Miele W 865 - washing a big rug and when it tried to spin it was an out of balance and the machins wobbled a lot then stopped with the 'Rinses' light flashing. A local repair man thinks that ther machine is ok just need to be reset but doesn't know how
    Genius:
  • 3,422 Answers
I'll let you know if there is a manual available for your model.
Posted on Apr 25, 2008
  • Priya darshan Apr 25, 2008
    Hi again,
    I have looked for a user manual and it looks like it is not available on the net.So the best solution is to contact these guys and ask them for a manual by sending them an email.
    You can get the telephone no. from HERE
    You can get the email support id from HERE
    Once you get the manual you can get the reset button.
    Goodluck,
    Please don't forget to rate the solution
  • 563 Answers
Hi grahamcox
This happened to my LG once as well.
Just leave the machine switched off for 24 hours and try it again.
  • Marnus Jacobs
    Marnus Jacobs Apr 25, 2008
    Hi Grahamcox
    As mentioned above , I checked on the Miele support site as well and they confirmed this. To check this out click HERE
    If this doesn't work , you should rather contact Miele's Customer Services.
    Thanks for using Fixya and Good Luck !
    Genius:
  • 2,785 Answers
Dear grahamcox
plz give the model no. and make
Why does Miele indicator stick on 'rinses'?
Hi dear. Your machine may have one of the three factors playing up.
1- Tacho generator or it's plug on motor
2- Motor carbon brushes
3- Power/ electronic module faulty. Thanks.
Mar 24, 2016 | Miele Washing Machines
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
Washing machine
check lid isolation switch. check for balance of clothes. I would go for the lid switch first. The balance second as if it starts to spin and wobbles violently it will switch itself off to prevent damage and you will have to move the clothes around to balance the drum.
May 18, 2013 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Throw rugs are dripping wet after washing. My washer doesn't have just a spin cycle, so I have to rinse and spin. This still doesn't help. Every rug I wash comes out dripping.
The washer is likely detecting an off balance load with only a rug or two. You may want to try and put more rugs or old towles in to offer a counter balance to alleviate off balance condition. Or, you may consider washing the rugs at a commercial facility. They really are hard on the residential machines, especially if they come apart or the backing comes off.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
How do you wash one rug? I can't get the machine
You dont say how big this rug is, but I am guessing its not big enough to spreadevenly around the machine. The machine senses an imbalance and willo not spin or failos to spin at a rate that would rekove the water. Try adding some balance to the drum with another object that will evenly spread the load to see if that helops to get rid of the sopping water.
BTW any pictures of you whipping the rug around in the backyard? That should make for Utube fame!
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Agitator ''dogs'' not gripping, agitator spins freely; tub rocks
Likely a broken dog itself was making the noise. They should all be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
Itis a 'no spin".It washes, drains, then it rinses, bypass spin to off.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Oct 18, 2006 | Magic Chef CAV2000 Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
