Question about Mitsubishi WD-52525 52" Rear Projection HDTV
When I press power button, it shows green light and cuts right off. Remote control not responding.
  • insider11 Aug 04, 2010
    Nettiser, you are right on the money. This is essentially what my TV Repairman said yesterday. He will replace all circuit boards (part(s) $175) and $150 for labor; guaranteeing several more years of service. He also added that this is a very good tv and will outlast the newer models for sure. Says he has many '08, 09' and 10' models to repair. Again, thanks for your expertise!
  • Shahid Electronics
    Shahid Electronics Aug 08, 2010
    sustain boards?????????????????
    Brigadier General:
  • 4,090 Answers
Fail safe circuit is indicating a voltage variance either in the power supply or on the sustain boards. It does this to preserve unaffected components. It needs investigation and repair. It also pays not to continue trying to get it to work as it could combust.
P{lease rate my help++++Thanks for using FIXYA
Posted on Aug 04, 2010
Testimonial: "Nettiser, you are right on the money. My TV Repairman essentially said the same thing. Circuit boards need to be replaced. Thanks for your expertise!"
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
protection circuit. Wait for the light to stop flashing and turn TV
on.
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
Program code for Directtv Universal remote.
You can see an easy step-by-step guide to programming your remote right on your TV screen:
sm_cl_blu__number1_icon.pngPress MENU on your remote control sm_cl_blu__number2_icon.pngSelect Settings & Help sm_cl_blu__number3_icon.pngSelect Settings sm_cl_blu__number4_icon.pngSelect Remote Control sm_cl_blu__number5_icon.pngSelect Program Remote and follow the on-screen prompts img_remote_control_tv_sol1.jpg You can also use the manual method below: sm_cl_blu__number1_icon.pngMake sure your TV and your receiver are both on. sm_cl_blu__number2_icon.pngUse this tool to look up the 5-digit code for your TV. There could be more than one code for your brand of TV. sm_cl_blu__number3_icon.pngSlide the MODE switch on your remote control to the TV position. sm_cl_blu__number4_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number5_icon.pngUsing the number buttons, enter the 5 digit code for your brand of TV. The green light under the TV should flash twice. sm_cl_blu__number6_icon.pngAim the remote at your TV and press the VOLUME UP button. If the volume doesn't increase, repeat Steps 3-5, trying a different 5-digit code for your TV. If your remote control fails to program using all available codes, try scanning for additional codes. If one of the codes worked, proceed to the next step. sm_cl_blu__number7_icon.pngPress and hold MUTE and SELECT buttons until the green light at the top of your remote control flashes twice. sm_cl_blu__number8_icon.pngEnter 9-6-0 using the keypad on the remote control. The green light should flash twice again. sm_cl_blu__number9_icon.pngSlide the MODE switch on your remote control to the DIRECTV position. img_remote_control_tv_sol2.jpg Follow these steps to scan for additional TV codes using your DIRECTV remote: sm_cl_blu__number1_icon.pngSlide the MODE switch on your remote control all the way to the right to the TV position. sm_cl_blu__number2_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number3_icon.pngUsing the number buttons, enter 9-9-1. The green light on your remote should flash twice. sm_cl_blu__number4_icon.pngAim the remote at your TV and press CHAN/PAGE UP button. Tap the CHAN/PAGE UP button repeatedly until the TV powers off. sm_cl_blu__number5_icon.pngWhen the TV powers off, press and release the SELECT button. Note: If the green light flashes three times before your TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, but your TV may not be compatible with our remote control.
Jul 08, 2014 | GE JASRM24912 Remote Control
Tv says receiver is not on and do not respond to remote control
Hi Jackiewes928, I apologize for the inconvenience you have experienced. It is my pleasure to assist you today. I understand that the only channel you are currently getting is channel 116 and that your remote is not responding. Do any buttons at the top light up on the remote when you try to change channels? If so, what button lights up in red or green? if any button other the SAT button lights up this means that the remote is not on SAT mode and this would be why is not responding. In order to put the remote in SAT mode press the SAT button for 3 seconds. Once you do this try using the remote. If you need further assistance please feel free to reach me directly at kimberly.escobar@dish.com
Feb 06, 2013 | DISH Network IR Remote Control
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
Make sure your TV is turned on.
Slide the mode switch at top of remote to "TV".
Press and hold the MUTE button. This is located above the number 1 button.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
Then enter 9911, the green light on remote should flash twice.
Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Mar 08, 2010 | Televison & Video
"AMP" button on Sony RM-VL 900T stopped responding
Using the code search function: Press [S]. All Component Select buttons will flash. Press the button you want to configure. Press [CH+] or [CH-] and [POWER] in turn until the component turns on or off, then press [ENT] to save.
To reset all functions for a Component: Press and hold [S] until the green indicator lights. All Component Select buttons will flash. While holding [STOP], press the desired Component Select button.
Dec 27, 2008 | Sony RM-VL900 Remote Control
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Volume not responding on Direct TV remote
http://www.directv.com/learn/pdf/System_Manuals/RCA/RCA_DRD221RD.pdf
See Page 15.
Worked like a charm! Good luck!
Jan 31, 2008 | RCA DIRECTV Satellite Remote Control
Problem with channel changing
You must program the tv. Go into the MENU and find AUTO PROGRAM. Then program it and it should work.
Sep 11, 2007 | Sharp 27K-S100 TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
263 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
