Question about LG CHOCOLATE BL40 (1 GB) Cell Phone
Battery life only lasts 24 hours - - LG CHOCOLATE BL40 (1 GB) Cell Phone
  • LG Master
  • 3,866 Answers
Most cases a new battery should work to fix your issue, But i have seem some common issues in these LG phones that where sent back because of a defective board inside that causes drain because of the bluetooth radio and other sheer badluck with the board inside. I would first have it observed by a local repair shop to see if its even worth the sheer mistake of going wroung on a new battery. But first after discovering the fualt in these lg phones would you have LG take care of the issue. Most cases people with cell phones have a insurence plan with there provider I have seen as low as $50 for a deductable witch can save you big cash in the long run that is if the phone is out of warranty.
Good luck and God bless
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 02, 2010
How do i check the battery life of the calculator?
The life of the batteries depend on the use. If calculator is on and running programs 24 hours a day, the batteries will not last more that 2 or 3 days. If you use it the calculator for 2 hours a day, fresh batteries may last a semester.
But I believe you want to check the CURRENT state of the batteries. You can buy from an electronic store or a dollar store a device that tells you if a battery is still good or not.
With the TI Connect software you can check battery status. See the screen capture that follows. To obtain the displayed window you must click the button DeviceInfo with calculator connected to the computer and TI Connect running.
Jul 17, 2011 | Texas Instruments TI-84 Plus Calculator
I have a portable DVD player,Yukai 700 I have charged the battery several times , but it only lasts five minutes in its dead. Once I charged it for three hours done for seven hours in the last time 24...
This means that the battery is unable to hold a charge any longer. THe only option in this case is to replace the rechargeable battery for your Yukai 700. A battery has a charge life meaning you can only charge it for a set number of times. It seems that it has already exceeded that.
Aug 14, 2008 | Mustek Televison & Video
Tip
Make your Lithium Laptop Battery last longer.
Hello folks,
Although I usually offer advice on backing up files or recovering them, I have been asked a lot lately how my 3 year old laptop still runs 1:45mins on a standard battery when many peoples 1-2 year old laptops can barely last an hour.
Simply put, most people do one of two things wrong. Both are common misconceptions and easy to remedy. First I've heard countless people tell me they pop the battery out of their laptop and toss it in the desk drawer until needed, often months. Second I have been told by more people than I can count that they leave their laptop plugged in 24/7 for most of the year.
Bottom line, although popping it out and leaving it in the drawer is less harmful to it's lifespan, both ideas are wrong.
The shelf life of most unused lithium batteries is shorter when unused than ones being used properly. The lifespan of a battery that is constantly being trickle charged is even shorter.
Most batteries in modern laptops are 4-6 cells, designed to give about 2 hours of charge and should last 3-5 years with charge life starting to degrade in the third year.
A "stored battery" has only 3 years of shelf life due to extended times sitting discharged and one that is trickle charged 24/7 may burn out in as little as a year.
Many laptop manufacturers have taken measures to improve this but ultimately the best thing for your battery is to use it. If you currently run you laptop plugged in 24/7, unplug it every night after you shut it off, then when you start it in the morning, let it run an hour before plugging it back in. This will give the battery both down time and exercise.
If your battery is in a drawer somewhere for safe keeping, put it back in the laptop, run it down then charge it over night and run it down then recharge it one more time. Store it back in the drawer charged and repeat the cycle at least once a month.
These tips will help drastically improve you batteries performance over time. My 3 year old laptop only ever got 2 hours of battery life and still gets 1:45 with no power saving measures, give it a try.
Crankstart
on Mar 20, 2010 | Computers & Internet
FOR HOW LONG CAN THE BATTRY LAST BEFORE YOU CHANGE IT
How Long Does the Nokia E65 battery REALLY last?
Ever wonder how long the phone battery actually lasts? For the first use of my Nokia E65, I charged the phone for 24 hours after receiving it (still not sure if this is necessary), then took it off the charger Saturday afternoon. The battery low warning first sounded 54 hours later. This was after
•Calls: Around 15 calls made and about 3 calls received, with almost 40 minutes call duration in total.
•Data: 726kb data sent and 3.96mb downloaded
•WIFI: About 20 minutes of WIFI use
•Applications: Use of Skype and Gmail application as well as a bit of Nokia Maps and Google Maps
The battery eventually gave up after 2 more hourse of standby. The Nokia website says the following about the Nokia E65 battery:
•BP-4L 1500 mAh Li-Po standard battery
•Talk time (maximum): GSM up to 11 hours; WCDMA up to 4h 40 min
•Standby time (maximum): GSM up to 18 days; WCDMA up to 20 days;WLAN idle up to 170 hours
If you are wanting to make comparisons with the Nokia E71 battery life, this is what the Nokia website claims for the Nokia E71. The Nokia E65 and E71 both use the same battery - BP-4L 1500 mAh Li-Po battery but E71 is slightly more demanding on the battery life.
•Talk time:- GSM up to 10 h 30 min- WCDMA up to 4 h 30 min
•Standby time:- GSM up to 17 days- WCDMA up to 20 days- WLAN idle up to 166 hours
If you are willing to help, maybe you can do the same experiment for your Nokia E65. Use the call logs and the data counter under "Connectivity" and measure how long your Nokia E63 battery lasts with "normal" usage. Report your findings in the comments below and someone just as curious as you googling battery life E65 will also benefit from your efforts.
Your mobile habits may not be as demanding as me but I hope this helped you in your battery life calculations for the Nokia E65.
To charge a battery from empty to full, it took 2 hours and 40 minutes
....... If you are willing to help, maybe you can do the same experiment ... It lasts me about 40 hours before I get a battery low warning .... I got my Nokia E65
Jan 05, 2011 | Nokia e65 Cellular Phone
Battery life
It must be battery's defect that prevented it from retaining the charge. You may want to replace the battery. I just got one from www.wirelessunlimitedonline.com for $6.95 w/ free shipping.
Apr 04, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Charging new battery
usually 8 hours.
for first charge.
on a brand new battery
Jan 29, 2009 | IBM ThinkPad T41 Notebook
Battery goes dead in 24 hours even without use
DO YOU HAPPEN TO KNOW THE CODE TO UNLOCK THE PHONE WE HAVE?I WOULD APPRICIATE IT GREATLY IF U COULD HELP ME OUT....THANK U VERY MUCH.
Dec 21, 2008 | Samsung SCH-u340 Cellular Phone
Charging new phone
it wont harm your phone they just recomend 24 hours to make sure the bat is ok and that it gets fully charged but remember to let your bat go totally flat from time to time this will prolong the life of your battery as it does them no good just keep topping it up so i sugest to let it go totally flat say once a month this will keep your battery lasting longer between charge hope this helps
Oct 26, 2007 | Motorola Mobility RAZR V3
Battery Life
These things just came out 18 hours ago! Didn't anybody get a User Manual??
Jun 30, 2007 | Apple iPhone Smartphone
LG CHOCOLATE BL40 (1 GB) Cell Phone Logo
166 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
