Question about Garmin nuvi 885T GPS Receiver
No voice. Volume bar shows 100% the bar is not
No voice. Volume bar shows 100% - however the bar is not colored in. Navigation works fine.
  • 1,514 Answers
I assume you checked that the mute box is not ticked. If not check it at the same place as the volume. The most likely cause is that there is no voice selected. To select a voice, press Tools, then Settings, then Language, and then Voice. If a voice is not ticked then press one to select it.
It's possible that the voice files have been corrupted and will not work. IF this is the case connect your satnav to your computer and it should automatically download the latest version of webupdater from the garmin website. When updated you will have the option to download voices. Select the ones you want and follow the prompts and they will be downloaded to your satnav. You may then have to to repeat the voice selection process described in paragraph 1 above
Posted on Aug 02, 2010
Why doent my gps speak s
The things you'd want to check first are:
1. the volume of your speaker is not turned off ...
2. your GPS (navigation) software supports voice navigation - directions /commands ...
3. you have (installed & selected) a navigation voice (e.g. standard or computer voice)
4. you have done a "reboot" ... or "hard reset" ... to start the software up again.
If all of these are OK ... and you previously had heard navigation voice on your GPS ... but suddenly, there's no more navigation voice, then it is possible that the navigation software (voice portion) got corrupted. If that's the case, you would want to try to restore your software from backup (using HOME), or download a copy of the navigation software from TomTom.com (for your device type/class) and install it.
Dec 28, 2013 | GPS
The voice on the gps sounds weak like its dying out. i can't understand driving instuctions
sounds like you have it lower on the master volume
Try this... Tools.....Settings...Volume...press it ..now you will see ...Master ...Navigation.....Media make sure the Master is higher in percentage I have mine at 100% and keep my Media at 70% Navigation 100%
Nov 06, 2010 | GPS
Garmin navigation voice not working
First press the speaker symbol and check that the volume is not down fully or that the mute box is not ticked. If it is press the mute box to untick it or increase the volume. Otherwise follow the instructions below.
1. Press Tools, then press Settings (or Locale on some models), then press Language. You will see a bar for Voice. Press Voice and select a different voice. If this doesn't solve the problem it's most likely because the voice file has become corrupted. To replace the corrupted file.
2. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and connect your satnav to your computer. Install webupdater and your satnav will look for updates. After it's finished it will give you an option to download voices. Click the ones you want and press next. The voices selected will be downloaded to your satnav.
When you have removed the satnav from the computer you'll need to select a voice again as described in para 1 above.
Sep 30, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nuvi has no sound navigation working volume 100% mute not on
1. Pres Tools, then settings then language and select Voice. Try selecting a voice. This may solve your problem.
2 If not it's probably because the Voice file has become corrupted. Connect your Satnav to your pc and download the latest version of Webupdater from (http://www.garmin.com/products/webupdater/howtoinstall.jsp) and follow the instructions. When it's installed click next, tick the voices you want to download, press next and then finish.
3 You can change which voice you use then by following the advice in para 1 above.
Jul 23, 2010 | Garmin nuvi 255W GPS Receiver
My OnStar navigation no longer gives voice prompts for turns and such. Was working fine, radio mutes down but then no voice prompts play. Just started in middle of a drive. How do I get the audio voice...
I was told by on star that if you leave the drivers door open for 90 seconds and then lock all of the doors and wait until the next day the system will reset itself. I know this sounds like smoke and mirrors but it does work. Please let me know. Hope this helps.
Apr 22, 2017 | Chevrolet Equinox Cars & Trucks
I was told that 2006 dts had either onstar or radio/dvd/cd/gps system not both i spent over three hundred dollars at gm dealer for hm to diagnose this and that even though my dvd nav is factory it will...
ok this is what I just found concerning your issue.
Now this is just the beginning so Im sending this complete in sections for you.
  • Turn ON the ignition. The Cadillac emblem screen appears on the navigation radio.
  • Press the POWER/VOLUME button on the radio.
  • When the navigation disclaimer screen appears, press the I AGREE button on the display.
  • Press the NAV button on the radio. The display should show the current position of the vehicle. The navigation map should be clear and have clear color.
  • Press the voice switch on the steering wheel. Speak a valid voice command. The system should repeat your command and then perform the function.
  • Does the system operate normally?
  • Nov 10, 2009 | Car Audio & Video
    Can't get back the voice and how do i change it?
    on media player touch the volume button
    a window will open for navigation volume level
    mute may be on unmute turn up level
    May 30, 2009 | Tomtom ONE XL GPS
    Kenwood dnx7120 (automatic volume lowering stoped working)
    hit setup...then under AV setup...click over to the 3rd screen...and it should give you options for navagtion volume and and options for muting and overiding the sounds comming from the speakers either front left, right or both....
    Jan 02, 2009 | Kenwood DNX7120 Car GPS Receiver
    No Voice Guidance
    Are you sure the volume was up? There is a scroll wheel on the top right side of the unit (as you face it). Make sure it is turned all the way up towards the top of the GPS. You should see yellow bars in the right of the unit indicating the volume level. Also, when you turn the unit on, there is a button on the bottom right that looks like a wrench. Tap this, then press the down arrow on the bottom right. You will see an icon that says, "Volume." Tap it, then check that the "Navigation" volume level is where you want it to be (normally 100%, but that is up to you).
    Nov 27, 2007 | Garmin StreetPilot c550 GPS Receiver
    Garmin nuvi 885T GPS Receiver Logo
    177 people viewed this question
    Top Garmin GPS Experts
    Marvin
    Marvin
    Steve
    Will Halftowaite
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
