Question about Panasonic KX-T7885 Cordless Phone
Hi on panasonic kxt 7885 multi line cordless- the screen suddenly goes on " reset" mode like the unit has been turned of /on- and can't scan for base and beeps- if i squeeze handset a certain way it goes back to normal ,but only for a short time- tried to clean battery contacts- did not help- changed battery - didn't help. can you help with the cause of malfunction
JMuskovitz
  • 135 Answers
SOURCE: GE Phone Model 25881
Per the instruction manual, there is supposed to be a switch on the base (look on the back or bottom) for TONE/PULSE mode. Here is a link to the manual: http://www.home-electronics.net/GE/ProductDownloads/25881EE3_IB.pdf In the "troubleshooting" section, there is this entry: Dial tone is OK, but can?t dial out: Make sure the TONE/PULSE setting on the base is set to the type of phone service you are subscribed to.
Posted on Mar 04, 2007
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: panasonic cordless phone
You can get yours repaired at www.cordlessrepair.com , and if you send the handsets they will reregister them to your fixed base at no extra charge.
Posted on Feb 04, 2008
SOURCE: GE dECT 6.0 Cordless Model 28112 Series
phones say do not disturb and will not ring
Posted on Feb 28, 2008
  • 3 Answers
SOURCE: Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Posted on Aug 13, 2008
RETRIEVE VOICEMAIL FROM PANASONIC KXT-7731
In the settings menu there will probably be a menu for voicemail somewhere. There should be a number for connecting to the voicemail delivery service. If you are with O2 it is 901 in UK.
Aug 22, 2014 | Panasonic Kx-ta7731 Kxta7731 Kxt 7731 7731...
Increase number of rings
You can select the desired ringer patterns of the base unit and cordless
handsets. 4 patterns are available for each line. Your phone comes from
the factory set to pattern 1. Programming must be carried out
separately for the base unit and cordless handset(s).
Make sure that the base unit/cordless handset is in the standby mode.
Base Unit Handset
4 Enter the desired pattern using
the dialing buttons ((1) to (4)) for
each line. To move to another
line, press H or I.
• Each time you select a pattern, it
rings.
5 Press (ENTER).
• A beep sounds.
• To return to the standby mode,
press (EXIT).
1 Press (FUNCTION).
2 Press or until the arrow
points to "Ringer setting",
and press H.
3 Press or until the arrow
points to "Ringer pattern",
and press H.
• The current settings are displayed.
Ringer pattern
L1 L2 L3 L4
1 1 1 1
Feb 20, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
Hi I have a panasonic KX-T7730 and I need to connect it to my linksys PAP2T Device. but I haven't Voice Over It. can I use this device with KX-T7730?
The 7730 is a Panasonic Analog System phone. It plugs into a Key Service Unit and the line port plugs into the PAP2T device. Model numbers like KXT-A624/824 are examples.
Carl
Feb 18, 2011 | Panasonic KX-T7730 Corded Phone
I have a Panasonic KX-TG2730 cordless phone set. It is a single line phone. We had to unplug it recently and get new batteries for the phone. When we put the batteries in they worked on the phone but when...
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Jan 17, 2011 | Panasonic KX-TG2730 Multi-Handset cordless...
What to dial to access panasonic esa phone 616
Panasonic never issued a manual for R3. It was done with addendums that got you from R1 to R2 to R3. I think these are the right codes, but you may have to test them.
External page should be 33.
All Page (internal, I think) is 34. It's also the page transfer code.
Groups 1-4 are 35-38. (All phones are in group 1 by default)
43 is the "meet-me" code. It can retrieve any page or transfer to page.
Here's a link to a manual(s) if you need it.
http://public.carl.airpost.net/KXT%20Analog/KX-T61610_IM_PM
http://public.carl.airpost.net/KXT%20Analog/Panasonic%20KX-T616%20Station%20User%20Guide.pdf
Carl
May 11, 2009 | Panasonic KXT 61610 R3 Key Service Unit...
It always losing the line during the cordless calls
* CHECK YOUR AC OUTLET WITH NO LOOSE CONNECTIONS.(remove multi adapters mostly caused problems)
* FULLY RECHARGE THE BATTERIES.
* CLEAN DE BATTERY CONTACTS IN & OUTSIDE THE HANDSET & THE BASE UNIT.
* IS THE BATTERIES DON'T GET CHARGED FULLY IN OVER NIGHT.PLEASE REPLACE THOSE.
* REPLACE WITH ONLY RECOMMENDED RECHARGEABLE BATT"S.
* PLACE THE BASE UNIT AT CENTRALIZED AREA FOR THE MAXIMUM HANDSET RADIATION.
* KEEP THE BASE UNIT AT SAME FLOOR.
Mar 30, 2009 | Panasonic KX-TG1100 Cordless Phone
Suddenly line 2 only works on wired phones
Here are a couple of things to try. First is to disconnect the base and install a regular two line phone to verify that line 2 is ok at that jack. Also on Panasonics website, when you unboxed and installed that unit, there was a cord that had green plugs on it. That was a 4 conductor cord. If somebody changed that out to a 2 conductor, it could cause this. Also it could be a defective cord. If you have another 4 conducter cord from the wired phones, swap it out. Make sure on the base, on the back, that it is plugged in to the correct plug, marked line 1/2. Basically if a regular 2 line phone works, it is possible that the unit is defective. Also maybe unplugging the base from power and resetting that may fix it also.
If that does not help here is Panasonics number.
1-800-211-PANA(7262)
Jan 05, 2009 | Panasonic KX-TG2740 Cordless Phone
Lost panasonic KXT-7730 password
If you lost the password the only way to get into programming mode is to reset the telephone system to factory default. If you are not accustomed to all programming features this is not recomended because resetting will whipe out all programming including ringer settings, extension names, speeddials, routing and class of service. If you still want to reset let me know.
Dec 10, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7885 Cordless Phone Logo
47 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
