Question about Umax Astra 6700 Flatbed Scanner
Serch start position error
I have found search start position error with error code 177 while we scan the document.
  • Anonymous Jun 06, 2008
    During preview and scan process i Got a message.
    error code 157
    read image error
  • Anonymous Aug 29, 2008
    error code 157
    read image error
I have a problem my scanner umax astra 4500 with message start position error with error code 17
why solution it.
thank
Posted on Nov 25, 2008
SOURCE:
Conika minolta bizhub 215 error code c6101
The scanner is not going back to home position, have a tech come out to check this. The scanner is what moves when scanning a document on the big glass or if using a document feeder
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 08, 2017 | Minolta Office Equipment & Supplies
How do l get low def lite,no start counter and code 16cf00,18b400,15b700,131e00,17900 to reset.
PDF Manual Document Search
5.249.144.94/
I have the check engine light on and the scan read P0135 error - what is this? .... lite,no start counter and code 16cf00,18b400,15b700,131e00,17900 to reset.
The unit will not stay on unless it is plugged into the wall
www.greatbook.tk/F/.../t26023273-unit_will_not_stay_unless_plugged_i...
... condition · Emergency brake repair on 1992 Chevy lumina · How do l get low def lite,no start counter and code 16cf00,18b400,15b700,131e00,17900 to reset.Missing: error
Dec 29, 2015 | Cars & Trucks
How can I fix This car?
FIX/CHECK IGNITION COIL FIRST, BEFORE YOU DO ANYTHING ELSE
Mar 19, 2015 | 2001 Lexus RX 300
How to fix canon mp258 error code 2,140,2 when i scan douument
please help me....
I m trying to scan my document but it is showing error code 2,140,2 on PC and error code E5 at printer....my catridiges is empty is it because of that reason............
Aug 11, 2012 | Canon PIXMA Office Equipment & Supplies
Error Code: 39,003.40:133671 Yesterday the copier/scanner would not work. I shut the printer down and restarted it and received the above error code. I shut the printer down again and restarted it and...
this is a scanner problem that can be associated with the scanner lock under the scanner bed. make sure the lock is in the 'unlocked' position. it is easy to move this when lifting the scanner bed to reload the ink blocks. if this does not solve the problem you may have to replace the scanner assembly. hope this helps.
Aug 19, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
I put my pen drive in first it recognize it then it says i should scan it after scanning it i send a document onto it then it says it cannot recognize it. i have tried it on another computer but still it...
If this is a U3 Sandisk USB stick drive you can usually use the launcher installer to backup the contents if it is still physically working.
Otherwise there are a few websites that will offer a recovery application
Jul 07, 2010 | Electronics - Others
Scanner will not scan an item into My Documents
try to uninstall then reinstall the driver. to do that go type device manager in run box in XP and start search in Vista/ Win 7, and look for the scanner. right click and uninstall. then load the driver from the website or from the cd that came with your device..
Mar 29, 2010 | Computers & Internet
Cannot scan documents
go to device manager look for imaging device (scanner) right click and uninstall. / click scan for hardware changes tab, found new hardware must be appeared and click next / select don't search, i will choose the driver to install / click show compatible hardware and choose scanner driver found and click next. and finish.
Feb 11, 2010 | Fujitsu M3091DC Path-Through Scanner
HP 1210 all in one scanner connection error
I found a solution to this...
1. Go to the Windows Start Button
2. Click on Programs
3. Click on Windows Fax and Scan
4. Use that program to scan documents
Apr 21, 2009 | HP PSC 1210 All-In-One InkJet Printer
Xerox workcenter c2424 error code 39,014.40;33151
Could be a dirty scanner. Not much to check, it is a lamp issue.
You can try disconnecting the cables to the document feeder and scanner. The one on the right side of the machine, where the power cord, thats is odd to access and tighten often works loose.
Here is the entire documentation troubleshooting procedure, this is from the service manual.
Step Questions and Actions Yes No
1 1.
Cycle power to the system to clear.
2. Did the error recur?
Replace the Complete.
2 1.
2.
3.
3 1.
Are the lamps on?
2. Run the diagnostic test:
Go to Step 3. Replace the
lamp(s).
4 1. Is the scan head in the home position? Replace Replace
Mar 28, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Umax Astra 6700 Flatbed Scanner Logo
494 people viewed this question
Top Umax Office Equipment & Supplies Experts
Thomas F. Schneider
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
