Computers & Internet Logo
Posted on Aug 02, 2010
The ppms warning indicator is on. what does this
The ppms warning indicator is on. what does this mean?
WHY IS MY2020 ISUZU NPR AC Y DASH LIGHT ON
The AC dash light in your 2020 Isuzu NPR indicates that there is an issue with the air conditioning system. This could be due to a number of reasons, such as a faulty compressor, low refrigerant levels, or a bad relay switch. It's important to have a professional technician inspect the system to diagnose and repair the issue as soon as possible.
Car Dashboard Warning and Indicator Light Meanings ...
https://dashboardsymbols.com/the-symbols/
What Does the Transmission Warning Light Mean? Common ...
https://www.carparts.com/blog/what-does-the-transmission-warning-light-mean-common-causes/
5 Common Reasons Why Your Check Engine Light Is On - Greg's ...
https://www.gregs.com/5-common-reasons-why-your-check-engine-light-is-on/
No sign of gear on the dashboard of my Nissan serena
Generally, when the dashboard warning light populates, panic erupts - why? Most people are unaware of what specific symbols mean. If they did, they would know that not every warning light signal is indicative of a malfunction or costly repair.
At times, your dashboard lights are merely letting you know what systems are in use. We decided to compile a list of the most important indications, so you can have a better understanding of Nissan warning lights and their meanings.
2007 mercury mountaineer wrench light lit. what is that mean?
Wrench Warning Indicator (Base Instrument Cluster)
The instrument cluster receives the powertrain status from the PCM over the HS-CAN. When a powertrain system concern is detected, the PCM sends the instrument cluster a command signal to illuminate the wrench warning indicator. If the 4WD control module detects a failure with the 4WD drive system, the 4WD control module sends a message to the instrument cluster over the CAN to illuminate the wrench warning indicator. On 4.6L engines, if the transmission control module (TCM) detects a failure with the transmission, the TCM sends a message to the instrument cluster over the CAN to illuminate the wrench warning indicator.
It means a trip to the dealer or some other qualified repair shop .
2010 ford explorer wrench light what does this mean
You need to take it to the dealer for them to sort it out , needs dealer IDS factory scan tool to see which system is the problem .
You
2answers
Engine warning light
Warning light on mean you car have problem. When the engine warning light remain on for a long, Mostly is your engine system got fault codes. You can use obd2 code scanner to have a check, the fault code will tell you problem
I have a 2004 Jeep Cherokee Laredo. An indicator (with a symbol of what looks like a radiator) below the low fuel indicator (bottom left had side of the dashboard) lights up and remains on. I have checked...
2005 Instrument cluster layout
1. Speedometer
2. Brake warning light
3. Turn signal indicator light
4. High beam indicator light
5. Malfunction Indicator Light (MIL)
6. Airbag warning light
7. Anti-Lock brake warning light
8. Tachometer
9. Security alarm indicator light
10. Oil pressure warning light
11. Electronic Stability Program (ESP)/
Traction Control System (TCS) indicator light
12. Tire Pressure Monitor warning light (base)
13. Temperature gauge
14. Electronic Vehicle Information Display
15. Tow/Haul indicator light
16. 4WD Low mode indicator light
17. Seat belt reminder light
18. Cruise control indicator light
19. Odometer/Trip Odometer
20. Transmission gear indicator
21. Fuel gauge
22. Electronic Throttle warning light (5.7 Hemi)
23. Front fog light indicator light
24. Voltage warning light
5helpful
2answers
One of the dummie lights is on and I am not sure what it means. Its the round one on the bottom right.
1. Brake warning lights. 2. Charge warning light. 3. Oil pressure warning light. 4. Coolant temperature warning light. 5. Coolant level warning light. 6. Engine management system warning light. 7. ABS warning light. 8. Airbag or SRS warning light. 9. Glow plug warning light 10. Water in fuel warning light 12. Low fuel warning light.
Not sure what light I would be on the bottom right but I hope this helps.
Good Luck!
8helpful
There is a light on the dashboard that I do not
I believe it's the washer fluid light
Here's a list of your dash lights and their meanings
Left
1. Door-ajar warning light
2. Oil pressure warning light
3. Check engine warning light
4. Tour or Sport for the ECS
5. Security indicator
Center Warning Lights
1st space down
Left: 4-wheel steering oil level warning light
Right: Brake warning light
2nd space down:
Left: Anti-lock brake warning light
Right: Active Exhaust Tour indicator
3rd space down
Left: cruise control indicator
Right: cruise control ON indicator
4th space down:
Left: charging system warning light
Right: High-beam indicator
Right Warning Lights
1st down: Not used
2nd down: Seatbelt warning light
3rd down: Washer fluid (2 storage containers)
4th down: Supplemental restraint system (SRS) warning light
8helpful
2answers
Warning light indicator
Hello, My car is nissan tiida 2007. I recently noticed that there is a yellow colored engine shape warning indicator in the dashboard. What does this mean
Dash board light indicator
water light check coolent lvl in resavore
Top Hyundai Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Simon Atkinson
Simon Atkinson
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
