Question about Digimate DG4200 42 in. HD-Ready Plasma Television
What do ALL mean for the regional code for a DVD player ? Ref; Digimate LTV-1961WCR
  • 10,421 Answers
RCA blu ray/ dvd video player won't play regular dvd any longer
Laser assembly has lost the ability to focus and play back. Replace unit since repair not cost effective.
Dec 19, 2016 | RCA Televison & Video
I want o purchase a Multi region DVD player. Will any or all of the following play Region 1 US Import DVD's Please?
Check the DVD player specs for this quote "Free Upgrade - Plays Region 1-6 DVDs". Then it will do what you want.
Mar 01, 2015 | Televison & Video
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
Dgm ltv-1961wcr tv, when powering up the screen comes on for about a second, then goes black?
It is a Lcd lamp problem or even the lcd panel try to see any reflexion of the image , if u see one is the lamps, if not then is the lcd panel and if it is then is garbage.
Apr 23, 2012 | Digimate Televison & Video
I have bought Pioneer DVD player 420V few days ago, but when I put disc I got message on the TV that DVD can not play because the region code is not recognized. Should I reset all systems or???. I need...
the region code means the player does not support the disc your playing each country is given a region code for dvd australias is region 4 if you buy a dvd from another country it wont work you can get multi region codes for dvd players im not sure of pioneers code but try using a dvd from your country region and youl find it works just fine you can also try asking a tech on fixya for the multi region code for the model dvd player you have.
best of luck
merry christmas
Dec 22, 2010 | Pioneer DV-490V-K DVD Player
What does check regional code mean?
It means your DVD player has a different region code to the disc you are attemting to play.
DVD's and most DVD players have a region code corresponding to the country/region in which they were purchased. The region code printed on the disc must match the region code of the player, usualy found on the rear of the unit or in the manual. Only players set to code 0 or 9 are able to play all regions, a setting of 1- 6 is most common. 1 = USA 2 = Europe etc.
It is often possible to set your player to code 0 or 9 enabeling you view all region DVD's.
May 16, 2010 | LGDVB418 DVD Player
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Wrong Region code error
http://www.amazon.com/gp/cdp/member-reviews/AGHZ9UF25BLCU/ref=cm_cr_dp_auth_rev?ie=UTF8&sort%5Fby=MostRecentReview
Click on the link and read the review of your product.
The region is set at the factory for your market for DVD movies in your area. Phillips says the warranty is void if you change the settings, but if you read the review he will tell you that you can make it region free.
Proceed at your own risk.
Mar 23, 2008 | Philips PET710 Portable DVD Player
What is a region code 2 dvd player
Most of the DVDs available in India mostly use Region 2, Region 4 and Region 5 codes, all together in one DVD.
Education on region dvd codes:
http://en.wikipedia.org/wiki/DVD_region_code
If you want something on the cheaper side try a Philips DVP5982 Multi-Region DVD Player.
hope that helps!
Jan 31, 2008 | Televison & Video
Changing region on a DVD player
You did not specify what kind of DVD player this is? Since you said player, and not drive, then I will assume this is a dvd player you hook up to your TV, not install in a computer.
Simple answer, you can not change the region code on a DVD player, unless there is a known hack listed on a website.
Therefore, your only option, is get a region free dvd player. They are cheap and easy to get on amazon.
here is one for $30:
http://www.amazon.com/Philips-DVP642-DivX-Certified-Progressive-Scan-Player/dp/B000204SWE/ref=pd_sim_e?ie=UTF8&qid=1196024533&sr=8-9
Nov 25, 2007 | Televison & Video
Digimate DG4200 42 in. HD-Ready Plasma Television Logo
67 people viewed this question
Top Digimate Televison & Video Experts
Jaime Hernandez
sureshd2008
 Grubhead
Grubhead
Are you a Digimate Televison and Video Expert? Answer questions, earn points and help others
