Question about Toro Lawn Mower With Toro Power Tools
MY TORO RIDING LAWN MOWER CUTS OUT AFTER TAKING MY FOOT OFF THE BRAKE
  • 252 Answers
Sounds like the seat switch is faulty or blade engage switch is stuck down
try pulling wires from seat switch if continues to run with wires off faulty switch if not may be pto switch stuck down
have a look and check it sounds like a seat switch
cheers hope it helps
Posted on Aug 03, 2010
I have a Toro model number 20622 auto start go forward and backward the blade won't turn it's like it's got a break on it how do I get this to work when I pulled the lever nothing happens
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
How to Replace Brake Pads on Mower Cutting Deck
Mower Deck Return Spring Replacement Craftsman Riding Lawn Mower Repair...
Apr 18, 2016 | Toro Garden
My toro 3200 seems like the transmission is locked
check the brake make sure its disengaged
if it wasnt moved in awhile brake can stick
Feb 07, 2015 | Toro Mowers - Time Cutter SS3200 32""...
Why does my torolawnmower take off when i start it?
I have a riding toro lawn mower that cut off on me and wouldn.t start back, what could be my problem? The crak wheel trys to turn but it won,t turn over
Dec 11, 2012 | Toro Lawnmower Lawn Mower SP Drive Belt...
Why does my john deer la115 make a loud screeching sound when i take my foot off the brake
Bad belt or belt tensioner. Shut it off and look underneath for problems.
Apr 21, 2012 | John Deere Garden
I have a Husqvarna YTH2242, the engine runs great but as soon as I take my foot off the brake the engine dies. What can be the issue?
all the safety switches tie into a relay which kills the motor if they are not in the correct position for operation. find the relay and replace it.
Apr 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My Cub Cadet lawn tractor model 2155 stalls when I take my foot off the brake. Why?
SOUNDS LIKE ONE OF YOUR SAFTEY SWICHES ARE BAD ID START WITH THE SEAT SWICH THAT MAY BE ALL IT IS
Oct 08, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Looking for a good lawn mower
Any mower will do the job if you keep the blade sharp and do your maintenance. But you cant go wrong with the big names.
Apr 23, 2009 | Mg International MasterCut 20" 123cc Push...
Toro riding mower/chain adjustment
There is an adjustment for the chain. There is a sproket that you can loosen and adjust. You should be able to get it from the outside of the machine. Should be a 1/2in or 9/16in nut.
Jan 31, 2009 | Toro Lawn Mower With Toro Power Tools
How many HP?
* If your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Toro Lawn Mower With Toro Power Tools Logo
407 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
