Question about HP LaserJet 3050 All-In-One Printer
HP-3050 priter is showing memory low in time of fax
After dialing for fax it is showing memory low press OK button. after pressing the button the fax is cancelled up.
  • 1 more comment
  • Anonymous May 29, 2008
    I have the same problem with simple text faxes. If I don't press "okay" my fax machine will receive the fax and print it as though there is no issue. Afterwards my printer no longer shows the error.
  • suban Aug 26, 2008
    after i dial a number the machine is showing "MEMORY LOW" on display unit, how to solve the problem ?
  • jack1234268 Oct 11, 2008
    it is not because of the length of doc. because my hp3050 does not load the doc before show this problem.
    i don;t know how to fix it.
Please perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
Posted on Oct 20, 2009
  • bn_bhrm May 28, 2011
    remov hardwaer printer hp 3050 and no ready
  • 62 Answers
How long is the doc.? is it text or text with graphics?
Try splitting up the fax doc, the fax memory on the device is to small
Posted on Apr 25, 2008
My 3050 suddenly refused to fax stating the memory is low. It has worked fine for several years. What is the problem today?
You need to clear the stuff out of memory.
Press the menu/enter button on the control panel.
Press the > button once to select Fax functions , and then press menu/enter .
Press to select Clear saved faxes , and then press menu/enter .
Press menu/enter to confirm deletion.
Jul 07, 2011 | HP LaserJet 3055 All-In-One Printer
Memory low on hp laser jet 3050. Please advise how to fix the problem. Thank you
solution: 1. Clear the fax memory. Here are the steps to clear the fax memory: a. Press the menu/enter button on the control panel. b. Press the > button once to select Fax functions , and then press menu/enter . c. Press or > to select Clear saved faxes , and then press menu/enter . d. Press menu/enter to confirm the deletion. NOTE: In addition to clearing the reprint memory, this procedure clears any fax that is currently being sent, unsent faxes that are pending redial, faxes that are scheduled to be sent at a future time, and faxes that are not printed or forwarded. 2. Enable the settings to print directly to the printer. Perform the following from the PC that has the printer driver installed: a. Click Start , Printers and Faxes , and check for the driver listed for the printer. b. Right-click the printer driver, and select Properties . c. Then click the Advanced tab, and check the print directly to the printer option. Click Apply , and thenOK . After performing each of these troubleshooting steps, try doing a print job and check for the results.
Jun 10, 2011 | HP LaserJet 3050 All-In-One Printer
FAX MEMORY FULL. PL. TELL ME HOW TO CLEAR.
To delete faxes from memory
1. On the all-in-one control panel, press Menu.
2. Press the > button once to display Fax functions, and then press the tick
3. Use the < or > button to select Clear saved faxes, and then press the tick
4. Press to confirm the deletion.
Feb 25, 2010 | HP LaserJet 3050 All-In-One Printer
Hp laser jet 3050 memory low does not allow me to receive faxes or even photocopy? What can I try to fix this problem?
Perhaps you could clear the fax memory.
Perform the following to clear the fax memory:
  1. Press the menu/enter button on the control panel.
  2. Press the > button once to select Fax functions , and then press menu/enter .
  3. Press < or > to select Clear saved faxes , and then press menu/enter .
  4. Press menu/enter to confirm deletion.
Dec 03, 2009 | HP LaserJet 3050 All-In-One Printer
My LJ 3055, it says memory is low. Pls let me know how to solve it
This can happen if your fax memory is full.
Clearing the fax memory Perform the following to clear the fax memory:
Its saying memory fill. and not letting me send nor recevie any documents.also no dial tone.
bmc1014 --
Here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Sep 18, 2009 | Canon PIXMA MX310 All-In-One Printer
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
How can i download users' manual. I need to get the automatic "9" out of the outgoing fax number.
Inserting a dial prefix A dial prefix is a number or group of numbers that are automatically added to the beginning of every fax number you enter at the control panel or from the software. The maximum number of characters for a dial prefix is 50.
The default setting is Off . You might want to turn this setting on and enter a prefix if, for example, you have to dial a number such as 9 to get a telephone line outside of your company telephone system. While this setting is activated, you can dial a fax number without the dial prefix by using manual dial. For instructions, see Using manual dial .
To set the dial prefix
  1. On the all-in-one control panel, press Menu .
  2. Use the < or the > button to select Fax setup , and then press c00597634.gif .
  3. Press the > button once to select Fax Send setup , and then press c00597634.gif .
  4. Use the < or the > button to select Dial Prefix , and then press c00597634.gif .
  5. Use the < or the > button to select On or Off , and then press c00597634.gif .
  6. If you selected On , use the alphanumeric buttons to enter the prefix, and then press c00597634.gif . You can use numbers, pauses, and dialing symbols.
To get the manuals visit the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=135&prodTypeId=18972&prodSeriesId=1140783
Regards,
Nikhil Gedam
Dec 16, 2008 | HP LaserJet 3050 All-In-One Printer
Low memory display on HP Laser Jet 3050
Hello All,
Super NVRAM init
1.
Mar 10, 2008 | HP LaserJet 3050 All-In-One Printer
Canon MP530 - Fax Memory is Full... How do I clear?
Check your ink cartridges and fill any that may be low. I got that error because one of the cartridges (magenta) needed to be refilled. The printer was storing failure reports in its memory until they could be printed out, leaving no room to fax new documents. As soon as the ink cartridge was replaced, the reports printed and freed up the memory to send out faxes.
Dec 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
HP LaserJet 3050 All-In-One Printer Logo
1,382 people viewed this question
Ben Johnson
