT-51HX41 51" Rear Projection...
SD card problem
Format the SD card using camera's format function. The SD card should work without a problem. BTW, what do you mean by Camera type: Qv-R41/Qv-R51? The camera should be either 41 or 51. 41 is 4MP and 51 is 5MP. Which camera do you have?
Sep 12, 2005 | Casio QV-R41 Digital Camera
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
205 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
