Question about Philips Magnavox DVD Player MWD200F
I cannot get the tray to go in! Its stuck somehow
    Problem Solver:
  • 14 Answers
The spindle must be completely down first and then the tray will be inserted. That is the standard mechanical sequence.
Posted on Aug 03, 2010
Cd player door won't open
cd/rw drive has shifted due to unit being bumped, Tray is binding or blocked. Remove the back panel. Remove 4 screws on the bottom holding cd drive. Now you can push the drive slightly back. On the left side of the drive there is a white nylon cam. Push in with a screwdriver and the tray will open so you can manually remove your cd. You should be able to cycle the tray open and closed now. Replace the four screws but cycle several times after tightening each screw. Replace the back.
Aug 30, 2012 | Crosley CR248 Turntable
CD Drawer will not open. Do you have any suggestions on how to fix
Does it look like it is trying to open but somehow it seem stucked? This would indicate a mechanical problem whic is most of the time due to loading mechanism has been misalligned.
Open the device so you can see the tray. The tray is removable. You to remove the tray manually and while it is removed plug the device in so it will go into it's default position. Then insert the tray back again.
Jun 01, 2011 | GPX KC218S CD Player / Recorder
Toshiba DVD player doesn't retract or load media. DVD carrier is stuck in the out position
There is a rubber band on the motor that opens the tray out to load the disc, somehow that must of slip off the motor. Or the motor itself went bad.
Oct 11, 2009 | Toshiba SD-5700 DVD Player
MY SIM TRAY GOT STUCK
well bro somehow u got take the turbo sim out from there.theres instruction on google o youtube on how to open a iphone without damaging it.wen u done with that let me knw..ill giv u instructions o how to unlock the iphone without the turbo sim where ull b able to get and make calls and also us sms.
cheeeerz
Oct 13, 2008 | Apple iPhone Smartphone
Ice maker problem
Clear the Ice tray by pressing the button under the ice maker. The problem is that the ice is in the first couple of slots is not dumping and the tray tries to fill again and over flows. I pressed the button and cleared the tray of ice (This will tilt the tray and twist it to empty it) that was re-frozen several times without dumping. My ice maker works perfectly after I did the above. I think the problem arises if the door did not close completely. I stopped hanging the dish cloth on the door and on my LG Dish wisher. I hope this helps
Oct 03, 2008 | LG LRSC26940ST 36" Side-by-Side...
Brother MFC 8460 N, all in one copier. Loud clicking noise (from tray area) when trying to make a copy, it will not do a copy now, says to load paper - tray has fresh, higher quality paper in it. Is this...
Make sure the stopper in the paper tray is snug against the paper. sounds like the paper is not properly in place and the tires are making the noise.
Could be it's trying to lift the tray and it can't, determine why; something stuck, out of place,
Jul 21, 2008 | Brother Office Equipment & Supplies
Lg wm-2277 dispenser tray
Hiya Vanch... disconnect the electric.. remove the lid screws at the rear.. slide from the front to the back with lid.
Depress the tab at the top of the drawer "gently" whilst easing the drawer from the machine.
Refit lid.. connect up to electric.. Sorted!!
Regards Faggly
Mar 19, 2008 | LG WM-2277HW Front Load Washer
CD tray opens only when there's a CD in it
Hi nolights
The disc clamp usually has a magnet in it so I would sugest the loading belt is slipping and therefore the motor can't overcome the clamp force.
A new belt should cure the problem
John w
Dec 21, 2007 | Audio Players & Recorders
Stuck Disc
I sould hope by now you have already taken your set to be repair your gears inside are either broken or striped .blessing from belize goodluck.
Mar 18, 2007 | Bose 3·2·1 II System
Philips Magnavox DVD Player MWD200F Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
